cossie hot start prob
Old May 9, 2006 | 04:13 PM
cossiegreg1's Avatar
cossiegreg1
Default cossie hot start prob
right the saff has had every new sensor just had a rebuild and has even had another ecu in.the bugger still wont start up when it has been running.it is doing my head in.but if you bump start it, it fires straight away.im thinking now that it must be a dodgy wire in the loom any ideas?
Old May 11, 2006 | 04:28 PM
cossiegreg1
anyone??
Old May 11, 2006 | 04:32 PM
boost mad's Avatar
boost mad
i had something like this on my saph...... neverfound out the prob, but i did find out how to start it.....
i had a switch for the fuel pump in the car. make sure its on, start turning the car over, switch the switch off for a second ( whilst still turning car over ) then switch it back on and it started
if u get that
the only thing i could hink of is vapour lock
Old May 11, 2006 | 05:33 PM
cossiegreg1
cheers mate it sounds like a good idea.
Old May 11, 2006 | 05:54 PM
boost mad's Avatar
boost mad
let me no if it works
Old May 11, 2006 | 06:47 PM
cossiegreg1
ill let the world know cos its driving me mad
Old May 12, 2006 | 09:22 AM
IANS2RST's Avatar
IANS2RST
do a compression test, I had the exact same problem on a 2wd and it turned out a couple of vales were not sealing correctly
Old May 12, 2006 | 03:47 PM
lawnsy's Avatar
lawnsy
mmmmmmmmmmmmm worth a try pop round somtime it will not take long........................did he have the valves out??????
Old May 12, 2006 | 04:05 PM
IANS2RST's Avatar
IANS2RST
its also possible to slightly bend the valves when re fitting the head
Old May 15, 2006 | 06:31 AM
boost mad's Avatar
boost mad
anything yet mate ?
Old May 15, 2006 | 11:29 AM
stonehavencossie's Avatar
stonehavencossie
I had the same problem a few years back. Turned out to be something to do with the crank/sensor ?
Old May 15, 2006 | 06:47 PM
cossiegreg's Avatar
cossiegreg
the crank sensor has been changed although it wasnt a brand new one, boost madthe car is still sitting there with a flat battery,no interest at the minute with it,one night this week i think ill put a battery on and see my mate to do a compression test.
Old May 15, 2006 | 08:43 PM
lawnsy's Avatar
lawnsy
just give me a shout
Old May 19, 2006 | 12:09 PM
boost mad's Avatar
boost mad
anything ?
Old May 19, 2006 | 08:02 PM
cossiegreg1
boost madputting a battery on in the morn and see how it goes. [
Old May 20, 2006 | 04:20 PM
thegrimreaper's Avatar
thegrimreaper
i have exactly the same problem (except my car isnt the same) mine is a xr2i running a tall block conversion , i dont know how ur car engine bay is laid out but on mine the starter is close to the manifold/downpipes and i have been told the heat from the exhaust affects the performance of the starter motor, could that be an issue with urs, i have just ordered a starter motor heat shield to see if that solves it??
Old May 21, 2006 | 03:02 PM
vinnyd's Avatar
vinnyd
Default re need engine bay loom
boost mad
hey are u still breakin the cossie?? i need a 2wd engine bay loom..
pm if you still have it many thanks
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
