Cam cap bolt/nut question
Old Aug 3, 2004 | 01:53 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Cam cap bolt/nut question
I have a 4x4 sapphire cosworth and dismantled the head a while back. In doing that, I fu**ed a bolt that holds the cam cap nearest the pulley (one of two big ones at the front of the head, not the eight little ones).
The bold had an allen key head on it, which I ended up drilling out cos my allen bit slipped in it.
I have just tried to order a replacement, but no-one has ever heard of an allen bolt fitting for this, according to microcat, it should be a stud, washer and nut fitting.
Checked escos diagrams too and those show the same stud/washer/nut combination.
I am a little puzzled as to what could have happened there, any of you seen this before ?
Thanks in advance.
Greg
Old Aug 3, 2004 | 04:14 PM
Cosworth4388's Avatar
Cosworth4388
m8 all the ones i have seen have allen key type bolts on the caps nearest the pullys
and nuts and washers on the rest!
Old Aug 3, 2004 | 06:51 PM
rocar's Avatar
rocar
The No:1 and No:6 cam main cap (holding the ball bearing and oilseal are stud and nut on all 2wd and M6 allen bolts on all 4wd.
Roger
Old Aug 4, 2004 | 07:50 AM
frog's Avatar
frog
Cheers, just to be sure, this is what I am talking about:
and
Old Aug 4, 2004 | 07:56 AM
rocar's Avatar
rocar
Yes those are the 4x4 caps,You can buy high tensile allen bolt.
Roger
Old Aug 4, 2004 | 11:54 AM
frog's Avatar
frog
Cool - on the phone now.
Old Aug 5, 2004 | 09:50 PM
frog's Avatar
frog
All sorted, the pictures on microcat are wrong, but when you try and order the stud, it tells you can't order anything else that's related to it - the allen bolts are what you get when you order the studs.
Old Jun 23, 2012 | 08:53 PM
andycos's Avatar
andycos
Ive dug this old thread (excuse pun) up as im after some info on this m6 bolt.
Does anyone know what the pitch thread is for it ?
As ive got a cam cap bolt that has that feeling of stripping its thread if tightened any further,and its not that tight now
I'm thinking of putting a helicoil in,but want to order the right size before i pull it apart.
Any help appreciated
Old Jun 28, 2012 | 07:12 PM
opposite lock's Avatar
opposite lock
How much do you tighten these upto?
Old Jul 25, 2012 | 10:31 PM
andycos's Avatar
andycos
Well as no one new the size i had to take a bolt out,measure it and helicoil it.
Also fitted new cam oil seals,and no more leaks now !
IainRS1700T
Sep 25, 2015 06:44 AM
biggiejody
Sep 19, 2015 10:25 AM
shoppel
Ford Escort RS Cosworth
Sep 17, 2015 09:03 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
