Bit of an engine problem! Blocks apart
#361
cossie fan (unluckerly)
Got my front door cards covered today. Obviously look a little different to standard being the eBay covers. The seams being the main difference but a million times better than the original ones with shrinking leather. So I’m happy as this option should last if I got a set of standard ones again there just shrink as they have now.
Certainly better than shrunk ones tho
#363
There not ideal but I’m too far past show and shine now so just happy there covered and look neat. Buying another standard set was just not an option as there just shrink again
#364
i hear that mate - im using a pair of early saph front door cards which were given to me for free so i painted them satin black. The rears have been retrimmed in black suede/alcantara material as has my roof so just wanted a pair of black doorcards on the front.
Ive even bought a spare set of leather doorcards cheap but the leather has already shrunk on those so may get them retrimmed all at the same time so i have a matching set
#370
Very nice what's next mate?
#371
Well I want to put it back together. I’m hoping that happens in the next year. I may send the car to a local fabricator with my old block. Get them to fit that in the car with the gearbox so they can make a gearbox mount and mod the prop. That way that’s all ready for when I get my engine
#372
Look forward to seeing it come together mate
#373
Is the engine just waiting for you to collect it now?
or still being built?
Cheers Paul
Cheers Paul
#375
Well it’s time just gathering the last few bits then my old boat goes back together. Turbo and waste gate paid for just waiting till they turn up. I’ll bolt up the in let manifold before lifting the engine in. It’s booked into Edwards Motorsport on the 6/9 for a turbo back 3.5 inch exhaust system. I’ll bolt all my bits up the last week of August I’m looking forward to it!!
#377
Well it’s time just gathering the last few bits then my old boat goes back together. Turbo and waste gate paid for just waiting till they turn up. I’ll bolt up the in let manifold being lifting the engine in. It’s booked into Edwards Motorsport on the 6/9 for a turbo back 3.5 inch exhaust system. I’ll bolt all my bits up the last of August I’m looking forward to it!!
Did mad build the motor for you mate ?
#378
Yeah I see it up there. Be worth the wait mate. The 8474 will do 650 maybe some more. Will have to see what it makes. Be plenty quick enough for a road car
#381
Well cars at work now so I’ll start to put it together. I’ve a long long list of stuff to do lol hopefully it’s ready for exhaust on the 6/9th as it’s booked in at edwards motorsport for a full 3.5 inch system.
#382
Fitted a new tiki ton clutch master to match my bearing and a new fluid pot. Also some heat reflective tape to the inner wing as there not be much room in there. Hopefully I’ll lift the engine in tonight
#385
Engine in is a great milestone 👍
#390
smiley (04-08-2021)
#391
Great progress. The shiny parts can be changed at a later date once it up and running. What’s still to be done before starting/mapping
#392
Nice to see it built 😎
#393
I’ve the last week of August off to wire the dash in fit my door cards run a live from the back to front. Finish any little bits. Overall the drive shafts bleed the brakes. Plus if it can’t go away for it. Fit the gearbox mod the cross member and the get the prop done. It gets shipped off for a full turbo back 3.5 inch exhaust system on the 6/9. Then will go to marks.
#394
What's cost of a tremec james looking at options for the 3dr
#395
I only had to re build mine. New lay shaft new 3rd gear new synchros and bearings. I can’t remember what the cost of the bell housing conversion plate from Reyland was. I’m sure a new one is about 2500 or something
smiley (05-08-2021)
#397
Few breather pipes to sort out. Had to order a new boost hose turbo to intercooler as the old one didn’t fit. I’ve got some nimbus sheet as well as I need to make a heat shield around the brake master. It will get there.
#399
Been chipping away at my old smoker. Pretty much done under the bonnet now. Breather and wastegate plumbed in. Ran a live from the front to back to power it up. Started to wire in the dash and fitted the link lead to my ecu. Had a problem with my brake accumulator pump burning it’s self out as I didn’t have fluid in the reservoir lol. But changed that now. Abs light and park/brake warning lights work. Car should be going to Andy Robinson race cars this week. He will fit the tremec as they can make a crossmember and do the prop shaft at the same time. Coming together now but the dam thing is fighting me every stage lol I think it liked resting up in the garage!
turbotrev (18-08-2021)
#400
Popped up and see my car today as it’s at a local specialist having the box fitted. There mod the floor build a crossmember and mod the prop shaft. Looks like there going to do the exhaust as well so could be there a while. But all things that need doing properly
boost monster (24-08-2021)
