Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Low Compression Vs High Compression - Discuss
Old Nov 29, 2007 | 08:43 AM
  #161
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Bore and stroke size, rod angle, piston speed etc. If you change any of these, they have a knock on effect (no pun intended ) of their ability to be resistant to det or not. You cannot compare different engines to their ability to run high compression - it absolutely has to be like for like - just because it is an in-line four of the same capacity, doesn't mean that it will respond in the same way to a compression hike. A good example of this is the Evo engine, which due to it's configuration, can take a much higher compression as standard (8.5:1 compared to the Cossies 8.0:1), as well as modified.
Old Dec 2, 2007 | 03:19 AM
  #162
NEIL A's Avatar
NEIL A
So what is the lowest comp that has been openly tried on a cosworth, i know 7.2:1 is what's normaly considered as low. Lowest i have been in was a 6.8:1 and didnt feel any different to my old 7.2:1 engine.
Old Dec 2, 2007 | 01:57 PM
  #163
Mike Rainbird
Caraholic
Exactly, it is a common misnoma that compression has a huge effect on driveability . However, the compression only needs to be as low as it has to be to allow the boost and ignition figures you would like to see. And I believe the engine you are talking about could take some more compression with no changes in the ignition / boost, which may give it a smidge more power .
Old Dec 2, 2007 | 06:28 PM
  #164
NEIL A's Avatar
NEIL A
Not the engine you think im on about Mike but was a ava build, dont know what comp Euan is running these day but sure it will be low and his car is responsive as any like for like and takes big boost with ease. Will be good to compare others i have been in to my new LOW comp engine soon
Old Dec 2, 2007 | 08:28 PM
  #165
rapidcossie's Avatar
rapidcossie
Have done and will be doing more testing on comp ratios on my car with true back to back testing after each stage so could be interesting
Old Dec 2, 2007 | 09:40 PM
  #166
NEIL A's Avatar
NEIL A
Any results so far ? You going up or down in cop ratio ?
Old Dec 2, 2007 | 09:44 PM
  #167
rapidcossie
only time will tell
Old Dec 4, 2007 | 10:15 PM
  #168
glancy2081's Avatar
glancy2081
a heard a rumour it was going up
Old Dec 4, 2007 | 10:21 PM
  #169
rapidcossie
wouldnt listen to rumours
Old Dec 4, 2007 | 10:43 PM
  #170
glancy2081's Avatar
glancy2081
come from a reliable source too .............
Old Dec 5, 2007 | 05:23 AM
  #171
NEIL A's Avatar
NEIL A
Told you Euan 9.5:1 is too high
Old Dec 5, 2007 | 11:32 AM
  #172
rapidcossie
no its not
Old Dec 7, 2007 | 11:54 AM
  #173
NEIL A's Avatar
NEIL A
no its not
Well i hope it is or im waaaaay off with my comp
So what other things will comp effect ? Will it have effect on boost threshold ? What about surge or is that more to do with the head ?
Old Jan 13, 2008 | 08:19 AM
  #174
testastretta999's Avatar
testastretta999
Default high compression
escrstJust noticed you are building zetc hc engine, who's the builder? I ask as i'm in the same process. Sounds more sense to me if you are not after high hp to run hc engine
cheers Richard
Old Apr 14, 2008 | 02:31 AM
  #175
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Good thread
Old Apr 17, 2008 | 09:25 PM
  #176
glancy2081's Avatar
glancy2081
so is euans new engine higher or lower
Old Apr 18, 2008 | 07:54 AM
  #177
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
its higher than it used to be, but still low
Old Apr 18, 2008 | 08:53 AM
  #178
Mike Rainbird
Caraholic
Yeah, it used to start with a 5, now it starts with a 6 .
Old Apr 18, 2008 | 09:13 AM
  #179
NEIL A's Avatar
NEIL A
SHHHH Mike dont give all the secrets away
Old Apr 18, 2008 | 12:42 PM
  #180
rapidcossie
its a bit higher than it used to be, the difference in off boost driving is so noticable.......
NOT!
Old Apr 18, 2008 | 04:52 PM
  #181
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Originally Posted by RS500
What can we expect from cosworth yb engines in the next few years??
Can we expect 700 + bhp from a street YB engine ??
707bhp on Optimax from mine . Can I ask what MikeR considers HC in a YB engine producing near 800bhp, over 7.5:1 or maybe even 8:1 . Genuine question after Knowing what Mark now builds.
Old Apr 19, 2008 | 11:39 AM
  #182
NEIL A's Avatar
NEIL A
Rod hasnt Mark already stated that he can build them high comp but has to be a ground up build, so he can change rod lenght ect to get it to work.
Old Apr 19, 2008 | 03:50 PM
  #183
Mark Shead's Avatar
Mark Shead
Rod lenght realy has nothing to do with it, Its knowing how to make it work and the realy big engines can support a much higher comp than you think if you are stuck in the past
Mark
Old Apr 20, 2008 | 06:20 AM
  #184
testastretta999
Default compression
How about someone doing a technical write up about high compression engine building?
