Aftermarket Engine management compatability.
Old Feb 21, 2006 | 07:44 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default Aftermarket Engine management compatability.
On my Puma I am looking to upgrade the engine management system And have been thinking of omex 600 series or pectel T2.
The question I have is that in a year or so I plan to swap the engine to zetec turbo or maybe even cossie power (not yet decided!!) so is there an engine management system that i can fit that will be compatable with forced induction and an engine swap??
I'm thinking by fitting the upgraded management I can solve any potential wiring nightmares later when I engine swap and effectively just reprogram new ECU for the new engine.
I realise I may need to get an overspecced ECU and loom to save upgrading later (including longer wires in loom for the planned new engine).
The ultimate simplistic aim is to have an aftermarket dash and ECU controlling the engine and all dials, completely electrically seperate from the auxilliary loom (lights wipers etc althougth ignition live auxilliary circuits will need a feed to make the relays). My thinking being that it has to be a better solution than trying to combine a newer ford loom to an older ford loom and with the obvious problems that may cause..
Old Feb 21, 2006 | 10:02 PM
bud-weis's Avatar
bud-weis
Football Cwazy
from what i have heard, the T2 will be more than capable
Old Feb 21, 2006 | 10:25 PM
NUTS RuS's Avatar
NUTS RuS
Most of the well named branded products will do that easily
Old Feb 22, 2006 | 06:37 PM
Psycho Warren
Carbon Crazy
Excellent!!!
My evil plans are now complete!!!
Pectel are owned by PI IIRC so I might add thier dash to a T2 ECU package!
Old Feb 22, 2006 | 07:06 PM
Avinitlarge's Avatar
Avinitlarge
Megasquirt seems to be capable of alot of things, Bought it myself, Seems very good, Reasonably priced, Good backup forum with loads of help
Old Feb 22, 2006 | 07:57 PM
Psycho Warren
Carbon Crazy
I presume somthing like pectel, omex or megasquirt would be mapable my most decent tuners or would I be stuck with one??
I still haven't made my mind up on the engine yet.
My brain says zetec turbo as I can build that in stages, run it fwd for a while then 4wd it using mondeo 4x4 gear or RS2000 4x4 gear (if I can get it!).
But my heart says cosworth 4wd...........
What a choice to make???
I was indecisive once, but now I'm not sure!!!
Old Feb 22, 2006 | 08:14 PM
Avinitlarge
Mondeo/Rs2000 4x4 system is very weak, It would last 2 mins with a Zetec turbo
Old Feb 23, 2006 | 07:09 PM
Psycho Warren
Carbon Crazy
It can be uprated and isn't that bad. Theres a few rs2000's 4x4 running with 300bhp plus, one from a 2300cc I4 turbo and a rebuilt transfer box from CTS.
There was a 4x4 fiesta running mondeo gear a while back with 300bhp and no problems.
The mondeo transfer box is much stronger than the rs2000 due to the viscous coupling in the rs2000 being a bit of a weak point if not scrupulously maintained.
I'd agree that cossie bits are so much stronger though!!
Transverse 4wd does not need as much fabrication around the bulkhead area and tunnel in my car.
manuel boeckx
13
Oct 3, 2015 02:29 PM
YODI
Aug 30, 2015 01:12 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Old ford
Jul 31, 2015 06:50 AM
