3 door cos trailing arm bushes?????
Old Dec 16, 2003 | 07:21 PM
Blakeya's Avatar
Blakeya
Default 3 door cos trailing arm bushes?????
Gonna replace the trailing (Swing) arm bushes on the rear of my cos, among other things. Would like to know if i should fit poly bushes or new standard ones.
Any help much appreciated.
Andy
Old Dec 16, 2003 | 07:44 PM
RSrussell's Avatar
RSrussell
I believe the iner ones are sypherical bearing but the outter ones are just rubber bushed.
Therefore keep the inner one syperical, but change the outer ones to poly
Old Dec 16, 2003 | 07:55 PM
Blakeya's Avatar
Blakeya
Anymore for anymore please!!
Andy
Old Dec 17, 2003 | 12:31 PM
B11GNS's Avatar
B11GNS
I changed the whole rear end, inner and outer and big beam ones, made so much difference! Is a big job though
Old Dec 17, 2003 | 04:49 PM
Blakeya's Avatar
Blakeya
Steve,
Did you change the for poly ones o standard ford ones?
Andy
Old Dec 18, 2003 | 04:00 PM
B11GNS's Avatar
B11GNS
Polies, all round.
Old Dec 18, 2003 | 04:08 PM
Blakeya's Avatar
Blakeya
What make mate. Toying with the idea of fitting the Deflex ones as they are one hell of alot cheaper.
Andy
Old Dec 18, 2003 | 04:43 PM
B11GNS's Avatar
B11GNS
Got mine from Rally Design, i have their catalogue which i can bring in tomorrow if you like or you can ring them on 01795 531871. They are very reasonably priced.
Old Dec 18, 2003 | 09:13 PM
richm's Avatar
richm
Andy,
I've got a complete set of Deflex poly's in the back of my 4x4.
I have got poly's in place of the original shericals (got a second pair of arms powdercoated, so fitted polys) and it all works just fine. I'd guess though that it was the beam mount donut bushes that made the biggest difference.
Old Dec 21, 2003 | 07:39 AM
STUCOS's Avatar
STUCOS
only replace rear beam bushes with genuine ford items,if fitting polly ones these will last no time at all,ford bushes ar competition quality so why change.
cheeRS stu
p.s. i know there dear i just bought a full set for mine
Old Dec 21, 2003 | 12:06 PM
swerv's Avatar
swerv
rear beam -poly
rear arms - standard ford
Old Dec 22, 2003 | 05:59 AM
Blakeya's Avatar
Blakeya
Thanx for the advice chaps. Heva now bought OE for items for the rear arms. Not the cheapest as you say but hopefully, along with the Rear beam poly bushes should tighten everything very nicely indeed.
Andy
Old Dec 22, 2003 | 06:31 PM
swerv's Avatar
swerv
you made the right choice imo
Old Dec 22, 2003 | 07:31 PM
how long does it take to change all the rear bushs
Old Dec 22, 2003 | 07:44 PM
RSrussell's Avatar
RSrussell
depends if it takes you 3 weeks to jack the car up, remove the wheels and shocks (like me )
I'm having a rest now and I might remove the beam and arms over the next month
Old Dec 24, 2003 | 11:50 AM
very good but how long in hours
rex647
Mar 6, 2022 06:20 AM
155lee
Oct 27, 2015 04:55 AM
gcfcos
88
Sep 15, 2015 03:48 PM
rsturbo27
Sep 5, 2015 05:08 PM
