My Escort Cosworth...
#81
LOOKS FUCKIN GORGEOUS MATE
think thats made my mind up
im goin get an imperial blue one
in the first pics on the standard wheels how much she lowered by?
carl
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
carl
#82
nick- heres hoping hey!!!
the piller pod was from NOMAD
its a good one too, and yes the bay parts will be getting crackled NOT OTT just few parts think you can go too far doing everything in 1 colour or finish...
but basically i'm looking at the header+breather+catchtank+steering res+thermos housing thats it
rest will be done different
carl- the car was on the WORST springs you have ever seen these are low anyway really but they were so bad they made the rear bottom out and caused my prop to be damaged
, hence me fitting leda springs i would never reccomend anyone lowing a ecoss more than 10-20mm as i believe it puts the drive shafts on strain remember it was this height for a reason
but my springs now are 10mm lower than std i think on the rear? thats it
#86
cheers chaps, cars still there mark aint finished it yet
fiesta is off the road too so i am car less!
heres hoping to a brighter new year
#87
ok good news at last
phoned mark today and the car is fine, had a slight miss but when driven on the road was found and solved so running 100% now, apparently been mostly all done just a few other bits to finalise. they done a oil change for me
, the brakes are also on now
.... wonder if they cleaned it
. i should be going to pick it up this sunday
then i have to get fitting and sorting the new bits out
so watch this space pics will follow
Ad
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Ad
#91
Monte Geek
Good news
Major breakthrough for you my end aswell.. the subframe as moved from the back of my garage to the boot of my car
Just got to find a box big enough
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
#92
wait on marks reply to see what were gonna do
Ad
#94
Don't make me say "Told you so" about that clutch
As long as it's the clutch slipping and not the gearbox exploding, because that'll be your issue before too long if you get a clutch that's man enough and start giving it beans. If it were mine and I wasn't going to uprate the gearbox and get a good clutch, I'd wind the boost down till the clutch could juuuuust hold onto it in most situations.
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#95
i mean what is the point having all this done and then skimping??
So it will have the clutch changed for a organic one (which mark recommends is good for 400bhp+nos so will be fine on mine) and then the car will be mapped again so it will have 1.5BAR low boost, 2.0BAR full boost
Still it may be ready for the weekend just depends on the parts and time etc
got the bill too
Ad
#99
ok picked up the cossie the weekend, mark did all i wanted. altho i have encountered on a couple of small problems he needs to fix but he said he will pop over somtime soon to plug the car in and change a setting or two...
But my brief spec was to have the
STG 3 T34.48 fitted
new braided loom
SM4+CDI ign,4 coils and leads
1000cc injectors
AP organice clutch
AP 6 pots fitted
longer wheel studs
now with this spec mark predicts me to now have in the region of 360-380bhp.... anyway the car seems to run brill, good on fuel still and goes V well. what with all the new stuff it is taking some getting used to but i'm getting there, the features are cool too
now its back i managed to kill a cv joint
so a new shaft had to be bought as you cannot buy the inner joint alone
.... which in a way is ok at least i know its new... i have also managed to start fitting the car up with some of the new bits, altho i need to get the water inj finished, sort some wiring, and few other small bits....
but heres a few pics to keep you amused
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/newrearlights.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/newgaitor.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/newbrakes.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/afterconversion.jpg)
Ad xx
STG 3 T34.48 fitted
new braided loom
1000cc injectors
AP organice clutch
AP 6 pots fitted
longer wheel studs
Ad xx
800bhp (18-01-2015)
#107
thanks for the comment chaps
, danny b may be paying you a visit soon for some chassis bars
just need some time off work now to get fitting the other new stuff
#111
#112
ok well as you may know the car went on the rollers graph below just encase you missed it
![](https://i2.photobucket.com/albums/y50/Adamskilar/picture003.jpg)
Also due to the car now having the extra power i have took it upon me to realise i NEED to upgrade a few things sooner rather than later
so after speaking to Paul R bought a spare cross member(going to be powder coated), mike R for some new engine mounts, rear shims and some BLING carbon bits on order
and a thermostat housing frm pete rs spares to be crackled....
also to mount upto the member i have now got some adj TCA's off TONY cheers
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/NEWPARTS.jpg)
my water injection is now fitted with quick release fittings
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture006.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture008.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture009.jpg)
Now final parts my breather system should need upgrading now asap, so all my bits are almost ready just waiting for my power steering res finished at A+H then i am sending my breather bits and header tank over to christian to get them crackled for me![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Now all thats left for me to do is bring myself to order the QUIP fittings for the breather system which i have worked out is gonna cost ŁŁŁ
cheers Ad
cheers Ad
#115
ok starting to get a few things moving now, time to pull my finger out...
been sorting my alloy parts and that i now have all the parts ready to go to christian for crackle coating
ordering my aeroquip fittings in the next day or two, my cross member is being coated now in matt black...
ALSO major thanks going out to SAILORBOB aka derek for the loan of his rocker so mine can go to be painted your a diamond...
so that will be painted along with some new side lights as mine broke
but i now have 2 sets so i can swap from clear to painted depending on mood
my water injection is fully active and working 100% really happy with the system...
Again big up to A+H fabrication supplying me with parts,time,effort all round top guys the amount of small and large and one offs they do for me
finally some pics from today at A+H:-
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture016.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture020.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture018.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture022.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture024.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture025.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture026.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture027.jpg)
![](https://i2.photobucket.com/albums/y50/Adamskilar/cossie/picture030.jpg)
*annoying momnet* this is being a rattle coming from the underside of the car
cannot for the life of me find it BUT gonna get the car on a ramp and jack it up and drive it see if anything comes up
, also would like to thank RYAN for breaking my oil pressure guage
so plenty more to come with parts arriving left right and centre will wait till all the parts arrive back then update on what i got
cheers Ad
cheers Ad
#117
Looking good Adam, will be good to see it finished
Got to say tho, what are those gastly things in the front bumper??
Oh and sort your badges out
Black crackle is going to look so
![Content](https://passionford.com/forum/images/smilies/content.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
#119
thanks alot chaps
the things in the front i'm in 2 minds whether to paint them black or get them powder coated black
??? opinions?
also badges i have been putting off as i wanna take the boot off and get it resprayed along with the spoilers so they would need removing anyway
, but again i am in 2 minds whether i should have left the bot lock in as it looks too plain.... what you recon???
crackle will look awesome struggling to get hold of christian atm tho
... Ordered my QUIP today
dear god this could be the begining of the end was not cheap
Ad
Ad
