Running problems with S1
Old Apr 12, 2006 | 09:16 PM
LouRS's Avatar
LouRS
Default Running problems with S1
Help - our S1 is not happy.
I was told it could be the fuel relay so we have replaced that and its still not happy. It will start, run quite happily for 10-15 minutes then die. Sometimes the fuel pump doesn't start up I.E doesn't make the connection buzz. We know it something to do with this but its not always getting power so willn't start.
Please help we are running out of ideas as to what it could be
Tnx
LouRS
Old Apr 12, 2006 | 09:36 PM
SafeChav's Avatar
SafeChav
Does it always prime (you have to wait 5 secs after switch off to make it prime)
Or do you mean after 15 mins the fuel pump stops running when you are cranking over?
Old Apr 18, 2006 | 01:28 PM
LouRS's Avatar
LouRS
The fuel pump just stops working but if you play with the wires under the pedels it helps and the car might start again. Some1 has told us that the alarm could be interferring with the pump doesn't help as the last owner was a slight cowboy!!!
Old Apr 18, 2006 | 01:30 PM
SafeChav's Avatar
SafeChav
Its fairly common for the wires on the fuel pump to take a hammering, the connections on the relay work loose and cut out. Its going to be trial and error by the sounds of it
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
