Engine managment light
Old Aug 12, 2004 | 09:31 PM
jr cossie's Avatar
jr cossie
Default Engine managment light
I've become the proud owner of 3 door cossie,its done about 2000 miles since its rebuild recently the engine managment light comes on when driven hard (after 4000 revs) there is no big end knock. any ideas?
Old Aug 13, 2004 | 06:26 AM
dave green's Avatar
dave green
£ door cossies dont have a engine management light . do you mean the oil light.
Dave
Old Aug 13, 2004 | 07:54 AM
foreigneRS's Avatar
foreigneRS
Testing the future
3 door cossies do have an engine management light, as jr cossie has found. it's on the small panel above the digi clock, with the low fuel warning and low washer water warning. it's an orange warning lamp that comes on when the ecu senses a fault with a sensor or something.
look here and here and here for what to do (build a test light, check the error code, find the error and fix it).
job done. enjoy cossie ownership
Old Aug 13, 2004 | 08:50 AM
jr cossie's Avatar
jr cossie
cheers, thanks for the info
Old Aug 13, 2004 | 05:28 PM
dave green's Avatar
dave green
I stand corrected. oooops
Old Aug 13, 2004 | 07:09 PM
2001ode's Avatar
2001ode
Hi,
I believe it is not necessary to build a test light.
Just shunt, on 5 holes connector, near ECU, the 2 lower pin.
And fault cold should be given directly by engine mngt light.
Regards.
Old Aug 14, 2004 | 12:09 AM
Billabong's Avatar
Billabong
Is your Cossie chipped? If it is, it *might* just be that the ECU is seeing an overboost situation (st1 normally about 15psi).
Old Aug 14, 2004 | 09:01 AM
jr cossie's Avatar
jr cossie
My cossie is stage 1 chip,zorst,filter.It boosts at 15psi(peaks at 18).
Old Aug 14, 2004 | 12:04 PM
rocar's Avatar
rocar
Thats why the check light goes on beause as Billabong said .Thats no trouble as it turns off as you switch off the engine and start it again.
Old Aug 16, 2004 | 03:30 AM
jr cossie's Avatar
jr cossie
cheers guys you were right
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
