lost boost presure
Old Dec 7, 2003 | 06:55 AM
Default lost boost presure
can anybody help only had my 2wd sapph for a couple of weeks was running about 15-16 psi just had new cam seals &belt fitted and now it's struggleing to hit 5psi
Old Dec 7, 2003 | 08:25 AM
XR4Timan's Avatar
XR4Timan
manifold leak? Try plugging up dump valve and check hoses.
Old Dec 7, 2003 | 01:32 PM
big_wig_074's Avatar
big_wig_074
yeah,run it,rev it,feel for leaks,and listen for leaks too!does it feel slower?if not it could just be the gauge!
Old Dec 7, 2003 | 02:46 PM
cheers guy's gauge was working fine before it went in for work just been checking all the hoses arond the turbo and they all seem fine apart from the one coming from the cone air filter would this cause the problem sorry but a bit of a novice with all this under the bonnet stuff
Old Dec 7, 2003 | 02:55 PM
PJay's Avatar
PJay
The only way the one from the cone filter would cause any problems is if its collapsing. has your car got a dump valve?
PJay
Old Dec 7, 2003 | 09:32 PM
no dump valve at present but did have one that section of hose is now plugged when i had a look at that hose though it seemed to have some possible perishing places and one or two possible rips but do not seem to go right through
Old Dec 7, 2003 | 10:27 PM
Toe Knee's Avatar
Toe Knee
Does it feel like its boosting properly when u drive?! The tubeing going to the boost gauge might have come loose or something.
Also does it start/run ok or sound a bit like a tractor?! mine had loose'd 2 manifold 2 turbo bolts last nite and it wouldnt boost properly.
Old Dec 8, 2003 | 05:27 AM
it feels fine to drive just no real boost pressure seems to almost reach 5psi and you can feel it starting to spin the turbo and thats it nothing after that just feels like a normal car without a turbo have checked all hoses i can see and they all seem to be fine apart from possibly the one from the cone air filter it starts fine and runs fine
Old Dec 8, 2003 | 10:40 AM
XR4Timan's Avatar
XR4Timan
Check the actuator - is there PLENTY of threads showing??
Old Dec 9, 2003 | 05:43 AM
i dont know how much shold be showing anyway have replaced induction pipe and still no better still struggling to hit 5psi feels like it wants to do more but when it hits 5 it stays there and then just accelerates like a normal car after that no kick up the arse at all
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
The Youth.
Sep 30, 2015 09:59 PM
Russ Payne
Sep 25, 2015 08:29 PM
