1.8 zvh timing
Old Mar 13, 2006 | 07:14 PM
robbob's Avatar
robbob
Default 1.8 zvh timing
GETTING REALY STUCK NOW ON HOW TO TIME UP MY ZVH HAVENT GOT A LOWER CAM BELT COVER CANT GET ONE TO FIT SO NO MARKS TO GO OFF IS THER ENY OTHER WAY I CAN TIME IT UP CHEERS ROB
Old Mar 13, 2006 | 07:24 PM
nik t's Avatar
nik t
only way i would think is to get the engine on top dead centre and mark the front pulley.tipex is good and then make a pointer and bolt it on the block. can use abit of welding wire or coat hanger.again bolt it to the block. hope this helps
Old Mar 13, 2006 | 07:26 PM
robbob's Avatar
robbob
CHEERS MATE THAT WAS HELPFULL HOW ACURATE DO YOU THINK IT WILL BE CHEERS ROB
Old Mar 14, 2006 | 09:10 AM
nik t's Avatar
nik t
long as the pointer is stable and good clear marks will be spot on son
Old Mar 14, 2006 | 07:33 PM
cossie604's Avatar
cossie604
There's a good casting in the sump if you look underneith, to use as a marker point. Get number 1 to tdc using a dial gauge...you'll find a dwell period of around 10degrees where the piston is on the edge of going up and then back down...true tdc in between these points. Then put a small cut /notch in the crank pulley aligned up to the casting in the sump (as you look at the pulley square on, the casting is around the 4 o'clock area...has been a few yrs since I last set up a zvh tho, but its around that side)
Stu.
RUBY123
Oct 22, 2023 12:04 PM
Porplus12
Sep 10, 2015 07:20 PM
base190380
Sep 3, 2015 08:32 PM
jonjg
Sep 1, 2015 03:46 PM
taylora1409
Aug 12, 2015 12:06 PM
