'COSSIE RICH SPEC GT30' - GT3071 - 4" inlet - .82 backend - internal gate - 450bhp
Old Jul 4, 2009 | 01:08 PM
B13 JUS's Avatar
B13 JUS
Default 'COSSIE RICH SPEC GT30' - GT3071 - 4" inlet - .82 backend - internal gate - 450bhp
GT3071 for sale.
Same spec as cossie rich's that made 453 on a set of DD rollers recently on a standard YB head with a BD14 inlet
Comes complete with:
Surge ported inlet housing
V band adaptor outlet
V band itself
The V band portion you need to weld onto your existing downpipe (3" needed)
Actuator (needs bracket sorting for how you orientate it, so you will need to do that)
£900 with fittings
i bought this from chip about 6 months ago but never used it. so its still brand new.
These are 1430 dollars in the states for a bare turbo currently from ATP
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
Thats without the surge ported front housing, without the actuator and without the v aband adaptor outlet or fittings, that lot pushes it up to well over 1600 dollars, and then you have to get it here!
Brand new, genuine garrett
[IMG]file:///C:/Users/ACER_O%7E1/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
Old Jul 4, 2009 | 02:44 PM
boXXer's Avatar
boXXer
GASH!
VERY VERY tempted........
Whats the "v" band bit all about then? i hear it mentioned quite often
Old Jul 4, 2009 | 03:55 PM
B13 JUS's Avatar
B13 JUS
you need to cut about 15mm of the end of your exhaust (where it joins the turbo) and weld the v band adaptor so you use a v band to fasten the exhaust to turbo. not the 3 bolts
but when i've been looking it might fasten up without cutting the exhaust as the exhaust is a simlar shape to the v band anyway. (i may be wrong)
Old Jul 5, 2009 | 02:05 PM
boXXer's Avatar
boXXer
GASH!
ah i get it now. Basically you have to change th flange on the exhaust pipe to fit the GT series. Do they not do 3bolt housings?
Old Jul 5, 2009 | 05:16 PM
B13 JUS's Avatar
B13 JUS
yeah thats right.
i've seen a 4 bolt housing but not a 3. i'm sure someone must sell one so you don't need to change the flange.
Old Jul 6, 2009 | 05:50 AM
- Sim -'s Avatar
- Sim -
,82 housing, when will it start to produce boost then?
if there is headwork, can it be earlier?
Old Jul 6, 2009 | 06:01 AM
B13 JUS's Avatar
B13 JUS
i've been told they start to produce boost like a t34
Old Jul 6, 2009 | 06:02 AM
- Sim -'s Avatar
- Sim -
hmm
a T34 has a much smaller exhaust side, 0,63 or even smaller...
Old Jul 6, 2009 | 10:04 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
hmm
The size cannot be compared across turbos, it is the aspect ratio between the turbine wheel and the turbine housing.
Old Jul 6, 2009 | 11:16 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
SIM,
over 2 bar at 4k on mine
Old Jul 6, 2009 | 01:28 PM
B13 JUS's Avatar
B13 JUS
SOLD
Old Jul 6, 2009 | 06:11 PM
boXXer's Avatar
boXXer
GASH!
boo hoo, lol
Old Jul 6, 2009 | 07:25 PM
CossieRich's Avatar
CossieRich
not surprised it sold. Great turbo
Old Jul 6, 2009 | 07:33 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Not surprised it sold so quick at that price, they are about 100 quid more than that from me now thanks to the weak pound sadly!
Old Jul 6, 2009 | 08:55 PM
boXXer's Avatar
boXXer
GASH!
next time
Old Jul 7, 2009 | 07:10 AM
CossieRich's Avatar
CossieRich
Its actually a 480bhp turbo all factors being correct on the engine its going on
jessie_rs
62
Aug 6, 2019 09:27 PM
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Rsmat
63
Sep 25, 2015 12:11 PM
