Braided engine loom, secs monitor ALL SOLD
Old Apr 14, 2011 | 05:43 PM
B13 JUS's Avatar
B13 JUS
Default Braided engine loom, secs monitor ALL SOLD
I'm selling my carlooms uk braided engine loom *SOLD*
If this sells I will also sell my secs monitor but the loom needs to sell first or together.
this loom with fit a 2wd or 4wd cosworth.
My loom has every extra built into it, twin ignition amps which are included, secs monitor lead, lamba sensor lead, and coil pack lead.
There's also 2 crank sensors built into it and are controlled via a switch, I'm sure the spare sensor it wired up for a 36-1 or cam sensor pulley but I've never used it. i'm just using it how a standard 2wd and 4x4 set up is using the dizzy
I also bought extensions for icv and tps due to buying a hart plenum which cost me £15 each. These extensions are included and are braided and made by Ryan.
Switchs for anti lag and launch control will be included.
A standard loom costs £400 and mine was over £500, plus twin amp brackets cost £30 then what ever the amps cost to run wasted spark.
Loom + extentions, twin amps and bracket to mount them. £350
Monitor is £220
Buy both for £550 delivered
I will add pictures ASAP.
Old Apr 14, 2011 | 07:53 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Now that sounds seriously sexy...
Old Apr 14, 2011 | 08:33 PM
B13 JUS's Avatar
B13 JUS
Get it bought lol
Old Apr 16, 2011 | 12:06 PM
B13 JUS's Avatar
B13 JUS
updated advert to say what you get with loom.
loom
extensions
2x amps
twin amp bracket to mount them
£350
Old Apr 16, 2011 | 02:31 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Somebody buy the loom
Steve
Old Apr 16, 2011 | 04:02 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Come on tempt me with some pics. Also the secs monitor
Old Apr 16, 2011 | 05:30 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
What are the benefits of this loom?
Old Apr 16, 2011 | 06:13 PM
B13 JUS's Avatar
B13 JUS
I'll sort some out tomorrow mate
Old Apr 16, 2011 | 06:18 PM
B13 JUS's Avatar
B13 JUS
The standard loom is now 20+ years old which can start to break down and cause you problems.
They look much neater in your engine bay and are not as bulky as a standard loom.
You can run wasted spark and closed loop fueling.
Old Apr 16, 2011 | 06:57 PM
ital_cossie's Avatar
ital_cossie
hi, the lomm is lhd or rhd?
Old Apr 16, 2011 | 07:18 PM
B13 JUS's Avatar
B13 JUS
It's a rhd car but I can't see there been any different because everything is still on the same side of the engine if it's left or right hand drive.
Old Apr 16, 2011 | 07:23 PM
capri280's Avatar
capri280
can you give me a call on 07815 879956 to sort out secs monitor
Eugene
Old Apr 16, 2011 | 07:32 PM
B13 JUS's Avatar
B13 JUS
Eugene
I do have someone wanting the monitor already mate but the loom needs to sell first or both sell together.
Old Apr 16, 2011 | 09:57 PM
dakunia's Avatar
dakunia
ECU is on opposite side mate. Yours is on left siede, and LHD cars have it on right side. So LHD loom could be a bit longer probably.
maciek
Old Apr 17, 2011 | 01:27 PM
B13 JUS's Avatar
B13 JUS
here some pictures
you can have the loom as in the picture or could fit it under the rail so it can't be seen.
everything all marked up so you cant go wrong in fitting it
Old Apr 17, 2011 | 01:29 PM
B13 JUS's Avatar
B13 JUS
here's some pictures of the monitor, it has other screen modes but just took a few.
Old Apr 17, 2011 | 09:29 PM
cossie09's Avatar
cossie09
hi,is the loom from the ecu or from under the bonnet
Old Apr 18, 2011 | 08:17 AM
B13 JUS's Avatar
B13 JUS
the loom feeds through the bulk head and plugs into the ecu inside the car
Old Apr 18, 2011 | 01:52 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve
Old Apr 18, 2011 | 03:52 PM
R5FORD's Avatar
R5FORD
have you got the water injection loom for the SECS monitor?
Old Jun 17, 2011 | 05:49 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Were do you connect the white 6 pins connector too???
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
jdsjojo
Aug 1, 2015 08:50 PM
