Cossie owners need to read this - voltage and fuelpumps.....
Team HOTHOT!
As you will of read yesterday, i put a question about the voltage on the taxi reading 13.2 volts at hot idle with the aditional earthing strap and a rewire the alternaotr feed and re-terminalling of all the terminals on the battery.
Today my quest for greater voltages, and more reliability, led me to start re-wiring my fuelpump, using the original wires as the trigger wires for a 70amp relay (an ignition relay from any ford sierra, fiesta, escort etc etc).
What i found when i removed the wires from the fuel pump was shocking - black and crusty copper inside the sheithing which obviously had been getting rather hot
Instead of stripping back to find good wire, i untaped the loom in the boot and took nice fresh wire from there for my relay - all is good
Now with the new fuel pump wires (not totally finished, just waiting for my 044 fuel pump now as the original one is as old as the car - preventative maintenance
), and new wiring for the battery and alternator etc etc, the SECS monitor is reading a healthy 13.9 volts at hot idle and cold idle with all electrics off, and this drops to 13.6 volts with the headlights on, and then drops again to 13.1 volts with everything switched on, rising to 13.4 volts if the engine speed is raised to 2000rpm
Pictures of the rewired parts are below
Aditional earth strap using gold plated terminals that are crimped and then soldered to the wire
![](https://i6.photobucket.com/albums/y241/Graceland1/Cossie/Rewire/100_1646.jpg)
Positive terminal on the battery showing the new feed from the alternator and other re-terminalled feeds
![](https://i6.photobucket.com/albums/y241/Graceland1/Cossie/Rewire/100_1645.jpg)
All connections to the battery - the big fuse holder ontop of the battery is not for an amplifier, but is infact the positive feed for the fuel pump with a 40 amp fuse. The negative feed is of the same size also
![](https://i6.photobucket.com/albums/y241/Graceland1/Cossie/Rewire/100_1647.jpg)
This is where the feeds for the fuel pump come thru the boot floor, protected by rubber grommits - they are purposefully left looped like this as i am waiting on an 044 fuel pump been delivered, once this is fitted, along with new filter in a new cradle, i will trim the wires to the correct length and terminate them with gold plated terminals onto the fuel pump
![](https://i6.photobucket.com/albums/y241/Graceland1/Cossie/Rewire/100_1642.jpg)
SECS monitor showing hot idle voltage (950rpm, the monitor shows 500rpm due coilpacks, Simon says he will update the software for me soon
![](https://i6.photobucket.com/albums/y241/Graceland1/Cossie/Rewire/100_1649.jpg)
So there you go boys and girls - check those fuelpump feeds as the more work the fuelpump does, the more current it draws and the more chance of the old wiring failing
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Football Cwazy
Originally Posted by lamb chops
So have you wired the secs monitor to the fuel pump wiring?
Graceland , how much are 044's nowadays??
PassionFord's crazy fool!
Man what's with the spaghetti junction going on on your positive battery terminal?
For a guy who always used to tell me he hates talking about his car, you don't do a bad job
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Team HOTHOT!
![007](https://passionford.com/forum/images/smilies/bond.gif)
the multiple connections on the battery are going to be sorted soon - i'm waiting on a big distribution block arriving
the secs monitor has all 7 wires that it posesses soldered to the terminals in the back of the ECU plug
The 044 pump is costing me a nice figure, i believe a member on here has 4 left now, he may be willing to part with one for a good price too
Team HOTHOT!
the fuel pump circuit is controlled by the ECU so thats all good, and with big chunky wires like i have just fitted, i can be assured that the fuelpump is seeing full battery voltage all the time ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
My secs monitor monitors the voltage to the ecu, and a seperate voltage gauge monitors the rest of the circuits,
The fuel pump is originally fed from the ecu power circuit and as such, a bad set of wiring and a poor pump can drop the voltage of other important management items down, so you score two goals with one rewire.
Heres a topic i did about fuel pump issues to keep this topical...
https://passionford.com/forum/viewtopic.php?t=163279
Well done Gracy.
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Well done Gracy.
Nice one Paul. My re-wire is Here
My cable runs are all as per standard, so nothing hanging down and no redundant wiring anywhere.
