Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Coolant Pipework ?
Old Nov 16, 2010 | 02:53 PM
Hoogi's Avatar
Hoogi
Default Coolant Pipework ?
Hope someone out there can advise ?
Where do the following go too or come from..........I'm not running a Heater as it's a Track Car.
1) The inlet/outlet on a 4WD Water Pump - it sits at about 8o'clock position and has an ID of about 8-10mm.
2) The very small inlet/oulet on a 4WD Thermostat Housing - it sits at the top exits on the left-hand side at about the 9o'clock position and has an ID of about 4mm.......can I loose this/block it off ?
3) And finally - I have three returns/outlets to my Header Tank:-
One is from the top of my Swirl Pot (no problem), one comes back to the Header Tank via my Turbo Cooler. But where is the larger bore outlet supposed to feed ?
So many questions, so I do appologise
Old Nov 16, 2010 | 02:58 PM
Hoogi's Avatar
Hoogi
Sorry, just realised I;ve posted in the wrong section
TPM961
Jan 15, 2018 10:50 AM
Fudgey
21
Sep 30, 2015 06:19 PM
Botts
Sep 22, 2015 02:04 PM
