FOCUS RS 4x4 COSWORTH 24 - 02 - 2013
Old 24-07-2010 | 11:43 PM
  #681
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Originally Posted by focus 4x4
Yeah got it back now -
Gonna plumb in the fuel system , get it wired up and get her running!
Nice one
Old 25-07-2010 | 12:50 AM
  #682
BRAMMER's Avatar
BRAMMER
That looks very tidy
Old 28-07-2010 | 09:36 PM
  #683
nobbycossie's Avatar
nobbycossie
this looks awesome, keep up the work, looking forward to seeing the final car
Old 06-08-2010 | 07:05 PM
  #684
focus 4x4's Avatar
focus 4x4
Got a few bits from Matt @ Think Automotive - next day delivery and very reasonable too!
And its should all fit under the car something like this .
Old 06-08-2010 | 07:11 PM
  #685
dingla rs's Avatar
dingla rs
you got the stack dash yet simon? mines been put back again will never get it finished at this rate lol ,that mean your fueling be sorted soon then
Old 06-08-2010 | 07:16 PM
  #686
focus 4x4's Avatar
focus 4x4
Not got the stack yet , (its on the list) gonna concentrate on finishing the fueling before i move onto the final part of the build - the wiring and the Stack dash!
Old 06-08-2010 | 07:18 PM
  #687
dingla rs's Avatar
dingla rs
the wiring bit that will be intresting to see how hard it will be to do ,only bit that i scratch me head about rest easy
Old 06-08-2010 | 07:22 PM
  #688
focus 4x4's Avatar
focus 4x4
Should be a peice of piss , gonna get some else to do it all LOL (Ryan with a bit of luck)
P/X FOCUS RS in the mean time !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!
Old 06-08-2010 | 07:25 PM
  #689
scarnny's Avatar
scarnny
Is your tank baffled? Or will you be using a swirl pot?
Car looks nice mate I'm keeping an eye on your build can't wait to see the finished car.
Old 06-08-2010 | 07:28 PM
  #690
focus 4x4's Avatar
focus 4x4
The Pro Alloy Tank is baffled and has an internal swirl pot/collector so no need for the extra external pluming ;o)
Old 06-08-2010 | 07:29 PM
  #691
dingla rs's Avatar
dingla rs
you got a focus rs ? yer easy when some one else doz it lol
Old 06-08-2010 | 07:37 PM
  #692
scarnny's Avatar
scarnny
My tank is set up the same way but has pump in the tank also I think it just looks neater with out to much pipe work etc.
Where are you gonna fit the pumps?
Old 06-08-2010 | 07:44 PM
  #693
focus 4x4's Avatar
focus 4x4
Exactly why i wanted everything in the tank (much neater , less plumbing etc) we looked at fitting a pair of o44's in the tank aswell but they took up so much room , so the pumps and filters will all be mounted together up in the floor recess where a standard cosworth n/s center section exhaust box used to be. Fortunately in using a Mongoose exhaust so theres plenty of room now.
Old 06-08-2010 | 07:56 PM
  #694
scarnny's Avatar
scarnny
Very neat , job hats off to you mate.
Any idea when she's gonna be finished? How long have been so far?
Been on mine 6 years ouch!!!!
Old 06-08-2010 | 10:52 PM
  #695
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Nice set up
Using one of those fuel pump holders myself and looking at getting a scaled down version made to mount the filter
Old 07-08-2010 | 05:23 PM
  #696
focus 4x4's Avatar
focus 4x4
Originally Posted by Richie.
Nice set up
The foam thats supplied with the bracket is that thick it will allow you to house an o44 or the slimmer fuel filter! ;o)
Old 07-08-2010 | 05:26 PM
  #697
JonnyBravo's Avatar
JonnyBravo
Looking good, how much were the brackets ?
Old 11-08-2010 | 02:51 PM
  #698
focus 4x4's Avatar
focus 4x4
Managed to get an adaptor so i can mount the pumps and filters closer together and loose the restrictive standard o44 check valve.
Much closer !
