Old May 20, 2016 | 09:24 AM
  #961
Originally Posted by smiley
At least you know it will be all new mate best way going hydraulic clutch?
Yeah, thats the way I see it.
I converted the 205 pedal box to hydraulic clutch a while ago by welding in a plate to take the Reyland Master cylinder and I used that on a Tilton centre push on the GTR but this time I am going with the external slave cylinder as per the reyland mod so that I can swap out the slave without taking the whole box out of the car as I had a few issues previously that meant the box had to come out to sort it.
I am using a paddle clutch with high pressure helix cover and these would make the cable too uncomfortable so really needs to be hydraulic, Reyland even says on his site that you must upgrade to this to use that plate.
1-2 weeks should see the box here and in the car, Prop shaft services have nearly done the front prop and we are just waiting to measure how much I need to adapt the rear by as the 205 shell is shorter than the Sierra.
Old May 20, 2016 | 09:48 AM
  #962
Great stuff I will have to get some contact numbers from you at some point as I will need to do the same with my props shells not been started yet so plenty of time
Old May 20, 2016 | 10:03 AM
  #963
James Porter's Avatar
James Porter
Looking good mate
Old May 22, 2016 | 10:21 AM
  #964
Mounted up the toucan display and managed to get a rare 5 button 205 panel instead of the normal 3 button. So now I have the high and low boost switch and anti lag on the panel. Launch and anti lag can be operated by one of the toucan screens
Here is toucan on one of the multi dial screens, Mark made the Ecu talk to it so everything the Ecu readers on its own dial
Old May 22, 2016 | 10:25 AM
  #965
Here it is on throttle position, each dial has a min and max tell tale so you can see it has read 100%
Old May 22, 2016 | 10:27 AM
  #966
Here it is on page 1 of list mode, loads of info
Old May 22, 2016 | 10:31 AM
  #967
They do look good just too small for my liking really,
But that said it's great to have any display the shows real time ecu data
Old May 22, 2016 | 10:51 AM
  #968
When you press one gauge they are about the size of your typical after market temp or oil pressure gauges but I know what you mean, I was on their site yesterday seeing if they had launched any bigger ones, it would be nice to have one about the size of an iPad mini
Old May 22, 2016 | 08:44 PM
  #969
It won't be long before it can go to the trimmers for carpet
Old May 28, 2016 | 09:40 AM
  #970
Propshaft services called me as I sent them some second hand front and rear props to be adjusted to suit the 25mm difference in the oppliger box. They said that on the cossie they used very high quality universal joints but the front one I sent had been replaced with a poor quality one that was showing signs of torque twist so they are building me a completely new prop with the best quality that they can do.
I had a good measure up today for the rear prop as my car is different to the saph for length, my total wheel base is 19cm shorter than the saph.
Old May 28, 2016 | 01:44 PM
  #971
It should be all be good when you get them back then mate . All I can say is you did well to get a phone call as I ended up sending a email to the MD as I had asked for the full price befor they started on making my prop . When the MD come back to me the prop was made and ready to be shipped . It end up I picked it up and the woman was going to charge me the full price to witch I said I'm hear picking it up the lad said nock Ł18 off the bill . The propshaft is 100% spot on very happy with it but they need to work on there communication skills .
Old May 28, 2016 | 01:46 PM
  #972
Prop shaft services are spot on we use them loads at work have done for years there do you well
Old May 28, 2016 | 09:02 PM
  #973
They have called me quite a few times asking this and that, I am very impressed with them
Old May 29, 2016 | 02:12 PM
  #974
Jay,'s Avatar
Jay,
Sponsor
Yep used propshaft services for years and never had a issue
Nice progress Toby
Old May 29, 2016 | 03:57 PM
  #975
I think I have done virtually everything I can until MK sends me the rest of my comp struts, arb and pin kit plus the arrival of the oppliger box. Clutch is in and centred on the cover, the new header tank is in and plumbed and all fluids waiting to go. Prop shafts now all measured, posted and ordered.
Quick shift should be on its way to Bara from oppliger. Just need to decide on a gear knob now.
