frst help please this is a weird one
Old Jul 15, 2006 | 06:42 PM
turbomad1's Avatar
turbomad1
Default frst help please this is a weird one
are you ready for a long one cus its done my head in for the last week
ok first i swoped over from a t2 to a t3 turbo all went back together ok as far as i am aware then we changed the injectors to beige injectors but what i wasnt aware of they were the wrong ones (bought off ebay and shouldnt have taken someones word for it should of checked part number) anyway put them in without looking at them all went in ok went to turn it over and it wouldnt turn over tried but wouldnt quite go so then checked the part number and found out they were the wrong ones so put the blues back in and it was the same so started checking the usual things spark and such like took one of the plugs out turned it over looking for a spark and then it fired up on 3 without the 4th plug in so thought it must have been blockage or something so put the plug back in and again it wont start then proceeded through all 4 plugs and it did the same on them all starts on 3 but when 4th plug is in it tries but wont quite go
any ideas what this could be
i have tried putting the plug in whilst running on 3 and soon as the plug gets close to the hole it cuts out(dodgy i know )
i was told the erst manifold gasket was diferent so swoped that but same have fuel
all injectors seem to be working all plugs have spark
i am wondering if putting the wrong injectors in might have blown the ecu at the mo trying to get hold of an ofac ecu now
but if you can help in any way let me know as i am starting to run out of hair to pull out
Old Jul 15, 2006 | 06:54 PM
turbomad1's Avatar
turbomad1
i also better ad the engine has only done 5k since its had a full engine rebuild and was perfectly fine before swoping everything
Old Jul 15, 2006 | 10:44 PM
SafeChav's Avatar
SafeChav
You sure you haven't got a wiring fault or a weak earth, very strange fault
Old Jul 15, 2006 | 10:47 PM
turbomad1's Avatar
turbomad1
yeah man definetly all connected back up propa as far as we can see the only thing left to try is take the downpipe back off and see if there is anything in them i think as iv tried everything else i can think of.
if there is i am gonna brain my kids
Old Jul 15, 2006 | 10:51 PM
SafeChav's Avatar
SafeChav
So does the car cut out before you start screwing the plug in?
Old Jul 15, 2006 | 10:58 PM
turbomad1's Avatar
turbomad1
the car itself didnt start after we swoped the injectors and the turbo all it did was try to fire
so thats when we took the first plug out to check for spark and it cracked straight up on 3 without the plug in so we thought put it back in and try it but the same happened
but the car was fine before when it was running on the t2 that morning
Old Jul 15, 2006 | 10:59 PM
turbomad1's Avatar
turbomad1
yes matey sorry soon as you go to put plug close it cuts out yeah misread what u put
but if u dont it will run on 3 for as long as u like
Old Jul 15, 2006 | 11:03 PM
SafeChav's Avatar
SafeChav
That has to be an electrical fault if you don't even have to screw the plug in.....
Old Jul 15, 2006 | 11:07 PM
turbomad1's Avatar
turbomad1
i think its maybe more its blocking the air from coming out the port mayby at the mo asthough the engine is choking itself and when u go to put plug in its blocking airflow as such.
i can see what ya mean matey im am gonna take the ecu to pj's on monday see if he can check it over
Old Jul 15, 2006 | 11:08 PM
turbomad1's Avatar
turbomad1
cus i have tried moving connections when its running on 3 and all is ok till u try and place plug near the hole
Old Jul 15, 2006 | 11:09 PM
SafeChav's Avatar
SafeChav
Theres no way pushing the plug close to the hole is going to cut an engine out on a pressure/richness basis.
You sure all 4 injectors are firing?
Old Jul 15, 2006 | 11:12 PM
turbomad1's Avatar
turbomad1
yeah definetly firing
this is why i am think possibly asthough there might be something in the downpipe/turbo manifold blocking it so the exhaust gas's have knowhere else to go other than the plug hole if ya see what i am saying
Old Jul 15, 2006 | 11:16 PM
SafeChav's Avatar
SafeChav
U would know about it if the there was a blockage, it would be making popping noises if it was escaping out of the plug hole.
And if it was blocked itw ouldnt run on 3 either........i seriously think you have a wiring fault, not necessarily a loose connection, but a bad earth or feedback somewhere....
