Bit of an engine problem! Blocks apart
Old Jan 16, 2018 | 06:09 PM
  #321
Yeah def.
Not sure what twin plate I’ll be using yet. It will be 7.25 inch as well though
Cheer Paul
Old May 12, 2018 | 08:55 PM
  #322
eBay covers on my door cards rears done. No way I’m paying for another standard set just for them to shrink again
Old May 12, 2018 | 09:23 PM
  #323
They look lovely mate .
Old May 12, 2018 | 09:25 PM
  #324
There not perfect but there certainly do for cheap covers. Last set of mint standard ones I got was a lot of money certainly not doing it again as there shrink again
Old May 13, 2018 | 10:42 AM
  #325
Get some better pics up Andy.
They look far better than the shrunk std ones.
Paul
Old May 13, 2018 | 03:59 PM
  #326
Originally Posted by costina
Oh nice i like that.
Can you get them new?
Look for audi 80 v6's they came with the cover on the back of the alternator plus ducting to help with airflow to it.
Haynes of challows down near wantage used to get them in every so often. Been years since i've been there though
If you get stuck let me know and i'll ask an audi breaker I know if he has one.
Old May 13, 2018 | 06:06 PM
  #327
pectelboy's Avatar
pectelboy
I've got one here , if you need one never going to use it
Old May 13, 2018 | 06:22 PM
  #328
Challow now that's an old school scrap yard lol
Only problem I find is anything ford related has been had by someone I know who lives only 7 miles away.
Always worth a trip out with a big toolbag 😂
Old May 13, 2018 | 08:53 PM
  #329
Yeah I used to go quite frequently and normally used to end up getting quite a few bits each visit. Every so often you will strike gold with a car in there.
First visit I ever went and they had seven nissan 300 twin turbo's in there all with the same style damage, rear into a post or tree. The engine's/box's had all gone but the majority was still there.
Old May 14, 2018 | 06:30 AM
  #330
I have the same AIM and same aux LED's in my escos, its been a right headache to hook up all the aux lights etc, also noticed was the Aux LED's are always dimly lit due to low voltage getting to them when they are meant to be off, once full voltage they go twice as bright.
I have a seperate AIM fuel pressure sensor on my FPR and also oil pressure direct, mine is linked to my SM4
Old May 14, 2018 | 08:13 AM
  #331
Ive not wired mine in yet it looks pretty simple to configure. If my LED’s light up all the time I’ll fit some resistors
Old May 14, 2018 | 03:02 PM
  #332
I think you could also fit a tiny relay to make sure there is no leaky voltage.
Old May 14, 2018 | 05:10 PM
  #333
Yep definitely I could take that route. Once it’s running and I’ve fitted the dash Ill know what it dose. If a little voltage dose keep the LED warnings on Maplins and Halfords are round the corner lol it will get sorted in an hour or so
Old May 14, 2018 | 05:19 PM
  #334
Trying to get everything wired in, all road signals, abs, washer fluid level handbrake and so on, in behind dash all nice and neat isnt easy, limited space, limited original cable lengths etc etc, i also have a fuel sender damper unit wired in so the level isnt all over the place on the AIM, inverter for the escos banana pod guages, then the actual AIM loom is bulky, i have a Wideband beside AIM too, sequential gear indicator cabling, RS232 to SM4 wires, i have diodes fitted for the indicators wires to AIM as the dash was flashing quick, i have a small loom made up linking my AUX LED's on a fuse even with 2-3v they light up dimly but i'll live with that, all good fun
The AIM isnt too bad to configure once you get the jist of it all
Old May 14, 2018 | 05:20 PM
  #335
That is a good point where space is at a premium
Old May 14, 2018 | 06:02 PM
  #336
I’ve the lead to link my dash to my sm4. That will save a few gauges lol. I’ve a stack fuel gauge and afr gauge and I’ll keep my 3 bar boost gauge. My dash is a road one so only extra LED’s I’ll have is park brake high beam and ABS. There’s a fair bit of room behind the saff clocks so I’ll be fine with wiring space.