Old 11-08-2010 | 04:47 PM
  #699
M K's Avatar
M K
you cant get much closer than that fella
Old 11-08-2010 | 05:01 PM
  #700
fezzajsy's Avatar
fezzajsy
nice set up mate
Old 11-08-2010 | 05:17 PM
  #701
HockeyNomad's Avatar
HockeyNomad
Very trick i like it, loving the brackets too, got the same ones with my 044 on my RS focus,
but ive only got one of them
Old 11-08-2010 | 08:51 PM
  #702
focus 4x4's Avatar
focus 4x4
Gonna order another pair of those black brackets for the filters and mount them all together on a single sheet of 5 mm ali plate. Hopefully keeping it as simple as possible .
Old 11-08-2010 | 09:06 PM
  #703
HockeyNomad
You mounting these inside the car or underneath the floor?
Are they being fed from a swirl tank or a trick tank setup,
Old 11-08-2010 | 09:16 PM
  #704
COCHYN's Avatar
COCHYN
Nice addition there, are we near completion yet?
Old 11-08-2010 | 09:19 PM
  #705
focus 4x4's Avatar
focus 4x4
Being mounted underneath the car - where the near side standard exhaust centre box used to be. ( its left a nice space to mount them now that i had a Mongoose fitted)
All fed from a trick Pro Alloy Tank. (pictured earlier in the thread)
Old 11-08-2010 | 09:20 PM
  #706
focus 4x4's Avatar
focus 4x4
Nah not really! lol not too far away tho .
Old 11-08-2010 | 09:22 PM
  #707
HockeyNomad
Ah i remember now
so many focos projects going i forget which is which
top work mate, the tanks looks even better on second inspection of the pictures
Old 11-08-2010 | 09:26 PM
  #708
COCHYN's Avatar
COCHYN
Real Focus' take time and patience, you'll love it I swear. Best toy I've ever, will ever have
Old 11-08-2010 | 09:52 PM
  #709
whizzisat114's Avatar
whizzisat114
Looking Good Simon
Old 12-08-2010 | 07:04 AM
  #710
carl/saff's Avatar
carl/saff
Much closer !
x2
Old 12-08-2010 | 08:17 AM
  #711
Cyril Sneer's Avatar
Cyril Sneer
very very nice idea... looks superb!
Old 27-08-2010 | 08:58 PM
  #712
focus 4x4's Avatar
focus 4x4
After some debate , ive decided that im gonna use 4 clamps instead of 2 . its much stronger and sturdier. Just gotta mount it to an ali plate and fit it to the focus !
Old 27-08-2010 | 09:09 PM
  #713
whizzisat114
Looking Good Simon bet they'll be nice and sturdy
Old 27-08-2010 | 09:11 PM
  #714
Richie.'s Avatar
Richie.
aka Turbosailorboy
Looking good Simon
Definately going to do Ka like that
Old 31-08-2010 | 08:24 PM
  #715
focus 4x4's Avatar
focus 4x4
Managed to get the pumps/filters mounted onto an ali plate tonight......
I was going to use these bushes to mount everything to the car but on closer inspection they are way to small for the job. Will get some proper manly ones tomorrow.
Old 31-08-2010 | 08:51 PM
  #716
whizzisat114
i thought that the clamps to filter/ pumps had rubber bands in them its a little hard to see off the pics , are they 8mm threaded coton reels? we have them at work for mounting single cylinder diesel engines and they are fine for that job they last a good 500 hrs and they dont half bounce around
Old 31-08-2010 | 09:00 PM
  #717
focus 4x4's Avatar
focus 4x4
Yeah the Rubber sleeves supplied with the clamps are ok , but arent great. so thats why im gonna fit cotton reels aswell. the 8mm cooton reels i have , (pictured above) arent tall enough so thats why i was slightly bigger ones.
Old 31-08-2010 | 09:16 PM
  #718
COLEYST200's Avatar
COLEYST200
Very nice but that lot has cost you about £450 wot a lot of ££££££££ wot BHP you going for
Old 31-08-2010 | 10:02 PM
  #719
focus 4x4's Avatar
focus 4x4
Thanks for reminding me!!!! LOL just priced it all up and it cost me £407 !!!!!!
will be running 500 bhp
Old 01-09-2010 | 02:17 PM
  #720
seazer's Avatar
seazer
how much do you think this stands you in mate?
looks ace tho
top workmanship!
its going to scare alot of people!
Quick Reply: FOCUS RS 4x4 COSWORTH 24 - 02 - 2013
