engine knocking
Old Aug 5, 2004 | 09:05 PM
jonseyrs's Avatar
jonseyrs
Default engine knocking
bottom end knocks when cold and goes away after warming up. Saph cossie is running 400bhp. Is this normal? Is it signs of a bottom end rebuild required? Does not use oil or water, head sounds mint.The knocking goes away after about 5 minutes, it is quite loud, as loud as a diesel.
thanks
Old Aug 6, 2004 | 07:22 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
I presume you are have a 2wd mate. What you are hearing is piston slap. Yes it is normal on a 2wd. the noise is the piston hitting the bore and the reason it goes away when the car has warmed up a bit is coz the piston has expanded a bit to fit the bore properly. The 4x4 pistons dont knock because they have a off-set gudgeon pin which keeps the piston straight.
Thats how i understand it anyway. Im sure if im wrong someone will tell me, but that is what is happenin to your car.
Doesnt nessaceraly need a rebuild. HTH
JoeyBoyden
Jan 4, 2024 02:36 PM
Chas
Sep 21, 2015 08:57 PM
adam151082
Aug 30, 2015 08:34 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