Old Jul 15, 2006 | 11:17 PM
turbomad1's Avatar
turbomad1
ok matey cool il check it over again and see if i can find anything matey cheers for ya help
Old Jul 15, 2006 | 11:18 PM
SafeChav's Avatar
SafeChav
What loom are you using? And what car?
Old Jul 15, 2006 | 11:20 PM
turbomad1's Avatar
turbomad1
its a fiesta rs turbo and its running on ofac matey
Old Jul 15, 2006 | 11:21 PM
SafeChav's Avatar
SafeChav
So all you've done is change to a T3 and fit those shindogu injectors, and then change back to injectors you ran previously without any problems?
Old Jul 15, 2006 | 11:22 PM
turbomad1's Avatar
turbomad1
yes matey thats it
Old Jul 15, 2006 | 11:23 PM
SafeChav's Avatar
SafeChav
Hmmmm, very strange. How do you know the injectors are definately firing? Just out of interest
Old Jul 15, 2006 | 11:25 PM
turbomad1's Avatar
turbomad1
checked em with the mk5 escort bulb holder and bulb
and also it wouldnt fire on any of the 3 cylinders
Old Jul 16, 2006 | 12:38 AM
turbomad1's Avatar
turbomad1
thanks alot for all ya help buddy gonna get on it early in the morning and see whether or no we can get it going
Old Jul 16, 2006 | 09:10 AM
Stu @ M Developments's Avatar
PassionFords Creator
I presume you havent added a chip for those injectors and forgotten to take it out?
Old Jul 16, 2006 | 09:11 AM
turbomad1's Avatar
turbomad1
i have tried it with the chip and without the chip still exactly the same matey
Old Jul 16, 2006 | 09:24 AM
Have you had the leads off?
Are you 100% certain they are on teh correct way?
This system fires with the wasted spark principle so fires 2 at once. Its not totally unfeasible that you cold get them wrong in such a manner that 1 mising would allow it to run, but the 4th would cause an issue.
Old Jul 16, 2006 | 11:26 AM
SafeChav's Avatar
SafeChav
Any luck yet?
Old Jul 16, 2006 | 12:26 PM
white2i's Avatar
white2i
yes it runs found prob but will turbomad1 tell you what it was
Old Jul 16, 2006 | 12:30 PM
SafeChav's Avatar
SafeChav
come on give over
Old Jul 16, 2006 | 01:21 PM
turbomad1's Avatar
turbomad1
thanks for ya help now guys but i have sorted it out some prat had blocked the turbo up before i bought it there was a peice of newspaper rammed into the back of the turbo
this is what was in there
but least its sorted now
thanks again for all your help
Old Jul 16, 2006 | 01:31 PM
SafeChav's Avatar
SafeChav
how annoying.
Still, at least it was a simple fix
Old Jul 16, 2006 | 01:35 PM
turbomad1's Avatar
turbomad1
yeah man just a bit matey took a week to figure out but the funny thing is i thought about this first and never checked it cus i was steered away from it via the injectors being the wrong ones
Old Jul 16, 2006 | 01:40 PM
SafeChav's Avatar
SafeChav
Ah well, may of cost a bit of time but at least you didn't have to buy loads of unnecessary parts
turbomad1's Avatar
turbomad1
yeah man
Old Jul 16, 2006 | 01:43 PM
SafeChav's Avatar
SafeChav
Why aren't you out giving it a good thrashing for causing you agro
Old Jul 16, 2006 | 01:44 PM
turbomad1's Avatar
turbomad1
it now needs a setup lol before i can do that lol cus its now has boost fade lol but beleive it will get it soon as i can wana get all steup asap
Old Jul 16, 2006 | 01:47 PM
SafeChav's Avatar
SafeChav
Good plan
Old Jul 16, 2006 | 01:49 PM
turbomad1's Avatar
turbomad1
the block and head cost me 4.5k all in all so i dont wana blow it up cus of being impatient cheers again for ya help
Old Jul 16, 2006 | 01:51 PM
SafeChav's Avatar
SafeChav
four and a half grand!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Fuck me that should be shit scary. Probably best to wait for the set upothen
Old Jul 16, 2006 | 01:52 PM
turbomad1's Avatar
turbomad1
yeah man it will be lol when its got all the cossie managment on
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
gambo08
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
