cosworth turbo types
Old May 15, 2006 | 11:18 AM
rinus_2005's Avatar
rinus_2005
Default cosworth turbo types
Hi, i'm a relative new to the cosworth scene, and a bit confused.
As far as i'm aware that originally sierra/saph use a T4 or T3 turbo, and the escort a T25 and T35 turbo. So where do the T3/4 T34 and T28 come into this picture? Because these are the turbo's people are talking about.
thanks,
Old May 15, 2006 | 11:24 AM
stonehavencossie's Avatar
stonehavencossie
As far as i believe;
3 door/ 2wd & 4wd saff all use the T3
Escort big turbo - T34
Escort Small Turbo - T28
Only the RS500 had a T4 as standard
T35 and T34 are the same turbo. Some people just use different names. There is 3 different housings for the T34/35 (.48 .55 .63)
Hope this helps
Old May 15, 2006 | 11:28 AM
EssexBoyRacer's Avatar
EssexBoyRacer
2wd T3 had a 50 trip compressor inlet and 4wd had a 60 trim. Im not sure about any others.
Old May 15, 2006 | 11:56 AM
Stu @ M Developments's Avatar
PassionFords Creator
All 2wds = T3 50 trim with .48
4wd safs = T3 60trim with .48
Escort Cos Marelli = T34.63 rear.
Escort Cos Ford = T28.
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
knight19770
Aug 4, 2015 12:36 PM
