My 400+bhp CGI Zetec/ST170 Turbo S2 17/05/08 Game Over.
#323
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Righto - sadly a no pictures update
But:
AEM ECU and full wiring loom has now arrived and is sat at my local FedEx depot awaiting collection
Block is now machined, crank nitrided, polished and balanced - all awaiting collection too!
Dug out my other various engine bits and they're going off for hot acid dipping to clean them up and the sump is going off for powder coating.
Ian Howell has sorted me my replacement rings and circlips after the last set went 'walkies'
Piper should be getting me my reprofiled cams, vernier pulleys, valve springs and retainers posted back to me shortly and then its engine build time
But:
#324
Lukesville
Excellant news, Will....engine time, hey tht vast mountain of bedroom toys finally gets bolted together..
should be collecting my cams this weekend and then the built engine next weekend from Mr Howell..
Fingers crossed on getting your shell back, is this painted now or back from being prepped.
#326
Few pics for you
AEM ECU arrived:
Quick screen dump of the interface:
Also bought the AEM race wiring loom:
Fortunately every wire is printed with identification to try and minimise mix ups!
Also comes with appropriate bits to tidy it all up at the end:
I've also been fortunate enough to be invited to help strip an old race car and the freedom to remove some useful bits - god love mates in great places
Looks like a full motorsport spec loom is on the cards now :shock:
AEM ECU arrived:
#330
Mil-spec connectors are very good and come in a good range of size, we use these on all our race cars
Look forward to seeing the build pics / write up s Will
#331
I spent 4 months building looms at Honda Racing F1 so they're nothing new to me.
Just can't believe the price of the tooling to repin them
#334
Bothuurd
#336
Looking very good Will!
You have got me very worried LOL!!
What are you doing cage wise and suspension?
Keep the updates coming fella, looks like working where you do helps alot!
Cant seem to get my boss interested in turbos, he is far more interested in how my construction projects are running!
#337
Dan - your's is miles ahead of mine so i doubt i'll take any off the limelight this year lol
I'm just on my way out now but i'll PM you later for a chat
#340
NEEDFORSPEED
When i do my dummy engine build i'll start with the engine loom - problem will come from the fact that i wanted to a fully detachable engine loom from the bulkhead and i've just realised the AEM loom runs an external shielding
#341
Change of plan or a shiteload of work then?
Serious goodies on last couple pages mate...
Had an eye on this thread and can't wait for it all to start gettin bolted together...New, different and raipd
#348
Rest of the loom can be done on a bulkhead connector
#349
Rightio, had a couple of boxes delivered yesterday...
One from Piper who i have to say a big thankyou to - Garry was very helpful and was more than happy to discuss my ideas and options
So...
Piper Cam, Piper Valve Springs, Piper Retainers and Piper Verniers
And...
ANOTHER RS Turbo loom
Will be chopping about with this to get all my indicators, brake lights etc. etc.
So...
And...
#351
Which cam is that? Presume inlet as I see the phase sensor trigger bump thingies....?! What sort of power band are you designing the engine to operate in?
Chris
Chris
#352
Yeah Inlet cam there mate
It should drive like a 2.0 Zetec up to 3000, start being spritely up to around 4000 where it should be doing full boost and hold that through to 8000rpm.
Possibly a bit more on top speed runs.
I'm only on single valve springs as i've spent enough on the head already - don't want to get into machining and oversize buckets.
I'll go as far as i can before i get valve bounce basically
#354
Not really power as such that dictates when you need double valve springs.
Type of cams you're using and intended revs are what dictates the change in the planning stage.
Valve bounce occurs when the spring isn't up to the job - IF i get that too early in the rev range then i'll have to go to doubles and bite the bullet
#356
Ford Focus Specialist
Ryan
I've actually got a load of Vitone DR25 Raychem from er, somewhere
Cams and verniers look tidy! They turned up pretty smartish didn't they?
#357
Ryan
