Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
lightening the flywheel ST170
Old Dec 8, 2009 | 10:23 AM
Jackass1983's Avatar
Jackass1983
Default lightening the flywheel ST170
Hello
I wanted to lighten my Flywheel on my St170 engine!
I do have a std Zetec Flywheel on it, because the engine is in my Escort mk6 (FL)
how much does make sense...?
Old Dec 24, 2009 | 11:04 PM
krisrt's Avatar
krisrt
Originally Posted by Jackass1983
Hello
there is a company on ebay that sells lightened std flywheels for the zetec quite cheaply, i'll see if i can find the company and edit my post.
Old Dec 27, 2009 | 10:37 AM
mikey p's Avatar
mikey p
ttv racing?
Old Dec 28, 2009 | 01:19 PM
GTi_Tom's Avatar
GTi_Tom
Get a cvh efi flywheel and enlarge the mouting holes to 11mm from 10mm. It has the timing marks on the back for the crank sensor and weighs around 1.5kg less than the standard 220mm zetec flywheel
Old Dec 29, 2009 | 12:02 PM
Jackass1983
I do have the 240mm Clutch on a Zetec Flywheel!
And i dont want to miss it!
Here in Germany i cant find Ebay´ed less weight flywheel´s
So i do have to make it on my own, like everything else..
But i still dont know how much i can take away..
Old Mar 19, 2010 | 10:09 AM
Joshy's Avatar
Joshy
Dreamer
i wouldent try doing it yourself mate, its too much of a risk unless you really know what your doing...
Old Mar 19, 2010 | 06:18 PM
Go to a machine shop that do car parts etc, I don't know the weight of yours, but had my cossie one done, weighed 8.9KG(std 2wd) down to 6.6KG for Ł30, and that included a skim on the face as well.
Old Mar 30, 2010 | 09:39 PM
tarmac terriost's Avatar
tarmac terriost
what gearbox you running ? if mtx75 can run a rs focus light flywheel same as std zetec 240mm check out puma speed or build cant remember which one know not cheap, so might want go with the ttv option from burton power as bit cheaper.
ps dont think can lighten the std st170 one as it is a dmf unit, oh another place to check is the states ebay etc as the the svt focus is the same as uk spec st170's so might do a light conversion
Old Apr 1, 2010 | 08:29 AM
Sp3no's Avatar
Sp3no
I have imported my Clutchamsters lightened Fly from the states and its very good, not the lightest at 12.5lb but what a difference it makes. Avoid TTV they dont do a propper ST170 fly, the one they supply is for the 220mm smaller clutch plate that will fail, they cannot do a fly that will take the standard better 240mm clutch plate yet, hence why i ordered from the states.
Old Apr 1, 2010 | 05:18 PM
tarmac terriost
clutchmasters have a good rep seem very popular in the states with the foci lads out there
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
