Old Feb 12, 2017 | 07:43 AM
  #1361
Originally Posted by markk
Something will break. You have rubber/plastic in the engine mounts and box mounts andca rotating shaft with a floating center mount bearing, of course you have movement and movement creates misalignment in any driveshaft.
I never speak without having experience. Been there done that.
Makes sense, I assumed the rest of the movement in the slider and uj along with the rubber centre bearing would take up any movement. I didn't think the donut / doughnut was supposed to be used to take up any flex like a uj as that would lead to it failing? (I think...but may be wrong). I thought it was only there to take up shunt for nvh.
I have the new donut so I can bolt it in as standard....just wanted to remove a possible point of future failure, I assumed the big torque had lead to the premature failure of the last one....that and also the previous mis alignment when my engine mount broke up and allowed the engine to lean over a bit.
I do appreciate all comments though as I appreciate most of you on here have far more experience than me and know much more....this is a learning project for me.
Old Feb 12, 2017 | 09:11 AM
  #1362
No worries, nothing worse than throwing money at something that has already proved to fail.
Better to find out than take an expensive gear to destruction.
Old Feb 12, 2017 | 01:37 PM
  #1363
Just for you Markk. Thought I would give it a go
Old Feb 12, 2017 | 01:49 PM
  #1364
It's just for you mate, don't want your next post showing the gearbox tailcase hanging off in several bits 😁
Old Feb 12, 2017 | 05:34 PM
  #1365
It is all back together and on its wheels. Rears are toeing out loads so need to check the geo.
Went to drive it around the block and it won't start...I had already had the intlet and exchaust manifolds off along with the injectors and fuel rail so it will be a case of re-checking everything. I will whip the plugs out to and check for spark, probably something silly. I may have just flooded it.
Old Feb 12, 2017 | 06:07 PM
  #1366
I fort I was the one that had the bad look mate .
it will be something simple I bet
Old Feb 12, 2017 | 06:34 PM
  #1367
Yeah, neither of us have been lucky. I have a feeling that I flooded it but will check the plugs in the morning, if not then it will be something daft.
Old Feb 12, 2017 | 07:28 PM
  #1368
Just bought a lathe......MK motorsport is on borrowed time......I will be knocking out round stuff very soon........how do they work?
Old Feb 12, 2017 | 09:10 PM
  #1369
Jay,'s Avatar
Jay,
Sponsor
Fuckin lol
Old Feb 13, 2017 | 06:56 AM
  #1370
Originally Posted by Jay,
Fuckin lol
After I bought it I did realise that I have never even used a lathe before, I guess I will be watching lots of you tube vids. I don't think the motorsport world has much to worry about in reality....I don't even know where to buy the metal.
Old Feb 13, 2017 | 08:07 AM
  #1371
Jay,'s Avatar
Jay,
Sponsor
Is it CNC lathe Toby ?
Old Feb 13, 2017 | 08:14 AM
  #1372
No, only an old myford 7, nothing big or fancy. I will only be using it for very basic bits that need turning down or making.
Old Feb 13, 2017 | 07:41 PM
  #1373
OMG Toby you do no they use sharp tools lol
you will love it mate that's me out off a job lol
Old Feb 13, 2017 | 07:58 PM
  #1374
Been watching a few you tube guides and learning lots already, got a lot to learn before I have even a small % of what you know.
I think I have found the problem as to why the car won't start. Mark Shead gave me a few pointers and I have found that now the engine is back exactly where it should be the crank sensor is pushing on the anti roll bar, I think it has moved the sensor. I will check it tomorrow and hope the pulley has not hit the sensor.....more little things to sort in the development.
Old Feb 13, 2017 | 08:49 PM
  #1375
Awesome mate i'll have an alloy block please ���� hope you suss the problem
Old Feb 13, 2017 | 08:53 PM
  #1376
Lol, you might need to wait a bit longer on the block....I haven't watched the second part of the how to on you tube yet...I expect that is near the end.
Old Feb 14, 2017 | 10:19 AM
  #1377
Lol
Old Feb 14, 2017 | 01:07 PM
  #1378
It's Alive.
It wasn't the crank trigger after all, it was the little plug in the dizzy cap that has the hall sensor on it, the plug had come off whilst I had put the hart inlet back on...starts on first click of the key now.
Will take it out briefly later...even though the rear geo is out.
Thanks to Mark Shead for his hints n tips
Old Feb 14, 2017 | 03:54 PM
  #1379
Well I have now driven it with the 6 degree in there......what a load of old rubbish, wish I hadn't bothered...........
NOT, It is brilliant, even though it is on nothing more than base settings the camber is closer to where it should be, it doesn't squat as much and feels very well planted. No knocks or noises. I am looking forward to dialling in the settings and seeing what it can really do. Just need to work out what feels best after I set the ride height and then get it corner weighted and setup properly.
