Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Low Compression Vs High Compression - Discuss
Old Feb 5, 2004 | 12:17 PM
  #121
Originally Posted by Mike Gurney
"do you prefer the daughter or the mother"
Old Feb 5, 2004 | 01:00 PM
  #122
turbo man's Avatar
turbo man
You all crazy.
People HAVE to go low comp to compensate for the fact that they can't cool the air enuff before it enters the cylinders.
It costs ALOT more to run systems to cool the air enuff to run high boost on high comp.
thats all it is.
on high comp high boost you have to run even bigger coolers to bring the temp down to an operable level (assuming boost at same as low-comp)
thus you outwiegh the "benefits" if you go too far, ie boost is so high, and comp is so high, that cooling system is so big it takes 5000rpm to fill the system to operable pressure.
what you all need to do is get a book on turbo'd dragsters yank style.
methanol injection (if not fully fueled) is the way forwards.
CO2 spray on intercooler (if not methanol) is also the way.
reasonable sized cooler (not truck style like that red escort avec lorry cooler)
on yank dragsters they spray methanol into the system b4 cooler, over the cooler, and run the thing on methanol!
they put like 14:1 CR with 30+psi easy, an they do 1500-2500hp+
all it is is making sure the peak compression temperature does not exceed the natural fuel ignition temperature. and its not an easy thing to do. else we'd all be doing it!
Old Feb 5, 2004 | 01:03 PM
  #123
PJay's Avatar
PJay
There ARE people doing it hence the discusion!
Old Feb 5, 2004 | 01:06 PM
  #124
turbo man's Avatar
turbo man
did you read the sentence before that?
hence it costs and isn't an easy thing to do as cheap as low comp.
Old Feb 5, 2004 | 01:16 PM
  #125
PJay's Avatar
PJay
I did readed it yes, why is acheaving an acceptable ACT so hard, i think it's not, why is it more expensive than low comp, again an engine build cost would be similar surely? Were not talking methanol, race fuel or another were talking road cars, wheres the infor mation to substanciate your claims?
PJay
Old Feb 5, 2004 | 01:19 PM
  #126
So in conclusion, from what i've read over the past three pages,
High comp offers more benefits and performance but requires more precise mapping and setting up and looking after whereas low engines are easier to set up and are easier to look after and keep running.
Also low comp engines are cheaper to build and run compared to a high comp engine. If thats the case, low comp all the way for someone like myself. Not much money not much knowledge.
Old Feb 5, 2004 | 01:20 PM
  #127
PJay's Avatar
PJay
Notice theres nothing to substanciate thet though, why would low compression be cheaper when you could run with the pistons you've already got or Raise the compression further?
Old Feb 5, 2004 | 01:33 PM
  #128
I know little or nothing about the subject, just coming up with assumptions from what other people are saying.
Just trying to figure out the cost side of it all. In the future i'm hoping for 400bhp plus so am wondering what route to take.
  #129
turbo man's Avatar
turbo man
what do you consider an acceptable act? 28DegC with 30psi?
*Following are not actual figures, just examples*
on a 7:1CR engine this 28 becomes 196DegC under engine compression
on a 10:1CR engine this 28 becomes a 280DegC under engine compression
spontanious combustion of the fuel occurs at 220DegC
so the air needs to be made cooler BEFORE entering the cylinders, ie 22DegC at least.
now being as people running 7:1CR can have "problems" with detonation it becomes alot more problamatic once the CR is raised.
boost is "free" power, why waste it? high CRs are used to eliminate lag, plus you can only build on what you start with, and a high CR starts higher. its all swings and round abouts. do something, cut back on another. classic examlpe of our lecture on lateral weight load, do we load the car balanced when static, or is the track more suited to an asymetric load when static, ie are there more left corners than right. you give something up for another.
as in, high CR with same boost as low CR needs a bigger cooler to stop det, but at what point does the size of the cooler have to be so big to stop this that the lag is so big that it becomes pointless?
Old Feb 5, 2004 | 01:58 PM
  #130
PJay's Avatar
PJay
But you won't need 30 psi to make the same power on the high compression therefore the outlet temperature of the turbo will be lower so intake temperature will be lower the reason people struggle with det on low 7.?:1 compression ratios is because they are running huge 30+Psi boost to compensate for the lack of N/A power that a low compression engine can produce an 8.0:1 engince can make 550bhp on 25 ish psi i'd be interested to see the similar ouout for a low compression engine running the same boost, not that boost has anything to do with power but is just a by product of the turbo generating increased air flow and mass.
PJay
Old Feb 5, 2004 | 04:33 PM
  #131
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Most engines are a compromise and it is only the ones that are live mapped that are getting the full potential of low or high comp / max ignition / high boost anyway.
As long as the car is live mapped, you shouldn't have a problem either way, as you take the engine to the point of det and then back it off, so it is swings and roundabouts.
Each engine has to be specced from scratch and EVERY single component matched to the spec to keep the cylinder pressures at an acceptable level.
