s2 rear disc conversion
Old Jul 24, 2004 | 07:53 PM
goldS2's Avatar
goldS2
Default s2 rear disc conversion
hi people anyone know whats required for this conversion?
can you just rip bits of another car (if so what bits off which car)
or do you need specially fabricated parts? i wan't to do this more
for cosmetic reasons rather than performance if it matters.
any tips much appreciated cheers.
Old Jul 24, 2004 | 10:29 PM
Piinko-RS's Avatar
Piinko-RS
not 100% mate but from what i know u need cossy rear disc's ,calipiers ,pads and a plate which will adapt ya s2 to ya cossy brakes also think 4x4 sierra fits
Old Jul 25, 2004 | 05:11 PM
goldS2's Avatar
goldS2
cheers mate all i have to do know is find the bits
Old Jul 25, 2004 | 09:40 PM
richm's Avatar
richm
Parts:
Sierra/granada rear calipers, pads and 4-stud discs
Fabricated brackets to mount the calipers to hub.
RS2000 Mk5 handbrake cable
Longer flexible brake hoses, go directly from body bracket to caliper
The standard quoted conversion will specify Cosworth discs, but in practice these are too big and will overbrake the back, locking up prematurely on hard braking.
Fitting the smaller ( and cheaper) mainstream Sierra discs is a much better match, and avoids the brake bias valves that you will otherwise need in the rear lines.
You will however need to make sure you get the right brackets to match the disc size that you choose.
Rich
www.zetec-turbo.co.uk
yatta
May 21, 2016 10:31 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
cossirob
Sep 3, 2015 09:17 PM
