cossie, running lumpy when cold
Old Apr 30, 2006 | 09:05 AM
ian rst's Avatar
ian rst
Default cossie, running lumpy when cold
It only does it really when cold, its hard to explain but it coughs and splutters a bit until its warm any ideas what this could be??? Its a an esc cos. I have changed the plugs i havent changed the leads but there not that old really.
Old Apr 30, 2006 | 09:17 AM
330bhpcoz's Avatar
330bhpcoz
my sapph does the same
Old Apr 30, 2006 | 09:26 AM
KSA-Cossie's Avatar
KSA-Cossie
Plug gap ?
Old Apr 30, 2006 | 10:42 AM
cos jon's Avatar
cos jon
Mine also does this, even after all the sensors were replaced !! hope someone can help ........
Old Apr 30, 2006 | 04:25 PM
ian rst's Avatar
ian rst
It could be plug gap, but why would it do it only when cold?
Old Apr 30, 2006 | 05:02 PM
rapidcossie's Avatar
rapidcossie
havent seen any cossies or old cars in general that aint rough for a while when started from stone cold...
Old May 3, 2006 | 04:04 PM
adam rs's Avatar
adam rs
Had same problem with mine.Does it stop when you disconnect the idle valve? I used to do this with mine to cure it, but in the end it was the blue temperature sensor at the back of the head.Changed that and it never did it again!
Old May 5, 2006 | 11:47 AM
330bhpcoz's Avatar
330bhpcoz
my plugs are set to 6and im running 330bhp etc
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Adam-M
Aug 26, 2015 05:53 PM
kosienutter
31
Aug 22, 2015 09:55 AM
The Enigma
13
Aug 20, 2015 09:38 PM