Old Apr 21, 2008 | 12:52 PM
  #185
Mike Rainbird
Caraholic
Rod,
I know you can do it - if you're prepared to accept an engine that doesn't make full boost until 5000rpm. However, driveability is what I want, rather than outright numbers, so for me achieving a a high power figure with a huge turbo is complete and utter waste of time for a track car .
My engine makes 0.7 bar at 3000rpm and 2.2 bar by 3500rpm, which it holds all the the way to the limiter and due to this, I personally wouldn't want to run any higher than the 7.3:1 that I am running, as I want good ignition values to keep engine heat at bay.
A top speed run lasts 35s? A lap of the Ring lasts 8mins.... .
Obviously you build an engine to its desired remit. To say it is stuck in the past is completely missing the point .
Old Apr 22, 2008 | 08:13 AM
  #186
CossieRich's Avatar
CossieRich
Mike.
you could run more boost than that surely for more mid-range torque? Or is there a reason? And no im not saying 2.2 bar is low, but i am a boost junkie
Old Apr 22, 2008 | 09:06 AM
  #187
Mike Rainbird
Caraholic
Originally Posted by CossieRich
Mike.
450lb ft used regularly and aggressively is already highlighting any weaknesses with the transmission, so why would I want to put this under even more strain, along with overspeeding the turbo and increasing the ACTS?
Old May 13, 2008 | 02:20 AM
  #188
Canada1's Avatar
Canada1
Default Compression Ratio Dynamic vs. Static
Static compression ratio is calculated from swept volume and combustion chamber volume etc, etc... We come up with a value of 7.5:1 or 9.5:1, or whatever we want.
Camshaft timing - specifically when the intake valve closes is much more important.
Dynamic compression ratio is the important factor. Japanese engines ( or most modern designs) have variable intake camshaft timing - where the intake camshaft is advanced or retared wrt the crankshaft. This changes the dynamic compression ratio. Much higher static CR's are used when variable or late intake closing camshaft timing is used.
On a Cossie the camshaft position is not variable, and is not a late closing profile, therefore CR's of 7.5:1 and lower are used for high boost applications.
Honda engines with variable camshaft timing (phasing) and an efficient combustion chamber
can use a much higher compression ratio before detonation takes place.
One cannot make a blanket statement regarding compression ratio in a turbocharged engine. There are many more variables than just static compression ratio alone.
Just a thought from a Canadian ERST fan.
Old May 13, 2008 | 05:17 PM
  #189
Mad Matt's Avatar
Mad Matt
Rally nut
I have 425lb/ft of torque at 3000rpm and my engine is not a low CR one.
And without all Mike's Mountune inlet and other stuff. Thanks Harvey Gibbs !
Old Sep 25, 2008 | 11:13 PM
  #190
Charlie Chalk
Unknown.
Whats the difference in pistons for high and low comp, can someone post a picture please?
Old Sep 28, 2008 | 07:43 PM
  #191
JoeRS22's Avatar
JoeRS22
high comp one is more flat and low comp looks like a breakfast bowl charlie!
Old Sep 29, 2008 | 09:47 PM
  #192
theburns1's Avatar
theburns1
cannock is a race track
bmw f1 car! 1000 bhp from a 1.5! high comp turbo! if you got the internals and the octain then its better. i kno its an F1 car but thats where it all starts
Old Sep 29, 2008 | 09:50 PM
  #193
Stavros's Avatar
Stavros
DEYTUKURJERBS
what
they was NOT high comp, 7s and 6s.
and they ran on mega race fuel, on pump fuel high comp is a whole different ballgame...
Old Sep 30, 2008 | 01:03 PM
  #194
_DAN_'s Avatar
_DAN_
Yoon
Normal compression flat top pistons.
Higher compression domed/raised pistons.
Lower compression forged pistons.
Old Oct 1, 2008 | 08:18 AM
  #195
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Rod,
Well Mike mine made 3.2bar of boost at 4400rpm on 8.4:1 on a GT42.
Old Oct 1, 2008 | 08:32 AM
  #196
m_nettleship's Avatar
m_nettleship
This post can end up endless. i carnt belive how fast they can make diesels now.
Old Oct 1, 2008 | 04:23 PM
  #197
Mad Matt's Avatar
Mad Matt
Rally nut
Lol. Diesel is for tractors, nothing else. Driving pleasure starts where diesel end..... at 4000rpm. Just try to find a 2.0L diesel engine 4cyl with more than 500bhp...
Old Oct 4, 2008 | 10:40 AM
  #198
theburns1's Avatar
theburns1
Originally Posted by Stavros
what
yes they did, dick head!
Old Oct 4, 2008 | 05:54 PM
  #199
crazycage's Avatar
crazycage
any need for that ?? how old are you anyway?
Old Oct 9, 2008 | 07:52 AM
  #200
msport's Avatar
msport
Wink
The F1 Turbos used 8.0-8.5:1 in CR and used ~85% toluene and 15% heptane fuel = poison!
I run 10.88:1 in CR on my WRC escort rallycar engine. Anyone want to argue if it works proper?
