dump valve on wrong?
Old May 24, 2006 | 09:51 PM
fiestaturbo1984's Avatar
fiestaturbo1984
Default dump valve on wrong?
call me thick(please dont) but ive just brought a frst and the bloke i got it off was gormless. he thought that turbo stall was the sound of the dump vavle. anyway my query is, the car has a dump valve on the crossover but there is no pipe going to inlet, so am i right in guessing im loosing most of my boost
Old May 25, 2006 | 10:02 AM
bud-weis's Avatar
bud-weis
Football Cwazy
you mean there is no vacuum pipe to the inlet?
you shouldn't be loosing boost as the dump valve should be shut, use a blanking plug if you are worried about it
Old May 25, 2006 | 10:20 AM
fiestaturbo1984
i would but the dump valve is welded to the crossover. also it sounds like i have a major boost leak somewhere and its not pulling very well but still flutters like a bitch? im baffled
Old May 25, 2006 | 10:33 AM
bud-weis's Avatar
bud-weis
Football Cwazy
ok, have a look for air leaks around the inlet manifold, the brake servo pipe is a common place where it connects
Old May 26, 2006 | 10:58 AM
Stu @ M Developments's Avatar
PassionFords Creator
The dump valve will elak if there is no pressure signal pipe to teh top of it.
Old May 26, 2006 | 11:12 AM
boost mad's Avatar
boost mad
can u take a picture of it mate ?
Old May 26, 2006 | 01:14 PM
sufsRS's Avatar
sufsRS
simple solution throw it in the bin, and buy this off me
Old May 26, 2006 | 04:57 PM
fiestaturbo1984
sounds good how much matey?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
