Mk2 Fiesta ST 170
Old 21-06-2018, 09:00 AM
  #41
RibbleTechnology
RibbleTechnology's Avatar
Top marks This ill be following.
Old 22-06-2018, 05:42 PM
  #42
boost monster
boost monster's Avatar
Calliper bracket made today. Looks professional to me.
Old 22-06-2018, 06:31 PM
  #43
boost monster
Tight
Old 22-06-2018, 06:52 PM
  #44
Rsmat
300+
Rsmat's Avatar
Lovely work .
Old 25-06-2018, 09:14 PM
  #45
boost monster
Mondeo master cylinder and servo fitted
Old 27-06-2018, 02:44 PM
  #46
xr2john
Passionford Addict
xr2john's Avatar
Look awesome. Subscribed ��
Old 29-06-2018, 07:11 PM
  #47
boost monster
After
Before
Still removing waxoyl but absolutely no rust
Old 11-07-2018, 08:38 PM
  #48
boost monster
Some good progress lately, Gearbox man took longer than he said and the fly wheel turned out to be for a mt75 box that he only discovered at clutch fitting time but the company changed it.
Old 04-08-2018, 09:13 AM
  #49
boost monster
Engine now starting of the key. Exhaust manifold is the next problem.
Old 04-08-2018, 01:35 PM
  #50
boost monster
Calipers finished now
Mk1 Mondeo servo and master cylinder all bleed
Old 15-08-2018, 08:06 PM
  #51
boost monster
Focus 4-1 manifold now fits after a bit of a nip and tuck. Just needs the XR2 system cabodgitated to fit. Plan is a Mot next Friday all being well
Old 15-08-2018, 09:38 PM
  #52
Rsmat
300+
Rsmat's Avatar
Love this build mate .. top work.
Old 16-08-2018, 10:23 AM
  #53
costina
Live long and prosper!!
costina's Avatar
Very cool.
Old 18-08-2018, 09:23 AM
  #54
raymond dobbie
raymond dobbie's Avatar
Good stuff
Old 22-08-2018, 07:44 PM
  #55
boost monster
It goes.
Had a run up the street tonight a few issues to sort.
Bonnet hits the VVT solenoid
It’s not overly keen on starting from cold but starts perfect after first start. Any clues as what to do??
Throttle travel is small.
And brakes probably need another bleed
Old 23-08-2018, 09:03 PM
  #56
costina
costina's Avatar
Check fuel pressure or try priming the pump 3 times before starting.
boost monster (23-08-2018)
Old 25-08-2018, 06:16 PM
  #57
boost monster
Got it mot’d today with no advisories
. Tester described it as a brand new car. Still having starting issues from cold but suspect the pump. Done a rolling test from 2nd gear against my S2 and it goes really well.
Son no1 described it as savage. lol
Old 31-08-2018, 03:30 PM
  #58
boost monster
Had a problem with the front brakes locking on. Obviously suspect the master cylinder but its a brand new one fitted. It worked for a while before the fault. Could it be plumbed up wrong causing this after use?
Old 31-08-2018, 04:54 PM
  #59
big_wasa
big_wasa's Avatar
I’ve had this with a new slave, fluid leaking behind the seals and stopping it returning.
Old 31-08-2018, 05:41 PM
  #60
costina
costina's Avatar
Happen all the time or just once it gets some heat into the system?
Old 31-08-2018, 06:11 PM
  #61
boost monster
It’s happened twice now. No heat involved.
Old 31-08-2018, 06:25 PM
  #62
costina
costina's Avatar
Give the pedal a little more free play.
Old 31-08-2018, 07:05 PM
  #63
boost monster
Yes I think that could help. There is a bit of cabodgitation to get the angle correct with the Mondeo ms and the Fiesta bracket and I think that will be the cause.
Old 31-08-2018, 07:16 PM
  #64
costina
costina's Avatar
All brake systems expand with use sometime heat causes it other times it's just general use.
