frst into xr2i
Old Mar 3, 2006 | 09:24 AM
torquesteer's Avatar
torquesteer
Default frst into xr2i
anyone put a fezzy turbo in a cvh xr2i?
was wondering if i need to swap the full wiring loom or just the ecus.
have complete donor car if loom is required but would but much easier (and cheaper) if it wasnt
Old Mar 3, 2006 | 09:57 AM
daz1968's Avatar
daz1968
I think if ofac xr2i loom can be modded but if ofab then loom change required, but is easy to change.
Old Mar 3, 2006 | 12:06 PM
barry0777's Avatar
barry0777
yep you need to change the loom and the cross member ithink and cut the front out for the cooler and fan it very easy to do iv done 2or three convertions its easy to use the rst loom there are other bit that need to be changed hope this helps barry good luck it def worth while!!!!!11
Andypandy260
Sep 23, 2015 10:28 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