Old Jun 2, 2016 | 11:40 AM
  #976
shark91's Avatar
shark91
congratulation it's a very good project
Old Jun 4, 2016 | 04:54 PM
  #977
I do hope your parts do start turning up soon mate
Old Jun 4, 2016 | 08:54 PM
  #978
Front prop arrived today. Pete from spec r has promised post. Box is done and waiting on quick shift from oppliger. New intercooler has shipped. MK is just plating my comp struts and shod post next week.....getting close to being back on the road. I can't wait to try the new box.
My 6 degree beam should be done in 3 weeks. Then off to trimmers before corner weights and then new suspension to suit.
Old Jun 4, 2016 | 09:39 PM
  #979
Sounding good Toby
Old Jun 6, 2016 | 05:35 PM
  #980
Romain Oppliger still is not responding after I paid for his quick shift kit, the box is all done and waiting for just the shifter. I have put some posts on Facebook too.
Old Jun 7, 2016 | 06:57 PM
  #981
Looks like Romain might be posting weds and my spec r swirl pot turned up today. Pete's products are so nice.
Old Jun 10, 2016 | 03:46 PM
  #982
Still nowt from oppliger on the shifter.
But Mark from MK is keeping me well informed and this is about to be posted to me. Plated and coated
Old Jun 10, 2016 | 03:55 PM
  #983
When it arrives I will have a good measure up and see if one could ever fit the rear of the car. My plan is to have nice supple suspension so the arb will need to work well.
Old Jun 10, 2016 | 06:01 PM
  #984
Looks wicked mate nice parts!
Old Jun 10, 2016 | 06:39 PM
  #985
Now that sounds like a very sensible plan.
Old Jun 10, 2016 | 07:46 PM
  #986
I was talking to MK today and he thinks a rear bladed arb will fit so he is making a 6 degree beam to suit and this will be modded to accept my supra diff without any adapted kit.
Old Jun 11, 2016 | 10:56 AM
  #987
So your going the same way as me then Toby no fitting kit
Old Jun 11, 2016 | 02:04 PM
  #988
Yeah, you gave me the idea a while ago...makes sense really
Old Jun 13, 2016 | 07:54 PM
  #989
first time i've seen this one,
i read this thread from the start, (not everything, it was too much)...
man ! awesome build/restoring on this one!
great job !!
looking forward for next updates...
Old Jun 13, 2016 | 08:08 PM
  #990
Big changes about to be added, 6 des beam being done, front and rear bladed arb, compression struts, adjustable tca, Oppliger Ł5k gearbox with close ratio and custom props along with new intercooler. It is gonna be a busy weekend as most of it arriving at once.
My wife asked me what I want to do for Father's Day...I said, fit my gearbox.
Old Jun 13, 2016 | 08:16 PM
  #991
Mark Shead's Avatar
Mark Shead
The question is are you allowed to fit it on Father's Day or are you under the thumb
Mark
Old Jun 13, 2016 | 08:21 PM
  #992
Mark
I'm of the school where a Father can make his own choices. Our lass however tells me I can't!
Old Jun 13, 2016 | 08:23 PM
  #993
Have you got those bits off yet Toby?
Old Jun 13, 2016 | 09:14 PM
  #994
Mark
She allows me to be allowed. Makes me think I am in charge
Old Jun 13, 2016 | 09:15 PM
  #995
No, not yet, hopefully soon
Old Jun 14, 2016 | 04:46 PM
  #996
Had a call from Bara to say the oppliger shifter has arrived so will go get the box on Friday this week and MK has been sending me pics of all the stuff he has been posting to me so lots to do this weekend and then the 6 degree beam is prob going to be finished next week. I will get the car running and then take of a front and rear suspension and send it to Leda so they can copy the shape and size whilst I am on holiday and then once corner weighted they will make me up new Shox and springs to suit as mine went on in 1992 and it has spent a lot of time sitting around not being driven, fresh new Shox will be great.
Old Jun 14, 2016 | 04:47 PM
  #997
Mark
Got the pass for a weekend in the garage all sorted.
Old Jun 14, 2016 | 07:28 PM
  #998
Coming along nicely mate
I'd get the new shocks on before the corner weighting or you will have to get it done again after fitting the new ones unless they are going to be exact copies with same Spring rates and valve rates etc
Old Jun 14, 2016 | 07:57 PM
  #999
Thanks, I think they needed the corner weights to predict what damping and springs were needed based on overall weight of car etc.
How did you work out the dampers before?
Old Jun 14, 2016 | 08:04 PM
  #1000
Sounding good mate looking forward to it going together
