Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Low Compression Vs High Compression - Discuss
Old Jan 30, 2004 | 06:52 PM
  #41
ECU Monitor Enthusiast
The moral of the story is....
Decide a spec for the engine and get it built and tuned properly !!
(dont just chuck a chip in and expect 1000000 BHP)
Every tuner/builder has thier own methods and standards.
Sadly, alot of people WRONGLY believe the following statements are true...
1) Low compression is safe
2) Rich fuel mixtures prevent detonation
Old Jan 30, 2004 | 06:53 PM
  #42
PJay's Avatar
PJay
Monte have you got the link for that thread, would like to read it
Old Jan 30, 2004 | 06:57 PM
  #43
point 1.... would you say low comp is more reliable on pump fuel and as a road car....
point 2 surely the right air/fuel ratio is important......so running to rich fecks that up as much as running lean....also thinking that running a little rich is MUCH better than running lean ?
Old Jan 30, 2004 | 06:59 PM
  #44
As an example (can name names or car)...
(Not a cossie motor)
2.1 litres,
4 cylinders
8.7 CR,
Special designed pistons,
97 RON fuel (super),
Water injection (no additives),
Wideband lambda
EGT fuel control,
Motec ECU
840 BHP (With engine reliability - transmission is another matter !!)
I have seen this on the rollers and engine dyno ....
Old Jan 30, 2004 | 07:00 PM
  #45
dingy
Old Jan 30, 2004 | 07:02 PM
  #46
Yes Low comp is safer to a point,
AFR is important and rich is better than lean,
but rich mixtures do NOT guarantee det free perfromance.
  #47
daddy, i can't see how a little too much fuel is that bad over a little lean
I let karl do my engine specs, he seems to be ok at it, his car is no to slow.
Old Jan 30, 2004 | 07:04 PM
  #48
I did not say too much fuel is bad... just that it does NOT guarantee safety
Old Jan 30, 2004 | 07:05 PM
  #49
SECS, not saying your wrong or anything just asking...
So if a car has a little too much fuel how can this be det free....
I am thinking too much ignition ? or is that not what u are getting at.
Old Jan 30, 2004 | 07:06 PM
  #50
I know mate hence the
was a piss take
Old Jan 30, 2004 | 07:10 PM
  #51
Dingbat...no problems re dig at Dirtbox.
Old Jan 30, 2004 | 07:11 PM
  #52
EscortWRC's Avatar
EscortWRC
Well, metallurgy has evolved quite a bit and there are some alloys available now for pistons that were not back then.
I suspect that between having MUCH better ECU's available (better resolution on fuel AND timing) and the advances in materials, the development possibilities have opened up quite a bit.
There are a lot of people who tend to stay with 'tried and true' methods and that's fine as long as they work. I like to take advantage of newer tech and don't mind doing some of my own development rather than just going with a 'plug and play' solution.
YMMV
Old Jan 30, 2004 | 07:12 PM
  #53
Originally Posted by Ima Racing500
See Paul Hills at Engine Advantages...end of topic
Most tuners on here talk crap...ok 1 tuner on here in particular Get proper info and then base a decision..................
????? who ?????????
Old Jan 30, 2004 | 07:13 PM
  #54
PS....This is a fact...the reason many tuners dont agree with hi comp is because they arnt competant enuff to do hi comp,lo comp is safer cause its all they know...as SECS has said move on people....
Old Jan 30, 2004 | 07:14 PM
  #55
The moral:
If you are happy with your engines performance, who cares about CR.
If you want performance and good fuel consumption High CR is the way to go IMO!
Old Jan 30, 2004 | 07:17 PM
  #56
people do move on defo mate.....
but that statement is horseshit....if you have the means to make something better, IE management then thats the way it goes.
More the control increases the better the reliability, simple facts really.
  #57
????? who ?????????
Yeeeee .... ouch ????
I never claimed to be a tuner !!
Old Jan 30, 2004 | 07:21 PM
  #58
Phil's Avatar
Phil
Jeebus
well, lets see a high comp engine put some decent times in then and prove something...
