back end goes light under braking
Old Apr 21, 2006 | 10:16 PM
mmanse's Avatar
mmanse
Default back end goes light under braking
fitted 330mm disc's with ap 4 pot caliper's and the brake's are
great but the car goes very light on the rear and tries to step out
under hardish braking any idea's how to cure this please
thanks in advance
Old Apr 21, 2006 | 10:37 PM
Azrael's Avatar
Azrael
If it wasn't happening on standard brakes it's probably not really rear becoming light but incorrect brake balance. Try tweaking with different rear pads.
Dos it lock rear before the fronts?
Old Apr 22, 2006 | 07:48 PM
mmanse's Avatar
mmanse
no, just goes light and try's to go sideway's so you have to steer in to it
can be scary
Old Apr 23, 2006 | 02:01 AM
Azrael's Avatar
Azrael
It wasnt doing it before brake upgrade? Quite impossible....
I would think about lowering back end a bit a bit then, maybe stiffer front end suspention hmmm...
Old Apr 24, 2006 | 05:45 PM
mmanse's Avatar
mmanse
does sound like a plan as the the front does nose dive and feel's like the rear lift's will have a play with the shock setting's and see what happen's
Old Apr 24, 2006 | 08:21 PM
Azrael's Avatar
Azrael
Shocks themselves won't help I'm afraid. It's rather in spring rates.
Old Apr 24, 2006 | 10:10 PM
NUTS RuS's Avatar
NUTS RuS
Try re bleeding the system
Old Aug 1, 2008 | 11:02 PM
marco polo's Avatar
marco polo
thanks in advance
in simple terms your front suspension is too soft
Old Aug 2, 2008 | 03:29 AM
Vic's Avatar
Vic
what lb springs are you running on both the front and the back?
Old Aug 2, 2008 | 07:29 AM
nobbie_b's Avatar
nobbie_b
Default could
could slip a set of coil overs on there then you can adjust them to how you want. it could have been doing it before but not as much then wen you uprated the brakes they are now working a lot better so you notice it a lot more now
Old Aug 2, 2008 | 01:27 PM
Aaroncast's Avatar
Aaroncast
Talking
-bad Bleed And Or Also Needs Bias Valve--------
Forget Springs Etc Etc------it Wasnt Like This Before Brake Change Was It????
Must Be The Brakes Then!!!!!!!!!!!!! Try Changing Pads!!--lol At Around £50-£60 Plus How Many Sets To Get It Right Do You Think-------????lol
I Can Send You Six Sets That Wont Make A Bit Of Difference!!!!!!!!!!!!!!!
Paypal Me £360 Now Thanks And The Same Every Month Till We Get It Something Like---------------pads!-o'er
Old Aug 2, 2008 | 02:24 PM
nobbie_b's Avatar
nobbie_b
it wasnt like it before but were the brakes as good as they are on the front now since the upgrade, he has done a big upgrade on the brakes from standard so it will change it a lot
Old Aug 2, 2008 | 10:30 PM
s1cab's Avatar
s1cab
sounds like you need a bias/proportioning valve !! i had the same problem. are the rears locking up and just trying to slide out??
jessie_rs
11
Jun 3, 2019 04:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
