brake warning light
Old Mar 10, 2006 | 09:30 PM
angel 1's Avatar
angel 1
Default brake warning light
Had my brakes done a few weeks ago and the brake warning light hasn't gone off, so I went and brought some brake discs had them put on today and the light is still on. Can anyone help as this is really bugging me now.
Old Mar 10, 2006 | 11:21 PM
escortrsmatt's Avatar
escortrsmatt
what car?have you replaced the pad sensors?is there a special method of clearing the pad warning light?could it be your brake fluid level is low?could possibly be a wiring fault aswell.jus a few things to try
Old Mar 11, 2006 | 01:41 AM
SafeChav's Avatar
SafeChav
As above the car would help
Old Mar 11, 2006 | 03:46 PM
angel 1's Avatar
angel 1
Sorry my fault forgot to say. It is a mk1 mondeo 2.0i '93 Lreg.
Old Mar 11, 2006 | 05:42 PM
HORNETS7's Avatar
HORNETS7
if they haven't put in new pads with the sensors then it won't go out
if they have put pads on with sensors see if the multi pluds are plugged in should see some wires from each caliper to a multi plug this should be connected as well?
Old Mar 11, 2006 | 06:14 PM
SafeChav's Avatar
SafeChav
Which brake warning light is it just to clarify, is it the one thats like (!) or is it like a picture of a break pad? I didn't think the mondeo's had break pad wear sensors?
Old Mar 11, 2006 | 09:48 PM
angel 1's Avatar
angel 1
Yes it is (!) light and it has warning pad senors as it is the ghia model
Old Mar 12, 2006 | 01:58 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Check the handbrake switch as well as most use the same dash lamp when the handbrake is on.
Old Mar 12, 2006 | 11:54 AM
SafeChav's Avatar
SafeChav
As said then that light is in the brake fluid reservoir and handbrake circuit. Check the brake fluid level, check the cap is on tight, check the wiring plug is on properly and check the handbrake switch. I personally would say its the fluid sender or something thereabouts seeing as its only just happened after new discs.
Old Mar 16, 2006 | 02:14 PM
angel 1's Avatar
angel 1
Hi! safechav, just to let you know that it is the light with the brake pad on it, sorry for the confusion.
Old Mar 16, 2006 | 02:24 PM
SafeChav's Avatar
SafeChav
Ah, right ok I don't know a lot about the warning system on a Mondeo, does the light flash or just stay on permenantly?
Old Mar 16, 2006 | 05:54 PM
angel 1's Avatar
angel 1
Hi! the light is on permently and has been on since I had the brake pads done about two months ago
Old Mar 16, 2006 | 06:20 PM
SafeChav's Avatar
SafeChav
Hmmmm well they usually only flash if theres a fault on the circuit on the earlier models. At a guess i would say it sounds like they haven't changed the wear sensor (was the light on before u had them done). Some brake pads have the sensor built in and some have a little sensor which pushes into that pad.
Old Mar 16, 2006 | 06:56 PM
angel 1's Avatar
angel 1
Hi! They had the sensor already built into the pad when I got them and the connectors are all connected tightly.
Old Mar 16, 2006 | 06:58 PM
SafeChav's Avatar
SafeChav
I'm all out of ideas on that then..? I suppose there is a chance the pad could be faulty...which im sure u dont want to hear
Do you still have the owners handbook? Have a read through and see whats the lights do under different circumstances. I'm sure if there is a fault on the crcuit they flash for a set time when you turn the ignition and then go out.
Old Mar 18, 2006 | 02:24 PM
angel 1's Avatar
angel 1
Hi! the light that is on is the one with the brake disk and pad on it my fault was told the wrong warning light.
Old Mar 18, 2006 | 02:33 PM
SafeChav's Avatar
SafeChav
i thought u had already said that??
yatta
May 21, 2016 10:31 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
focus2351
Sep 9, 2015 09:33 PM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
