Help needed with xr3 turbo setup
Old Mar 2, 2006 | 04:34 PM
rs_escortturbo's Avatar
rs_escortturbo
Default Help needed with xr3 turbo setup
Ok,i finished fitting my turbo to my xr3 today,all went smoothly until i went to start it,now heres my problem,when i disconnected the pipe coming from the throttle body to the air box and connected the pipe from the intercooler to the throttle body,the car will not start no matter what i do,now,when i connect it back the right way,it starts first turn,any ideas folks,its really anoying after spending most of the day setting it all up.I dont have any rst stuff to change things around so im hopeing that there is a way to get it going as it is..Thanks
Old Mar 3, 2006 | 10:14 PM
rs_escortturbo
Surely someone on here must have done a turbo conversion on an xr3
Old Mar 4, 2006 | 02:28 AM
SafeChav's Avatar
SafeChav
You've obviously got an air leak somewhere.......
Chech you haven't left any pipe connections unblocked for a start
Old Mar 4, 2006 | 01:18 PM
rs_escortturbo
there seems to be a kind of float under the the pipe when i take it off the airbox and all the fuel pipes are connected on there aswel so im thinking that when you start the car,the pipe from the throttle body works like a vacum to lift the float to let the petrol through,maybe someone could let me know about this and is there a way around it..Thanks.
Old Mar 4, 2006 | 03:03 PM
SafeChav's Avatar
SafeChav
Yeah it works in the same way as RS Turbo stuff, its an air dependant system, you can't disconnect the pipe to the metering head.
Have a look around on the web for the Turbo Technics TT120 conversions cos that's basically what your trying to do.
Old Mar 4, 2006 | 03:18 PM
rs_escortturbo
Ok,Thanks for the info,would it be possible to put a T junction on the pipe coming from the throttle body and connect the pipe from the top of the intercooler into it,just a thought.Thanks again for the info
Old Mar 4, 2006 | 07:11 PM
SafeChav's Avatar
SafeChav
You shouldnt need any t pipes, u need to run from the air flow meter to the turbo, then out the turbo to the intercooler, then back out into the engine. No other way it can be done
Old Mar 5, 2006 | 10:10 AM
cossie_craig's Avatar
cossie_craig
Dont mean to sound a prick but surely a turbo conversion would be so much simpler than turboeing yours mate??
Old Mar 5, 2006 | 10:31 AM
rs_escortturbo
I would love to do a full rst conversion but its impossible to get the stuff i need to do it in ireland as rst's are no where to be found here,im not looking for massive boost,just that little bit extra,maybe in time,ill get across the water and buy an rst but for now,ill just have to settle with turbocharging my xr3,if i cant get it to work,at least i tried...i dont want to get rid of my xr3 cause i have fully rebuilt it and i just recently resprayed it so it looks mint...
Old Mar 5, 2006 | 10:54 AM
SafeChav's Avatar
SafeChav
With that said if you've just re-built it, unless you have used RS Turbo pistons etc its not going to stand up to the boost very well anyway, and its going to have massive compression.
Old Mar 5, 2006 | 11:14 AM
JesseT's Avatar
JesseT
I'm sorry if I sound discouraging, but it really seems like you don't really know what you are doing. I'm seeing a huge risk here of you killing your engine completely. The std. 1.6 CVH can be turboed directly but one really needs to sort the fuelling, ignition curve, spark plugs, etc. before one can use even half a bar of boost safely.
Old Mar 5, 2006 | 04:53 PM
Avinitlarge's Avatar
Avinitlarge
Originally Posted by JesseT
I'm sorry if I sound discouraging, but it really seems like you don't really know what you are doing. I'm seeing a huge risk here of you killing your engine completely. The std. 1.6 CVH can be turboed directly but one really needs to sort the fuelling, ignition curve, spark plugs, etc. before one can use even half a bar of bost safely.
PMSL
If you understand how it works, You shouldnt really be asking these questions, Its pretty simple really, Metering head > Turbo > Intercooler > Inlet. On a car with K or KE jetronic you cant have an air leak anywhere, If you have a leak it wont idle.
This is why you cant use a single piston or diaphram dump valve on the Escort RST
muz
Aug 16, 2015 12:57 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
col93saphcos
Aug 7, 2015 03:21 PM
