SHOULD I CHANGE THE OIL PUMP ?
Hi, can anyone tell me at what stage of tune should you uprate the oil pump on a cosworth, it had a full rebuild to a standard stage one, 3 years ago and has done little mileage since then but since then I have gone to a stage 2 about 300 to 320ish BHP,
so I was wondering if it is worth uprating the pump, as I will be taking the sump of this weekend to fix an oil leak anyway. Cheers!
NO replys yet I suppose all the experts are at the ring "lucky feckers"
seious though if someone can answer the ubove, as I need to order one soon so I can get started,
CHEERS in advance
CHEERS in advance
Football Cwazy
if you have good oil pressure and flow, and are suffering from no problems, then i don't see any benefits TBH.especially at just stage 3 power, however a new part is always a good thing
JK12
33
26-04-2021 12:09 PM
