gearbox or clutch ?????????
right peeps can i pick ur brains had a new clutch kit fitted 2 month back since then a problem has started and it is just getting worse and worse and it goes like this most of the time in fith on motorway or such ill put my foot down to over take the boost comes on revs pic up but no drive it dont accelerate now it started doin it in other gears !!!!!
now i have been told that it could be that they maneged to pop a seal when they where takin the box out and its now sprayin oil over the clutch ??
i dont pretend to know anything about gearboxes and wondered if u lot could help
if its popped a seal and spraying oil then you will notice it coming out of the bellhousing, jack it up and run it for a bit n see if it drips form there....
No need to be in gear or owt as the crank/clutch assembly still spins in the bellhousing in neutral so the oil should be leaking without moving in theory
hope that helps
Dan
hope that helps
Dan