Aim for about 5mm free play and increase or decrease as required.
Old 31-08-2018, 08:57 PM
  #65
Dthomas23
Dthomas23's Avatar
Originally Posted by boost monster
Thanks for the positive comments it certainly gets plenty attention when it's out and about
Here's the plan
This is the fourth engine that has been bought to go in it so hopefully this time.
The 2.0L Alda block is a pretty nice motor.
I’ve just put a new head on mine. As the cambelt shed a load of teeth. Has always started first time. Even after renovating the Inlet components.
When setup properly runs really sweet.
If your putting this into your Fiesta. You will end up with a fantastic car.
Well done
Old 04-09-2018, 01:52 PM
  #66
boost monster
Well the brakes have not broke again but he has tools in the car to do diagnose the problem if it happens again and has done the sensible thing of..... buying an other box from Motorsport Electronics to control the VVT. They claim up to a 40lbf of torque with it fitted.
We think the engine has has the mod to the timing on the exhaust cam. Is there any easy way to tell? It doesn’t have a vernier.
VVT controller from Motorsport Eletronics.
Old 04-09-2018, 02:38 PM
  #67
costina
costina's Avatar
Interested how that works.
Old 04-09-2018, 06:06 PM
  #68
big_wasa
big_wasa's Avatar
If it’s still got the original cam pulleys on it’s just a case of slackening of the bolts and re doing the timing.
have a read before you do, I can’t remeber what direction you move the inlet pulley to set it.
Old 21-09-2018, 10:56 PM
  #69
boost monster
Well the fitting of the VVT controller didn’t go well. The nodiz ignition ecu got fried due to a wiring anomaly! Should be good for take 2 next week.
Old 26-10-2018, 01:34 PM
  #70
boost monster
Little update. Got a new nodiz ecu and it was back up and running but still without the VVT Then he started to have clutch problems for a few day until eventually no drive at all so it was put away for the winter.
Yesterday he removed the box an the plastic release bearing locating pins had broken he thinks causing the bearing to jam. Still not investigated the brake issue.
Old 08-11-2018, 08:50 PM
  #71
boost monster
Now undergoing a underneath clean up.
The regularl waxoyl for the last 6 years seems to have done a good job.
Old 07-01-2019, 11:03 AM
  #72
boost monster
Battery tray removed and gearbox back in with new Helix Clutch after the plastic release bearing on the previous one failed.
All waxoyl removed from front arches and a little freshen up.
Good progress over the holidays
Old 07-01-2019, 12:27 PM
  #73
gcfcos
gcfcos's Avatar
Looking good mate, car looks very clean and rust free
Old 07-01-2019, 01:17 PM
  #74
Caddyshack
Caddyshack's Avatar
Love this car. Nice work!
Old 04-03-2019, 09:19 AM
  #75
boost monster
Good progress and also on schedule for April. New trumpets battery in the boot and discreet shift lights
Old 04-03-2019, 11:51 AM
  #76
Rsmat
300+
Rsmat's Avatar
Sorry to read of the problems you've come across .. top work as per mate.
Old 05-03-2019, 02:04 AM
  #77
boost monster
You know from your own experiences that things don’t always go to plan but it’s going well at the moment.
Old 05-03-2019, 10:06 AM
  #78
boost monster
This part was also designed and made.
It convert the very small throttle travel of the motor bike carbs to a longer travel for the Fiesta accelerator.
He said it’s the first time he’s used trigonometry for something useful.
Old 10-03-2019, 03:01 PM
  #79
boost monster
So today’s task was to cut the bonnet to clear the VVT solenoid.
I’d love to say I taught him everything he knows about metal fabrication but it would be a bare faced lie!
still work in progress but getting there.
Old 10-03-2019, 08:07 PM
  #80
boost monster
So this is where he got to at end of play today.
He wanted to avoid the hacked bashed method of achieving clearance. I think he’s done that.
Quick Reply: Mk2 Fiesta ST 170