I also replaced the fuselinks and re-wired the ECU feeds at the same time![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Neil.
Neil.
Stu, I'm confident the wiring to the ECU and the pump is cock on now, but I'm a little concerned about the voltage still.
I only get 13.5 at the battery with everything off at idle. The alternator reads 14.1V.
However, if I run a jump lead between the alternator and battery, it doesnt raise the battery voltage at all
can't get my head around it, but I assume this proves the alternator wiring is OK?
Is my battery voltage sufficient, or should I be re-conditioning the alternator?
Cheers!![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Neil.
Cheers!
Neil.
Team HOTHOT!
Originally Posted by Stu @ M Developments
Originally Posted by Neil S
I also replaced the fuselinks and re-wired the ECU feeds at the same time ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
ive run same wire direct from battery to a relay switched by the original wiring, also run big wires from the alternater to battery, starter and new earths to engine & body.
![](https://img.photobucket.com/albums/0603/cossiebert/finnyrepaint008.jpg)
Neil.
Cheers!
Neil.
Option 2 is battery is poor and taking a permanent current to sustain its life.
interesting read i am also in the middle of doing my fuel system at the mo wiring, quiped lines and an 044.
Replaced my ECU feeds when i did my loom last year.
i am running AWG 8 to the pump fused at the battery etc etc
and use the stock wiring as a trigger.
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/loom1.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0131Medium.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0128Medium.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0115Medium.jpg)
Engine/alternator earth suspect is option 1. (Painted brackets?)
Cheers Dude!
Neil.
Are these suitable to helping with situations like Gracie has on his + ive battery terminal....
http://www.maplin.co.uk/Module.aspx?...lation&doy=7m2
After you have done the mods you suggest, fit an accuvolt system & supply up to 16v (adjustable) to your pumps at all times. Will supply 16V even if the alternator fails & the battery volts drop to 9.6v. I would not atempt a Topspeed run without it.
Rod
Rod
Originally Posted by pee vee
So the -ve from the pump, does that just go to the body of the car in the boot?
or right back to the battery too?![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
sadly, dont have that feature in my motor! lol
grace
I had my wireing upgraded ahwile ago now form the relay to the feul pump and i have only got 10.8 volts while the car is running
now when i put the voltage tester on the battery while the engine is running i have got 13.9 volts it earthed in 3 places .......i was thinking would i need to up grade my fuel pump relays to something higher because i recon my fuel pump /ignition relays are working that good
just thought i would ask the question ?
the car feuling ok even with th 10.8 volts and i have got grp a pump on it aswell
cheers Marco
cheers Marco
just as a definative answer, could you tell us
what voltages are optimal/ideal at
Altenator
Battery
Fuel pump
SECS/ECU
would all be 14v ideally at idle?
Altenator
Battery
Fuel pump
SECS/ECU
10.8volts is worrying Marco, best get her checked out as when she starts drawing big current (On boost) your in danger of the pump stalling mate.
would i be better off changing the fuel/ignitions relays to a higher ampage or something like that ?
the car is off the rd at the min because of the diff so it wouldn't take too long to sort out
cheers Marco
100% good advice to sort this on your old shitters!
i feel sure mine reads 14.2 volts at idle (at ecu) per the secs monitor
(total new engine loom, new fuel pump loom with twin relays, extra earth straps, 90amp alternator)
Impossible to say as i dont know how its been rewired pal.
Ideal is a live, fused, direct from battery to pump and this being activated by a single stand alone relay thats operated by the existing wire.
mine it's not wired directly from the battery
it has been re wired from the original exhisting wire that come after the relay basicaly cut the old wire and up graded thicker wire to the pump
so i would be better off in sending a new wire from the battery to the pump on a switch or something like that
i'm shite with electrics
DazC
10.8 was good it was only 9.8 before that
cheers Marco
Brilliant topic peeps
I know for a fact my wiring at the pump is cack an dthat cheap fordy conector plug is seriously gash that breaks
Im on a mission to get mine all sorted this year
Matt
does your moniter read the voltage coming from the fuel pump or is that genral voltage ??
Marco
