Smoke!
Old Mar 6, 2006 | 09:57 AM
JK's Avatar
JK
Default Smoke!
hey guys and girls!
bit of advise required!
Was out in the turbo cab yesterday as you do on a sunday! gave her a bit and notice a bit of smoke!
not allot just a little bit,
so i stopped and noticed when i rev the car, and the turbo spins in and then i take foot off, as the revs drop down a tiny puff of blue smoke comes out of exhaust. now i know its not bottom end etc as i have just had 3.5k rebuild done at PTS. would this be the turbo? i took pipes off and there is play in turbo as i can move up and down and left to right (is this norm?)
any ideas what the problem could be? would it be the turbo? (i did think turbo was white somke?)
Any ideas would be a great help people
Old Mar 6, 2006 | 10:48 AM
jonnyturbo's Avatar
jonnyturbo
blue smoke when lifting off the throttle points toward an aging or worn turbo.
if its white smoke, generally means head gasket is shot,
blue smoke when engine is under load is piston/ring/bore wear.
Old Mar 6, 2006 | 10:49 AM
jonnyturbo's Avatar
jonnyturbo
oh and you dont really want much play in the main shaft of the turbo unit.
you will prob need to change turbo soon
Old Mar 6, 2006 | 11:09 AM
JK's Avatar
JK
cool, thanks for reply
as i said i noticed it when car was sat still and i reved her and then when i took foot off smoke come out of exhaust
Blue smoke (ive just had bottom end all re-built cannt be that can it?)
so would you change turbo??????
cheers for reply
Old Mar 6, 2006 | 11:17 AM
jonnyturbo's Avatar
jonnyturbo
if it still goes, then run it til it finishes itself off. a turbo could smoke for a year before its totally fucked. but if you want best performance then id change it.
do an exchange for a reconditioned unit. or if money is flowing, go all out and get an uprated number
Old Mar 6, 2006 | 11:27 AM
JK's Avatar
JK
oh it still goes!!
but i gota be sure it is turbo! coz if i carry on might not be turbo!
got money so will get uprated unit!!!
cheers for advise, will def look to change turbo coz as i said i have had rest of engine rebuilt! why is it the only bit u dont change starts playing up!
Old Mar 6, 2006 | 11:51 AM
jonnyturbo's Avatar
jonnyturbo
yeah if it only smokes when you ease off throttle then its most likely the turbo. as you have had engine internals done recently then it aint that, also, if they were fooked it would be constantly smokey, more so when high revs
Old Mar 7, 2006 | 06:13 AM
JK's Avatar
JK
cheers for help mate
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
Brickhouse
Sep 21, 2015 04:31 PM