Old May 14, 2018 | 06:12 PM
  #337
Default Mine, strada road
Old May 14, 2018 | 06:17 PM
  #338
Looks wicked I’m really looking forward to getting on with mine if I’m honest I like the tinkering and building best lol
Old May 14, 2018 | 06:36 PM
  #339
Wow, love that escos.
I love the tinkering too
Old May 14, 2018 | 06:46 PM
  #340
I like tinkering also when I can be fooked. It takes me a while to get wound up to do any work on my cossie but once I get stuck in I enjoy it.
Old Jun 17, 2018 | 02:42 PM
  #341
Got a different gearbox for my old boat just needs a little attention lol. I’ve the bits to rebuild it now It’s a TR3550 TKO
Also got my front door covers now so can get my front door cards re trimmed. Need to send my bell housing off to be modded for this gear box and order the new type fuel pump mark uses at high horse power levels
Old Jun 17, 2018 | 03:44 PM
  #342
Nice gearbox. I am swapping to that fuel pump too
Old Jul 6, 2018 | 12:15 PM
  #343
Picked up my manifold this morning ceramic coated and the fuel pump I’ll now use to feed the fuel rail.
Old Jul 6, 2018 | 12:40 PM
  #344
andy ,why didnt you go with the tko600 mate?
Old Jul 6, 2018 | 12:46 PM
  #345
The box I’m using is rods old box. It’s a good box that stood the test of time with a lot of torque chucked at it so a shame for it to go to waste. It’s a bit of a Frankenstein box as well. It has the later tko 500 mainshaft that’s the same thickness end too end. Which also has the larger rear main shaft bearing. Now has the 500/600 one piece counter shaft as well and carbon synchro’s on 2nd 3rd and 4th. Will be plenty man enough for mine
Old Jul 13, 2018 | 04:24 PM
  #346
Got my front door cards covered today. Obviously look a little different to standard being the eBay covers. The seams being the main difference but a million times better than the original ones with shrinking leather. So I’m happy as this option should last if I got a set of standard ones again there just shrink as they have now.
Old Jul 13, 2018 | 08:01 PM
  #347
They look nice. Did they glue easily?
Need to do mine at some point
Old Jul 13, 2018 | 08:04 PM
  #348
I let the local trimmer fit them. Much better job than I could do plus he has all the proper gear
Old Jul 13, 2018 | 08:24 PM
  #349
Good man stuff like that can be a real pain in the rs
Old Jul 13, 2018 | 08:35 PM
  #350
I needed them to look as good as they possibly could. There never look as nice as the standard ones but I can’t fit another set of them just to watch them shrink over time
Old Jul 13, 2018 | 08:36 PM
  #351
Manifold looks shit hot
Old Jul 13, 2018 | 08:37 PM
  #352
Yeah it dose look nice very well made. Will look a lot better bolted to an engine lol
Old Jul 13, 2018 | 08:50 PM
  #353
Spot on do it once👍
Old Jul 13, 2018 | 08:52 PM
  #354
Lol when you planning for the big bolt together
Old Jul 14, 2018 | 11:10 AM
  #355
I’m hoping this year but the years passing fast now. Only so many little jobs I can do I’m pretty stuck now.
Old Jul 14, 2018 | 01:41 PM
  #356
Look forward to it mate
Old Sep 13, 2018 | 06:39 PM
  #357
Had my old girl at work this week disheartening seeing it like this. Looks like a barn find now lol. But it was a productive ish week. Battery in boot wired up new fuel pump and filter fitted. Dash wiring sorted ready for my aim dash. Stack fuel gauge fitted. ECU wheel speed sensor fitted. And I got my bell housing so I can send it off to be modified for my tremec. Small steps but in the right direction!
Old Sep 13, 2018 | 06:58 PM
  #358
Albertodelgado's Avatar
Albertodelgado
looking good
What tyre size R888 you're running in front ?
Old Sep 13, 2018 | 07:02 PM
  #359
It's the best colour too eh.
Old Sep 13, 2018 | 07:05 PM
  #360
Originally Posted by Albertodelgado
looking good
205 40 17
