Fuel Pump URGENT
Old May 6, 2006 | 05:19 PM
Shandy-Ade's Avatar
Shandy-Ade
Default Fuel Pump URGENT
Can anyone tell me how to change the Fuel Pump on a FRST?? and if it's difficult or not
Thanks
Old May 6, 2006 | 06:05 PM
SafeChav's Avatar
SafeChav
Tank off, sender out, basically
4 bolts i think holding the tank in, filler neck is usually fun and games
Old May 6, 2006 | 06:48 PM
mercury grey minter's Avatar
mercury grey minter
Drop the tank out then with a hammer and flatblade screwdriver tap the securing plate anti clockwise then extract the pump About 1 and half hours in & out.
Old May 6, 2006 | 06:57 PM
Shandy-Ade's Avatar
Shandy-Ade
Thanks guys , 1 more question, will an xr2i fuel pump be the same? as i can get 1 from the scrappy tomoz
Old May 6, 2006 | 07:15 PM
SafeChav's Avatar
SafeChav
I dont know it for fact, but apparently the turbo ones have a higher flow rate and have "turbo" stamped on them?
Old May 7, 2006 | 10:24 AM
Shandy-Ade's Avatar
Shandy-Ade
Can anyone tell me how to remove the fuel line from the fuel pump? it has a white clip thing on it if that helps, i've been struggling for half hour
Old May 7, 2006 | 10:31 AM
SafeChav's Avatar
SafeChav
I could tell you, but i think you should have to break a few like i did learning how to do it
No pushy type things on the side then?? As you look at the end theres 2 little cut outs around the pipe yeah?
Old May 7, 2006 | 10:41 AM
Shandy-Ade's Avatar
Shandy-Ade
Yep 2 cut outs around the edges...anymore clues??
Old May 7, 2006 | 10:45 AM
Shandy-Ade's Avatar
Shandy-Ade
Old May 7, 2006 | 10:53 AM
SafeChav's Avatar
SafeChav
Right, try and leave the sender in the tank if u can, if not put it between your legs (!!!! )
Get 2 small screw drivers and push them in the gaps on the clip, and gently push back, it should push the clip in and slide it back off the pipe
Don't try and push the clips and pull the pipe, it doesn't work aswell
Old May 7, 2006 | 11:43 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
The white plastic clip needs to be broken to be able to take it off.
Old May 7, 2006 | 12:17 PM
SafeChav's Avatar
SafeChav
NEVER!!!!!!!!!
I've removed loads without breaking it, thats what the cut outs are there for........
Old May 7, 2006 | 01:35 PM
Versus_Creations
Ask me a question!
lol..
just break it off mate makes it easy to take off the pipe and fit back on.
Most of the fuel line clips do not have the plastic cover anyway.
Old May 7, 2006 | 01:39 PM
SafeChav's Avatar
SafeChav
lol..
LOL, they a bit too fiddly for ya
I had to break the one off my cabriolet though.........
Only because there was no little notches at all though Makes no difference i suppose but theres more chance or mositure getting in and rusting the pipe over many years
Old May 7, 2006 | 01:50 PM
Versus_Creations
Ask me a question!
Originally Posted by safechav
Whats the smileys all about?
Im trying to help somone with the easiest way to remove a clip for the "normal" type of person who does not know the in's and out's.
IMO removing the saftey clip, then pushing the pipeclip against the plastic is the easiest way.
OK! SO no need to be sticking your tounge out!
Old May 7, 2006 | 02:07 PM
SafeChav's Avatar
SafeChav
Fuck sake man you throw your toys out easy don't you
Ady Si: Sorry mate ignore me i know nothing, snap the plastic cover off save yourself 2 minutes
Old May 7, 2006 | 02:53 PM
Shandy-Ade's Avatar
Shandy-Ade
I saw your reply before the other mate, and managed to get it off i owe you a drink big time thanks mate
Old May 7, 2006 | 02:57 PM
SafeChav's Avatar
SafeChav
That must make both of us above average then
Did you get it off ok??? The trouble i had with them before i learnt how to do em LOL, strong fuckers theyve got a strong bite on them
Old May 7, 2006 | 03:48 PM
Shandy-Ade's Avatar
Shandy-Ade
Yeah took some forcing, but least it didn't brake, a good half hour i was looking at it wondering what to do
Old May 7, 2006 | 04:07 PM
SafeChav's Avatar
SafeChav
Hmmmmmmm i know that feeling The more you do it the easier it gets. Just when i thought i had it down to a fine art, my cabriolet sprung a leak on the pipe going to main fuel line so i jacked it up thinkin this'll be easy and there was no notches to stick anything in Had no option but to pry the cap off then
Glad you sorted it Has the pump got turbo stamped on it out of interest?
Old May 7, 2006 | 04:33 PM
Shandy-Ade's Avatar
Shandy-Ade
The old pump had a sticker with TURBO wrote on it, this xr2i one has nothing, i can tell the difference tho as the car is definantly slower, i just dont fancy going thru all that again to put a turbo one back in
Old May 7, 2006 | 05:23 PM
SafeChav's Avatar
SafeChav
Ah ok i knew it was something along the lines of having turbo on it.
Oh dear..........i didn't realise u had fitted the N/A pump in there after i said they are different, i wouldn't get boosting it too much if i were you.........if you plan to keep the car you will HAVE to fit the proper pump
Old May 7, 2006 | 05:39 PM
Shandy-Ade's Avatar
Shandy-Ade
Just been offered one for £25 so i think i'll snap his hand of at that price and yes i'll have to go thru that all again
Old May 7, 2006 | 06:03 PM
Old May 7, 2006 | 06:25 PM
SafeChav's Avatar
SafeChav
You LOVE it
Are you keeping the car for a while? U can get uprated ones for about £95, and that will see you for high power....
Old May 7, 2006 | 06:30 PM
Shandy-Ade's Avatar
Shandy-Ade
You LOVE it
Nah hope not to keep it, withinthe next few weeks i'll be putting it up for sale
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
