MK4 XR3i MFi twin carb conversion - help !!!!
Old Apr 25, 2006 | 09:55 PM
slowwalrus's Avatar
slowwalrus
Default MK4 XR3i MFi twin carb conversion - help !!!!
Hi, I have a MK4 XR3i that I use for track days and have always wanted to convert to twin carbs can anyone advise what I need and how difficult it is to convert ? is it twin 40 webers that I will need - any help will be appreciated !! Thanks Marc
Old May 16, 2006 | 03:14 PM
paconassa's Avatar
paconassa
I think the only challenge is fuel pressure (mfi's to high for carbs...)
you'll need a fuel regulator to lower fuel pressure or a fuel pump from a xr3...
everthing is tried and tested stuff, shouldn't have any trouble!!!
good luck!
Old May 16, 2006 | 03:50 PM
SafeChav's Avatar
SafeChav
You can use electric pumps with twin carbs can't you????
My mate had a MK2 Astra 16v on throttle bodies and that retained the electric pump???
Old May 16, 2006 | 04:25 PM
jonnyturbo's Avatar
jonnyturbo
most tuners will recommend replacing the fuel pump for an uprated one. i had twin 40's with a facet red top pump, and malpassi fpr. i recommend them as best on market.
are you also getting any head work done? because twin 40's only really benefit from a head with larger ports and a higher profile cam etc. ive seen xr2's etc with only very minimal gains after installing twin carbs because the standard head was restricting the flow.
I also recommend taking them to an expert to get them properly jetted and set up for your engine because that is some fiddly shit.
Old May 16, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
Well well well, long time no abuse......where you been hiding, in that pikey wagon???
What hes saying, as i understand it, is he needs to ditch the electronic pump an XR3i has, and get an XR3 pump (manual pump). READ more carefully
Old May 16, 2006 | 04:41 PM
jonnyturbo's Avatar
jonnyturbo
Do you mean mechanical pump?
twin 40's do require an electric fuel pump, mechanical pumps dont supply enough pressure, but you also need to regulate that pressure so that you get the right flow to the jets
Old May 16, 2006 | 07:37 PM
SafeChav's Avatar
SafeChav
I know that you plank
But check what was written:
good luck!
Now take it back or im not coming to Ford Fair in your sweaty transit
Old May 16, 2006 | 08:35 PM
jonnyturbo's Avatar
jonnyturbo
oh ive missed the fun of destroying other peoples posts
Old May 16, 2006 | 08:42 PM
SafeChav's Avatar
SafeChav
Not only have you missed that, but you've avoided answering the question i asked aswell
I win
Oh.......and
Old May 16, 2006 | 09:21 PM
jonnyturbo's Avatar
jonnyturbo
erm DUH....... need to get her ready for the road trip
Old May 16, 2006 | 09:40 PM
SafeChav's Avatar
SafeChav
LOL, very funny
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
