mk3 fiesta headlight problem.
Old Apr 23, 2006 | 09:41 PM
nathankershaw's Avatar
nathankershaw
Default mk3 fiesta headlight problem.
I have an h reg mk3 Fiesta. The headlights will work on sidelights ok but when i twist the stalk one further the lights go to virtually nothing instead of going to main beam. If i push the stalk forward the lights work on full beam no probs.
I have checked the bulbs, they're ok and the fuses, they're ok. Is there a common fault with the switch or anything?
Thanks, for any help,
Nathan.
Old May 17, 2009 | 07:24 PM
matty325's Avatar
matty325
hi nathan did you sort your lights, my series 2 rs turbo has the same problem i came across your post looking for ideas ,cheers matty
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
TPM961
Jan 15, 2018 10:50 AM
liamT74
Sep 23, 2015 10:24 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Brian
Sep 11, 2015 08:06 AM