Very impressed.
Old Feb 14, 2017 | 03:57 PM
  #1380
Jay,'s Avatar
Jay,
Sponsor
Very impressed.
told you I didn't think it was going to be all that either lol but it is night and day and the amount of understeer you loose is brilliant
Old Feb 14, 2017 | 04:04 PM
  #1381
Power slides on round abouts never felt better
Old Feb 14, 2017 | 04:09 PM
  #1382
Jay,'s Avatar
Jay,
Sponsor
Originally Posted by 800bhp
Power slides on road abouts never felt better
Hahaha defomore controllable
Old Feb 15, 2017 | 05:15 PM
  #1383
Grabbed an hour tonight, set the rear ride height and checked the geo, it was 2 deg neg camber and over 1 degree tow out, so have adjusted and current is at 1.6 neg and 30 degrees toe in now, will get it to 1 deg neg camber and 25 degrees toe In to see how that feels, that should be 3mm overall toe in based on 16 inch wheel. Just need to re centre the wheel in the arch then measure and re set then test. I like how easy the 6 degree is to adjust.
Old Feb 15, 2017 | 08:19 PM
  #1384
Thursday is Lathe pickup day.......
Old Feb 16, 2017 | 10:31 AM
  #1385
Jay,'s Avatar
Jay,
Sponsor
Ill have some group a top mounts for starters lol
Old Feb 16, 2017 | 10:45 AM
  #1386
MONSTER's Avatar
MONSTER
Nowt wrong with a Super 7, I use one every day and you'd be surprised what you can make out of a bit of round bar
Old Feb 16, 2017 | 04:42 PM
  #1387
Really pleased with it, lovely condition, it was the blokes dads from brand new, he was 75 and a proper gent.
Old Feb 17, 2017 | 06:19 AM
  #1388
Glad your happy with the lathe mate now let's see wot you can make on it
Old Feb 17, 2017 | 09:05 AM
  #1389
I have ordered some bar stock to practice on, I will send pics from A & E lol
Old Feb 17, 2017 | 09:07 AM
  #1390
I made this last night, I know it is a bit rough but not bad for the first time on a lathe? I got it running so will make an RC car to fit it in next
Old Feb 17, 2017 | 09:41 AM
  #1391
Old Feb 17, 2017 | 10:11 AM
  #1392
Jay,'s Avatar
Jay,
Sponsor
You Tit Toby
Old Feb 18, 2017 | 04:35 PM
  #1393
Today I got the rear tracking to the desired 3mm toe in (about 25 degrees on a 16 inch wheel). 1.3 deg of neg camber to they that and the wheels look nice and centred in the arches. Went for a run out and it no longer squats under full power, had only one little slide but that was due to a less than straight bit of road, full power in 2nd and it didn't even really need any oppo, it just pulled out of it.
Very impressed with the 6 degree beam, Mark Shead, Jay and MK plus others said they are night and day different, I guess it could also benefit me more due to the short wheel base?
Just need to fix the 4th gear jump out but I think the box will need to come out and go to Bara.
Old Feb 18, 2017 | 07:16 PM
  #1394
Sounds great mate, shame about the 4th gear issue hope its a quick fix
Old Feb 18, 2017 | 09:25 PM
  #1395
I suppose you mean 25 minutes instead of degrees, otherwise the wheels would almost be perpendiculair under the car.
Good that you've happy with the 6 degree beam. It indeed makes the car understeer a lot less and also makes it more predictable. I wouldn't think that it makes it squat less though. Perhaps you have set the ride height higher now, which does reduce squat.
Old Feb 19, 2017 | 08:33 AM
  #1396
Thanks Marc, yes minutes...oops
I did raise the ride height at the same time so probably explains that then.
Old Feb 19, 2017 | 09:28 AM
  #1397
Glad it's going ok for you at last Toby any photos of the new lathe ??
Old Feb 19, 2017 | 10:23 AM
  #1398
I was going to contact you, Ian. The bloke that sold it to me turned on the switch and then pulled the lever to tighten and engage the drive belt, this seems odd to me as you are reaching over the chuck then moving your hand back over the turning chuck. Is there a reason not to engage belt and then turn on switch or is it too much load on the switch? It was supplied new to his dad in 1951
Old Feb 19, 2017 | 01:30 PM
  #1399
As I don't no this lathe I could not say but on
my lathe I have to reach over the top to engage the drive to the chuck in my photo it's the top lever on the left witch I then pull to the right and the fun begins 😀😀
Old Feb 19, 2017 | 02:07 PM
  #1400
oh, my-ford... that suits well in here...
however, old british steel... you can bet it's a very good lathe. you'll take some great precisions out of it.
great find man!
