Cometic Rocker cover gaskets
Old Apr 22, 2006 | 08:17 PM
PeterLucas's Avatar
PeterLucas
Default Cometic Rocker cover gaskets
Got a leaky rocker cover gasket, possibly the half moon seals or the gasket (all new). Didnt put any sealant on them because I may want to have the rocker cover off for various reasons and cometic gaskets are reusable . . . .
Guess I have no option but to use gasket sealant and replace the gasket evertime??
Old Apr 22, 2006 | 08:23 PM
CosKev3's Avatar
CosKev3
Cometic gaskets are re-usable m8,have used one three times
As long as you don't over tigthen it
The only place you need sealer is where the half moons meet the rocker gasket,just a small blob on the joint
Old Apr 22, 2006 | 08:33 PM
PeterLucas's Avatar
PeterLucas
Thought I should have used a bit there!
Nice one
Old Apr 22, 2006 | 09:05 PM
Toe Knee's Avatar
Toe Knee
out of interest, which sealants best cos theres fookin millions out there now
Old Apr 22, 2006 | 09:30 PM
trevCOSS's Avatar
trevCOSS
when I went to buy a cometic rocker gasket from woodford Simon advised me against it as he said he has had nothing but trouble with them leaking, put a standard one on and had no problems, and have had the cover off a few times and not replaced and it still doesnt leak
Old Apr 22, 2006 | 11:16 PM
notSteveS2's Avatar
notSteveS2
peterlucas u got a cossie mate?
if RS Turbo id use a 1.8CVH 1...
but judgin by the replies u got cossie.. in that case id use Standard 1.
Old Apr 23, 2006 | 12:02 AM
SafeChav's Avatar
SafeChav
Personally i don't think you can get any better than a Genuine Ford rocker gasket. Most of the time they leak because 3rd party gaskets have been used, and when tightened it bends the rocker cover.....
There is a bit of a nack to doing them but i have fitted a cheapy £2 rocker gasket before now and had the cover off a few times with no leaks. Put your rocker cover on a flat surface and u will more than likely see its no longer "true"
Old Apr 23, 2006 | 12:20 PM
costina's Avatar
costina
Live long and prosper!!
I use a grey loctite sealer availible at Halfords find that is very good,and have used it instead of a gasket on my saff(Most new engines which are alloy use this type of sealer everywhere except head,exhaust and intake).
Don't forget to reseal under front cam caps because this can leak too.
Cometic cossie rocker gaskets are very good i have one on my tina No leaks,no probs,no worries
And i've had gasket off four times,just picked of sealer off half moons and edges of gasket and resealed and used it again
Use a torque wrench and start middle outwards.
Old Apr 23, 2006 | 12:23 PM
SafeChav's Avatar
SafeChav
Ah right so we're not talking about CVH's here???
Old Apr 23, 2006 | 12:25 PM
rssapphowner's Avatar
rssapphowner
i use flange sealant its the tits and ford recomend it
Old Apr 23, 2006 | 04:10 PM
b14dave's Avatar
b14dave
i gto a cometic head gasket which is supposed to be re-usable and some guy of here told me they aint
Old Apr 23, 2006 | 04:12 PM
notSteveS2's Avatar
notSteveS2
i think the thread is bout rocker cover gasket matey...
sorry if u already new that and was just raisin a point!
Old Apr 23, 2006 | 04:19 PM
b14dave's Avatar
b14dave
its still a cometic gasket aint it and i was just stating that some guy said cometic gaskets are not re-usable wheres i assumed they where
Old Apr 23, 2006 | 05:10 PM
notSteveS2's Avatar
notSteveS2
i see!
Old Apr 23, 2006 | 06:07 PM
rssapphowner
cometic head gaskets are re-usable and so are the rocker covers
Old Apr 23, 2006 | 07:09 PM
costina's Avatar
costina
As above i've one on my saff (head gasket) and they are re-useable
most triple layer gaskets are, the best being a WRC one but it cost's a lot only any good if you have over 400 bhp!
Old Apr 23, 2006 | 07:36 PM
nicksaph's Avatar
nicksaph
i have got a cometic cam cover gasket on mine! no leaks been off a couple of times.
bought it from pj motorsport and asked them about being reusable and they said yes! and when fitting smear a thin layer of grease on the faces to stop the gasket sticking
Old Apr 23, 2006 | 08:39 PM
PeterLucas's Avatar
PeterLucas
Yep cossie steveS2
Will use a dash of sealant then (ive used Locktight goldseal for a few of the other bits, that seams spot on!)
Will check the cover for warping as well then, ta everyone
Pete
Old Apr 24, 2006 | 01:21 PM
notSteveS2's Avatar
notSteveS2
Mark RS
Mar 5, 2021 06:08 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
deathrider666
Sep 28, 2015 06:12 PM
