T5 Gearbox oil
Old Mar 8, 2006 | 03:36 PM
Cosworth-PT's Avatar
Cosworth-PT
Default T5 Gearbox oil
I had a 3 hours discussion today with my Ford Dealer about the T5 Gearbox Oil
Workshop gives Ford Spec: SQM-2C9010-A however FordEkat application says this Oil Spec was replaced by FINIS 5014519 and that is Ford Spec: ESP-M2C166-H
Is this correct???
Old Mar 8, 2006 | 04:16 PM
Alvyn's Avatar
Alvyn
I DONT know the numbers but USE Dextron 2 which is usually a red automatic transmission oil!
Old Mar 10, 2006 | 08:55 AM
Ridgey's Avatar
Ridgey
When i replaced mine with the red transmission stuff, i was expecting to refill with 2.6 litres (workshop manual detail), however i brely managed to get over 2 litres back in before it was overflowing.
Is this normal or have i done something wrong ???
I used bottom drain plug, and relilled using the plug above on the same side (drivers side).
Dave
Old Mar 10, 2006 | 09:10 AM
C0S_TURBO's Avatar
C0S_TURBO
Hi I replaced the gearbox on my 2wd saff at Christmas. I brought 3 litres of the Ford red oil (automatic transmission fluid). From empty I used just under 3 litres, but have since drained it and refilled it using the drain and fill plug you have mentioned and it took a lot less to fill. This is probably as the drain plug isn’t low enough to completely empty the box. Hope this helps.
Old Mar 10, 2006 | 10:45 PM
Cosworth-PT
Dave
I had to lower the car in a strange position to get it all out. After that I have used around 2.6 liters.
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Adam Graham
Sep 6, 2015 06:04 AM
