Bd14 Cams
Old Dec 16, 2003 | 09:46 PM
Default Bd14 Cams
Any one know how much i should advance/retard the inlet and exhaust cams by
spec of me engine is
low comp 7.2/1 (Cosworth pistons) 200 block
multi layer headgasket etc etc
ported head
T4 turbo
Greys
Rs500 type intercooler
turbosystems chip in me P8 ecu
with the standard throttle body and with 27psi it made 419bhp at interpro
atm i run inlet at 10 degrees advance and the exhaust at 0..
Lot of people say that i should run the exhaust retarded but i have tried it at 6 degrees retarded and it felt flat to me..
any advice would be nice
Old Dec 16, 2003 | 10:13 PM
Stu @ M Developments's Avatar
PassionFords Creator
meep meep,
Youd best check those figures as your in the region of 100 degrees out
Old Dec 18, 2003 | 02:57 PM
Mike Gurney's Avatar
Mike Gurney
get it set up professionally m8
you are supposed to use a DTi gauge and set it at 120 degrees - so mid dwell is on the cam - or something like that anyway
Old Dec 18, 2003 | 08:41 PM
thx all will get it checked out
think they were set at 110/120 tdc
and then the inlet advanced 10 degrees on the vernier
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