The way I went about doing my engine was firstly deciding what power output I wanted to achieve, then I decided what turbo I was going to use (based on my power requirement and the optimum boost that this turbo was most efficient at). From there we were able to work out what was the highest c/r we could use to give accceptable cylinder pressures. It was then live mapped on an engine dyno with the maximum ignition advance the above could cope so that det occurred (and then backed off to a lower "safe" level) and obviously the fuelling matched to this.
The engine exceeded it's remit by almost 30bhp, so I was WELL happy and it feels like a T3/4 car down the bottom end . EXACTLY what I wanted - a good point and squirt car.
Most people are chasing numbers without ANY consideration to how the car will drive. I have an engine that is considerably less powerful than most T4 equipped cars, but I think it is much more driveable than almost any of them...
Old Feb 5, 2004 | 04:42 PM
  #132
Mike.....my car also drives mint now,looking fwd to beating your figures on a DIY build
PS i did hear you only had to point it to squirt...Jen is quite dismayed by it!
Old Feb 5, 2004 | 06:36 PM
  #133
JesseT's Avatar
JesseT
Is anybody in here using an ion-sensing setup to control ignition advance. It sounds interesting and feasible to say the least.
Old Feb 6, 2004 | 08:02 AM
  #134
Mike Rainbird
Caraholic
Phil,
In your dreams .
LOL
Old Feb 7, 2004 | 06:51 PM
  #135
turbo man's Avatar
turbo man
we agree i can see, but we are just slightly out with the way we are looking at it with each other. not gonna argue cos there is no arguement pjay, just missing each othas points.
but..
boost is the "simple" way of saying increased air flow and mass.
the mass is increased due to the fact that it is under pressure, "boost", so how is it not related to power?
Old Feb 7, 2004 | 07:03 PM
  #136
PJay's Avatar
PJay
I'm not aruing mate, discussing, i'm not saying that i'm right
I agree 100% that the mass is incresed due to the boost but i was trying to say that a high compession engine requires less boost to generate x amount of power compared to a low compression engine. and in doing so as i'm sure you are aware less boost will result in less temperature increase of the air under compression in the turbo compresser. Also a larger turbo produces more 'mass' per pound of boost than a smaller turbo
Old Feb 7, 2004 | 07:50 PM
  #137
RS500's Avatar
RS500
What can we expect from cosworth yb engines in the next few years??
Can we expect 700 + bhp from a street YB engine ??
Old Feb 7, 2004 | 08:13 PM
  #138
Matt's Avatar
Matt
it really does amaze me that some people are dumb enough to think that engine management systems can change the laws of physics and fundmental engine principals............. hilarious really
Old Feb 7, 2004 | 08:19 PM
  #139
GARETH T's Avatar
GARETH T
i agree with you!
Old Feb 7, 2004 | 08:26 PM
  #140
turbo man's Avatar
turbo man
where did that come from Matt? engine management doesn't really affect this situation. all it needs to be is setup properly, it won't change anything magically.
PJay-
yeah i know wot ur saying, all i was saying was that boost is "free" energy, so keeping the "free" energy input the same, a high comp engine can produce more power, if ample cooling is induced, but as said, at what point does the system to cool become so vast that it takes forever to reach the same boost level.
Old Feb 7, 2004 | 08:32 PM
  #141
Matt's Avatar
Matt
turbo man, it came in response to the usual crap you read on such discussions about low comp turbo's lumps being a thing of the past due to newly developed engine manegement system..............its just total and utter stupidity
my car is low comp and you couldnt get any more pointier and squirtier if you tried
Old Feb 7, 2004 | 09:17 PM
  #142
Alg1k's Avatar
Alg1k
Old Mar 10, 2004 | 10:48 PM
  #143
in sweden there is all ready en 734bhp engine... and a few in norway...
2L engines... high kompression
Old Mar 10, 2004 | 11:14 PM
  #144
PJay's Avatar
PJay
Any more info on this and any others?
Old Mar 10, 2004 | 11:16 PM
  #145
PhilM's Avatar
PhilM
PassionBMW.com Member
It is my understanding ultimatly the engines power/boost will define the CR.
A low power engine can run a higher CR, such as 8.3:1 for example to mainatin drivability, and a massive power engine, due to the laws of physics (dynamic compresion and flashpoints etc) will require a lower CR.
Exceptions being WRC cars which dont defy physics, their conditions are altered so they stay within the boundrys, ie, boost tailing off at high rpm (Hence they can run 2bar at 9:1CR)
Thats my brief understanding
Old Mar 11, 2004 | 07:24 AM
  #146
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Most people are chasing numbers without ANY consideration to how the car will drive...
good comment mike!
oh and btw my engine IS low comp and has superb of boost
drivability
Old Mar 11, 2004 | 07:40 AM
  #147
Kev.H's Avatar
Kev.H
I am stupid when it comes to engines but if rally cars used to run low comp and now run high comp and everybody follows the trend... would time not be better spent in developing the high revving aka Karls engine or develop say a turbo vtec style type engine ???
will the trend stretch to gearboxes They used to run 6 or 7 speed for rally cars and still do but now the likes of Pug team run a 4 speed box so will everyone be going for a 4 speed downgrade conversion I mean havent we come from there allready back in the day
Old Mar 11, 2004 | 12:30 PM
  #148
JesseT's Avatar
JesseT
Don't forget that the rally cars run high comp mostly because of the inlet restrictor, which they have to use according to FIA.
