YB 200 block cost new
3.5k that's mad Ł
i wonder how many of them they have sold
i wonder wot the price from ford was back on the day
it's the next mod for my focos a 200 block but not at them prices
The alloy block does de value a new 200 block but any decent one has to be worth Ł2k but that would just convince me to pay the extra for the alloy one. (I plan to go 2.2 or 2.4 depending on how mr Shead wants to spec it)
I'd never pay that in a million years lol I got a used 200 block from my motorsport for 500 then had liners fitted far cheaper
so this was a good deal then you think?
Brand new cosworth 200 block standard bore,brand new ggr pistons standard size & compression ,new arp main cap stud & nut kit,new arp head stud & nut kit,new 2wd 80psi high pressure oil pump,kent bd14 inlet cam useD but mint.
Ł1700.
Ł1700.
That's a good deal for sure. I've seen used 200 blocks on standard bore fetch Ł1000. If it's a Turkish 99 cast block you could get them for Ł800 new a few years back run one in my car for a while, their not as strong as an original 200 block but only break when silly power are put through them.
Ł1700.
Ł1700.
My low miles, standard bore, bare production block sold for Ł1500 recently, took a while to go but the buyer was over the moon when he found my advert.
Alloy is the way to go these days but I would say that is the going rate now for a new 200 block with the extras in the deal
I will message you later his number
Off the top of my head the spec is as follows
200 block
Squirt jets
6 long studs
( think it .5 over size )
Balanced crank
Spot peened rods
Cosworth racing pistons
( can't remember if it's a 2wd/4wd or dry sumped )
Either way they can be changed but think it did end up
Wet sumped
Wrc h/gasket
4x4 head
Fully ported by Neil roper
New guides
Re cut seats ( either that or new ones )
I have prob missed something
He had a few Messers so please be sure its
Along the lines of what your after please
200 block
Squirt jets
6 long studs
Balanced crank
Spot peened rods
Wet sumped
Wrc h/gasket
4x4 head
New guides
It is cheap to have squirt jets and studs in them, those are options but you are right, I guess you would need another Ł2k for an arrow crank and the rods n Pistons. Plus head work, cam(s), new oil pump and someone to bolt it together....plus gaskets and other little bits.
Apples for apples a new alloy block is about Ł2k more than the same spec new 200 block, after that all the add ons apply to both anyway!
So a fully built up like for like engine is just Ł2k more going the alloy route.
They weigh half that of a 200 block, in my single seater 25kg is a massive saving which is why I sold my 200 one and plan to replace it with an alloy version.
That's the extra oil sray jets crank them two are expensive
i can't see the point myself in using an alloy block without a proper crank. I stopped at changing my crank as standard is good for what I won't. Others who can afford it fair play as then you have more options.
I get what you are saying but you could keep it all the same. I must admit that the crank cost puts me off and if you are going large on most of it you might as well build the ultimate. Odd thing is, I don't want any more power but love the concept and my YB is a little smokey, despite having good leak down and compression.
Totally mate, you are going for much more power than me and Marks engines have proven this power without the need for the block, I am not dissing yours at all. To be honest the attraction for me is the weight saving. I love the idea of 2.2 but don't need it, I just feel that if I rebuild it I want something interesting to try. 500bhp is easily enough for my little road car.
Be more than 2 grand if done properly soon adds up. I payed 500 for a block 1500 for liners 250 for a standard crack. 2 grand for pistons and rods 700 for long studs I think and about a grand for machining that included a line bore on the crank journals. That's 5 1/2 grand that block will be good for 650-700 bhp im told. With out doubt the alloy is far better you can have more cc and go strocker. But will cost a fair bit more than 2 grand extra or I'd be doing it.
That not even taking into account the smith and jones
New Head as well
A nice piece of kit tho that works
As I said, a like for like spec build with only the alloy block being the difference then it simply now adds Ł2k to my budget, but saves 25kg in weight.
The alloy block doesn't work out much more than buying a 200 block at current prices and having it linered. In the long run when a linered 200 block needs the liners replacing, it's another Ł1400 to buy and for them, the alloy block the liners are Ł100 each and u can fit them yourself. Alloy is the way forward for sure.
I just went and bought 2 boxes of cat litter, 16kg in each. I had to carry them from the shop to the car, probably 300 meters away...32kg at the end of that I was thinking hmmm 25kg saving on the front axle is a massive amount of weight, by the time I put on the rear carbon fibre boot lid I am over 32kg saved.
The thing I cannot get my head around is if you go for 2.2 or 2.4 then you are not going to rev it that hard, do you therefore need cams and pocketed pistons? I get that you don't want a really old crank in there but my car has only done 36k on the engine...?
I expect I just need to be patient and save up for the full spec engine, cams, crank, Rods and Pistons and hope that I can re-use my head after it has had some porting done and a rebuild.
Would a 2.2 or 2.4 ever be revved above 7,000 rpm?
A linered 200 block and decent crank all in good condition would be fine for 6/700hp
