Engine swap
Old Jan 7, 2018 | 10:41 PM
weldfab-123's Avatar
weldfab-123
Default Engine swap
Want to do a engine swap form a 1788 push rod to maybe a 2.0 ztec with Mazda rx8 gear box is this a good choice or what else would give me about 180/200 bhp in my mk2 escort and not break the bank I'm on a budget???
Old Jan 8, 2018 | 10:47 AM
big_wasa's Avatar
big_wasa
Check the amount of work to get the rx8 box in.
I love a zetec. There are newer and better engines but a zetec is solid and reliable and still very cheap.
180~200bhp in a zetec is not cheap. If you can live with 150~160bhp its cheap and 150bhp can be done very cheap and can of cause be upgraded as and when funds allow.
For a genuine 200bhp from a zetec will require a fair bit of head work and cams, Or a turbo.
The St170 ( a zetec with as better head) would be a better starting point for a 200bhp na build.
The more you make the less it costs.
Old Jan 8, 2018 | 03:53 PM
The Black Count's Avatar
The Black Count
How about using the engine and gear box from a 3rd generation MX5 2005-2015 the engine should be lighter than a zetec and tuning parts are easily available. I would buy a wrecked MX5 donor car and transfer the lot over
Old Jan 8, 2018 | 05:23 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I like that sort of thing. A lot of the car world, not just Ford don't like cross pollination of different manufactures I.e. Non ford. But it makes sense to get a cheaper and better unit in there....if it comes to it get someone to mill off the rocker cover and stick a ford badge on it if it bothers you.
Old Jan 8, 2018 | 06:14 PM
weldfab-123
I'd like to keep it all Ford if possible but am open to to suggestions
Old Jan 8, 2018 | 08:44 PM
The Black Count
I think you will find that the engine in the 3rd gen mx5's are Ford engines.
You seemed to be happy to use a Mazda gearbox but if you go for a Ford one then something like the ST170 engine would be a good choice
Old Jan 8, 2018 | 08:52 PM
weldfab-123
Is there anything special needed to do this /brain wiring bike carbs or standard
Old Jan 8, 2018 | 08:55 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
If you have the whole car mx5 donor you would swap in the engine lol and ecu. Bike carbs do not really work well on cars. Or go standalone ecu like Emerald if you can get someone to map it
Old Mar 1, 2018 | 05:32 AM
weldfab-123
Default St 170
ok now st 170 bought what do I need to put It in ecu and all
Old Mar 1, 2018 | 08:33 AM
turbo m's Avatar
turbo m
And some of the mx5"s had as 6 speed box too, not sure what year though..
yogi
Ford Focus Range
Jun 21, 2016 05:46 PM
Bigdaggy123
Ford Focus (All Models)
Feb 1, 2016 03:41 PM
JoeE30
Aug 10, 2004 07:59 AM
Fiesta RS1800/RS Turbo
Feb 11, 2004 10:40 PM
Jan 28, 2004 09:53 PM
