90 spec fuel tank ... ?????
Old May 14, 2006 | 04:17 PM
rst_cabby's Avatar
rst_cabby
Default 90 spec fuel tank ... ?????
Does anyone know if i can use the 90 spec tank from a xr3i - What i want to do is use a 89 turbo loom with fuel gauge etc on dash but want to retain the 90 spec tank with has the feul pump on the inside - is there anything i need to know with regards to wiring being different - have a complete 90 spec loom & 89 spec turbo loom plus both tanks & all fuel lines etc...
Any help appreciated .....
Old May 14, 2006 | 04:49 PM
SafeChav's Avatar
SafeChav
The plugs are different for the intank senders obviously because the tank is internal. And also they have extra wiring for the inertia switch.
Theres nothing to stop you modifiying the wiring on the turbo loom (simple to do) but the XR3i pump in the tank won't be up to the job. I personally think you would do better to retain your external pump......
Old May 14, 2006 | 05:20 PM
rst_cabby's Avatar
rst_cabby
Ah - THANKS FOR THAT - is was just a idea - oh well have to buy a new tank then 89 one as the original is a bit ropey.
Old May 14, 2006 | 05:21 PM
SafeChav's Avatar
SafeChav
Can't you find a good second hand one? Same as XR3i
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
155lee
Oct 27, 2015 04:55 AM
Kam B
Sep 24, 2015 10:40 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