Old Mar 11, 2004 | 01:34 PM
  #149
scottbrown's Avatar
scottbrown
and rally cars can be rebuilt after every weekend and dont have to be driven to work on the monday morning.
i dont understand all the issues but it comes accross as having the cash and knowledge etc.
if it was me i would pick my trusted tuner and listen to wot they say, they are the experts and if u cant trust um why are they building ur engine?
it all seems like horses for courses!
Old Mar 11, 2004 | 01:50 PM
  #150
Sean Bicknell's Avatar
Sean Bicknell
Sounds like an indian restaurant i once visisted. I think both the first course and the second course were horse!!
Old Mar 11, 2004 | 02:06 PM
  #151
PJay's Avatar
PJay
I really don't want this topic to go downhill but horse is very nice
Old Nov 23, 2005 | 10:59 PM
  #152
Stu @ M Developments's Avatar
PassionFords Creator
bttt
Old Nov 24, 2005 | 12:08 PM
  #153
markk's Avatar
markk
bttt lol
technical discussions ---- AT LAST again
rather than 'how warm is my stella ! "
Old Jan 20, 2006 | 02:47 AM
  #154
Stavros's Avatar
Stavros
DEYTUKURJERBS
Turboman makes a LOT of sence, unlike most.
High comp and big bhp per litre only works with race fuel and/or incredible charge cooling.
If any of your believe (certainly used to by looks of this thread) that the high comp american or jap cars run big boost on pump fuel your massivley mistaken.
And most are horrendous to drive as to make half decent power with such high comp and run pump fuel they need massivley OTT exhaust housings and cams compared to a big boost low comp engine.
Old Dec 20, 2006 | 06:14 PM
  #155
escrst's Avatar
escrst
bk up ttt
we are having a zetec turbo engine buillt but the tuner rekons on a 9 to 1 compression ratio i thought that was a bit high but at the end of the day they are more expierienced at building engines than me.
wot you guys rekon?
Old Dec 29, 2006 | 09:21 PM
  #156
Rs1's Avatar
Rs1
Stavros when you say high comp and big bhp per litre what figures did you have in mind?
Theres people on here running in the region of 450hp yb's on on anything between 7 and 8:1, obvioulsy theres a a few people below and above these figures but generally it seems sub 8 is favoured...yeah?
I think it would make things alot more understandable for and possibly make a better discussion if we had an example to work off rather than throwing different comp ratio's on different engines and different turbos...what do think?
Lets says a yb(obvioulsy), 500hp is a pretty round number, 7.5k rev limit, rs500 cooler and a gt30r. Firstly i'd want to work out as close as i could as to how much air this will need to see than kind of hp, i'd then see where in the comp map the turbo is likly to supply it while factoring in pressure drops and estimated cooling of the air at the given flow rate.........and so on
Looking at turbo mans example of act temp increase during compression surly we can guessitmate enough of the factors to give a good working out ballpark figure to what comp ratio we should be at?
Then all it would take would be to build and run this engine setup, test it, factor into the first equation the actaul data we would now have and recalculate to a more.....accurate target comp figure for the next build. Surly it would take long to get to a point where it dyno's at just the right comp ratio
Anyone with plenty cash please try out my theory.
Feel free to tell me to shut up if i'm talking pants
Old Jan 22, 2007 | 06:14 PM
  #157
Mad Matt's Avatar
Mad Matt
Rally nut
Sorry to get this thread again but I have more questions :
I am going to start to plan an engine build, but I don't know yet all the specs. What I have in 1st position is I want torque. Not torque at high rpms, but torque from low rpms to middle, middle-high rpms.
This car won't be used everyday, only once a week or once in 2 weeks.
I will go for antilag of course, the aggressive one, on a T35. Then it is a bit blank. Would it be better to go in low or high-comp engine ? 4 greys I belive, but which camshafts ? Lot of interrogations.
Power would be around 350bhp.
Open to advices, also in PM if needed.
Old Nov 15, 2007 | 01:52 AM
  #158
paconassa's Avatar
paconassa
Sorry to pick up this subject again, what you said is true but only some in diesel-like engine speed's (5000-5500 as many ford engine tuners like to tune them )
Like you know, all things in life take a certain amount of time to take place. Detonation occurs when the fuel as enough time to heat up. that said, we can easily have a 2L engine 9:1CR and produce 900hp on pump fuel, simply by increasing rpm!
Old Nov 15, 2007 | 10:07 AM
  #159
Mike Rainbird
Caraholic
Depends completely on the engine architecture. Evo - YES. Cossie - NO.
Old Nov 29, 2007 | 03:25 AM
  #160
paconassa's Avatar
paconassa
What do you mean by "architecture"? they are both 4 cylinder, 4v per cyl, pentroof CC....