(i'm going to feel really stupid now if martin hadlands is over 8.0:1)
Old Jan 30, 2004 | 07:22 PM
  #59
I though he was having a dig at AHMED
  #60
Phil,
Perhaps you need to explain all the techinical aspects of low and high comp engine speccing et etc and why high comp is better. There is only one person I have seen do this on this board and justify his point and that is Karl hence why I love the posts he does.
Most people say you should do this but can't explain for shit why, Karl on the other hand say's you should do this and explain in great detail why.
In short one person is talking here say bollocks and somebody else is talking fact. I experience the same thing in IT and it makes me laugh my tits off at some people.
So to sum you up your techincal disccusion on the matter in case anyone missed that. High comp is better because............hmmmmm.........hmmmm.........er rr.......Paul Hills says it is........hmmmmmmmm........my engine drives better now (but still laggier than dan's T4 low comp engine).......
Point made me thinks, off for food!!LOL
Cheers,
Dan
Old Jan 30, 2004 | 07:23 PM
  #61
Mike Gurney's Avatar
Mike Gurney
interestingly low comp engines have better torque at low RPM's
Old Jan 30, 2004 | 07:24 PM
  #62
Mike Gurney
I guess the best solution is an engine with variable compression like the new Saab
Old Jan 30, 2004 | 07:29 PM
  #63
Mike Gurney, Whats the CR in that FESTA then ??
  #64
SECS.....it wernt a dig at you..paranoid or WHAT
Old Jan 30, 2004 | 07:33 PM
  #65
Yep I am paranoid - no probs!!!
Old Jan 30, 2004 | 07:34 PM
  #66
Mike Gurney
The C:R in my fiesta is quite low - but agressive ign advance makes it a responsive car to drive
here's another intersting point - if a car cannot produce low act's you have to go for low c:r to combat det
Old Jan 30, 2004 | 07:37 PM
  #67
PhilM's Avatar
PhilM
PassionBMW.com Member
Hmm, would ACTs have that much of an effect? I'd not ahve though you'd need to alter CR for it!!!.
Essentially a high ACT means less oxygen/unit. Therefore you'd just adjust the fueling to suit (so you retain your desired AF ratio), why would you need to go low comp??
*Probably missing a point here!*
  #68
I think this is one of those "chicken and egg" type subjects......
Old Jan 30, 2004 | 07:40 PM
  #69
xrsi's Avatar
xrsi
higher compression promotes earlier point of det! higher combustion temps in cylinder due to the air being compressed alot more. so in theory could lead to more localised hotspots which promote the onset of det...
how ever a higher compression does give a biger bang when combustion occurs so does give more power, its just making sure the engine can cope and that cheap/bad quality pump fuel aint used to try to decrease the risk of det!
just what i have sort of learnt in the course at uni so far, prob all wrong tho!
Old Jan 30, 2004 | 07:41 PM
  #70
High ACT's over about 35-40 deg C may cause induce conditions that induce det !
But it depends completely on the sum of the total spec of the engine.
(I.E Every engine is different !!)
  #71
Mike Gurney
well a hot charge is more prone to det as it is compressed
Old Jan 30, 2004 | 07:42 PM
  #72
PhilM's Avatar
PhilM
Cool
Good job ive got my little cooler planned then eh mate? Fuck knows what the outlet temperature will be, will be interesting to find out though
Old Jan 30, 2004 | 07:43 PM
  #73
Cool
Too cool can cause the fuel to drop out of the mixture .......
Its a fickle old world .....
Next topic subject -- too hot or too cool !!!!
  #74
PJay's Avatar
PJay
AE phil!
Old Jan 30, 2004 | 07:44 PM
  #75
Monte...i'd say my tuner is more experienced than your new sexual fantasy!..ROFL
  #76
PhilM's Avatar
PhilM
We'll soon find out Simon
Old Jan 30, 2004 | 07:45 PM
  #77
Originally Posted by PJay
AE phil!
I know what you are talking about !!!!!!
  #78
Its all to do with mapping..you either got it or you aint..and most certainly aint!!!!!
Remember i specced my engine..and i aint a pro ..Paul is doin his best with a bad job..ROFL...but i have every confidence!
Old Jan 30, 2004 | 07:46 PM
  #79
PhilM's Avatar
PhilM
So do i...adiabatic efficiency...its obvious innit?
  #80
ARGH.... Too many variables..........
