low voltage at fuel pump?
Old Apr 18, 2006 | 01:29 PM
danuk's Avatar
danuk
Default low voltage at fuel pump?
hi
on my saff cos i was told i had low voltage at the fuel pump when i had it set up and rollin roaded.
can anyone help, i cant seem to trace where i have to run the wires to the pump from?
thanks
Old Apr 18, 2006 | 01:31 PM
SafeChav's Avatar
SafeChav
What is the voltage firstly?
Old Apr 18, 2006 | 01:44 PM
danuk's Avatar
danuk
with the engine running it was about 7v
Old Apr 18, 2006 | 01:47 PM
SafeChav's Avatar
SafeChav
Errrrrrrrrrr, somethings not right there......im surprised the pump even works I'm totally up on cossie's but i think the pump relay is in the fusebox, trace back to there first and see if the voltage is as low there?
Old Apr 18, 2006 | 01:50 PM
danuk's Avatar
danuk
found the relays but cant figure out wich one is for the fuel pump?
Old Apr 18, 2006 | 01:51 PM
SafeChav's Avatar
SafeChav
I THINK they are pinky/purple like RST ones.
Old Apr 18, 2006 | 01:58 PM
danuk's Avatar
danuk
cheers mate
ill check it out
Old Apr 18, 2006 | 02:09 PM
CosKev3's Avatar
CosKev3
If its a 2wd saph it is a yellow relay with a yellow plug on it
Its behind the glove box on the passenger side of the car
Not sure about 4x4 saphs though
7 volts is well low,be carefull using it with that voltage at pump
There is a thread in the techcnical essays forum on re-wiring your pump m8
Old Apr 18, 2006 | 02:10 PM
SafeChav's Avatar
SafeChav
There we go someone that knows what they are on about with cossies
Old Apr 18, 2006 | 05:16 PM
danuk's Avatar
danuk
thanks guys
much apreciated
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
