Rosso red Rs turbo build and progress.
Old 18-04-2020 | 11:41 PM
  #1921
c20tbo's Avatar
c20tbo
Cracking ERST
I had a similar issue with a brand new DW350 pump on my Escos, fuel supply was maxed out on mapping, then there was a lot of head scratching etc etc tank in tank out and what not, new filters, then a simple flow test relieved pump was down 1ltr per min, new pump fitted and map tweaked, it was at 590 before final tweak, since then I've fitted a billet comp wheel to the EFR so ideally map needs checking over again
Again stunning build
Old 19-04-2020 | 06:39 PM
  #1922
Rsmat's Avatar
Rsmat
Originally Posted by c20tbo
Cracking ERST
Thanks mate , im just so glad it can go back for mapping properly now
Old 19-04-2020 | 06:42 PM
  #1923
scoooby slayer's Avatar
scoooby slayer
Originally Posted by Rsmat
Well the pump was my fuel restriction .happy days ..now to get it book back in to MSD .
Balls out just to see what it will do ? 😁😁😁😁
Old 19-04-2020 | 06:53 PM
  #1924
Rsmat's Avatar
Rsmat
When I fitted the IB5 conversion with the CG motorsport hybrid bearing, the first one Broke on fitting and the second broke up on MSD's rollers after 20 mile ish.. luckily I local lad to MSD had one on the shelf so i managed get it fitted and get it mapped.. fast forward 5130 miles later and I've always wanted to change it , so friday i rang G.E.A.R.S up for them to service my box and fit me another folk and metal bearing set up.. so when I got the box out today the third one even though it's been faultless was still in 2 pieces ... anyhow the box is out and getting dropped off in the morning .. other thing is the std baffles in the rocker cover ain't up to the job because of the roller rockers flicking oil into them and it going through my breather set up.. so that's off to Muz also for some uprated baffles..
And the bearing up on removal .
Old 19-04-2020 | 06:56 PM
  #1925
Rsmat's Avatar
Rsmat
Nah I'm Not a number chaser, well apart from this car had to be 300hp , I've done that already with plenty of scope left.. it's now running super rich with a poor spark table .. so could quite possibly be another 20hp their without anymore boost once mapped 😎
scoooby slayer (19-04-2020)
Old 19-04-2020 | 07:49 PM
  #1926
markk's Avatar
markk
A safe spark table at the high boost level because of the lack of fuel flow rich, yes which is far better than leaving it lean, not poor, perfectly safe for you to drive.
Only the top two lines of the load table. The rest is perfect. Had it been able to supply the fuel on the dyno then those lines would be perfect too.
Can't wait to see it optimised to the max now. Anymore and you will need a bigger map sensor.
Rsmat (19-04-2020)
Old 19-04-2020 | 07:54 PM
  #1927
Rsmat's Avatar
Rsmat
Sorry mate poor choice of word .. safe I mean ..and what's involved in swapping my 3bar for a 4bar map sensor as I have the same map sensor in 4bar on the shelf.
Old 19-04-2020 | 08:43 PM
  #1928
markk's Avatar
markk
I knew exactly what you meant some people take things out of context. If you re thinking of using 2bar and a bit more then it needs to be done when it goes back on the dyno. It will give you a little headroom on the top lines, I like a little spare space hence I run a 4bar, I often see 3.4bar abs. The load scale just gets re-scaled to share the voltage over 4bar pressure instead of 3bar. Your map table has plenty of resolution for it.
Don't just fit it though lol
Is it the same make? same wiring?
Old 19-04-2020 | 08:44 PM
  #1929
scoooby slayer
4 bar map sensor now your talking 😁😁💪💪
Rsmat (20-04-2020)
Old 19-04-2020 | 08:54 PM
  #1930
Rsmat's Avatar
Rsmat
Yea mate , same wiring ,make .. both identical apart from one 3bar and other 4bar.
Think I might do it mate 😬
Old 19-04-2020 | 08:57 PM
  #1931
scoooby slayer
Go for it pal we only live once 👍👍
Rsmat (19-04-2020)
Old 19-04-2020 | 08:58 PM
  #1932
gcfcos's Avatar
gcfcos
I've got to applaud you on your work on your car keeping it so clean when your tackling mechanical work. As a mechanic of 23 years I keep stuff clean but could never work as clean as you mate ha ha
Rsmat (19-04-2020)
Old 19-04-2020 | 09:25 PM
  #1933
Rsmat's Avatar
Rsmat
Totally true on that .👍
thanks mate , I'm just a fussy bugger .😳
Old 20-04-2020 | 02:07 PM
  #1934
Rsmat's Avatar
Rsmat
That's the box dropped off at G.E.A.R.S this morning.
Old 27-04-2020 | 09:32 PM
  #1935
Rsmat's Avatar
Rsmat
Gearbox will be back tomorrow, and I managed to get through my bits and find my 4 bar .. woohoo
The following 2 users liked this post by Rsmat:
bluntys1rsturbo (29-04-2020), smiley (28-04-2020)
Old 29-04-2020 | 02:29 PM
  #1936
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
Brilliant updates mate 4 bar map sensor can only mean rocketship boost incoming
Rsmat (29-04-2020)
Old 29-04-2020 | 10:20 PM
  #1937
Rsmat's Avatar
Rsmat
Oh yes mate .
bluntys1rsturbo (30-04-2020)
Old 30-04-2020 | 06:38 AM
  #1938
bluntys1rsturbo
Boost addict
Oh yes mate .
cant wait to see this next stage of development take shape going be amazing fella
Old 01-05-2020 | 08:49 AM
  #1939
cossirob's Avatar
cossirob
What happened to the front anti roll bar and bottom arms you was having made mat? i remember some clearance issues did you get it sorted?
Old 01-05-2020 | 10:19 AM
  #1940
Rsmat's Avatar
Rsmat
Hi mate , yea all sorted and works fine , its here on the garage floor all split up ready to powder coat when they open , then re fit it and dial it in again .. top piece of kit , totally transformed the car tbh more than I expected.
Old 01-05-2020 | 11:22 AM
  #1941
cossirob's Avatar
cossirob
Will there ever a kit available for sale or was i one off job for you?
Old 01-05-2020 | 12:08 PM
  #1942
Rsmat's Avatar
Rsmat
No mate , defo be kits on request , its took a while with getting right , so now the lock down is perfect to get it powder coated and back on .
Message MK motorsport if anyone wants one.
Old 01-05-2020 | 01:28 PM
  #1943
cossirob's Avatar
cossirob
ok cool. once its powder coated can you post some picture of it?
Old 01-05-2020 | 02:11 PM
  #1944
Rsmat's Avatar
Rsmat
Yea course I can .
Old 03-05-2020 | 05:57 PM
  #1945
Rsmat's Avatar
Rsmat
So I've re set the solid lifters since I was changing the rocker gasket and found 2 slightly out so those got set .. the rocker that's cause a few dramas is the past by chucking oil into the catch can is off for some proper baffles.. no wonder only having one std OE baffle .. drive shafts broken down for refurb and new boots whilst I'm waiting for the release bearing from CG motorsport .. I'm waiting on new pins from MK motorsport for the TCas then they can be powder coated and fitted ready for another geometry set up .. got my 4bar out ready for my next trip to MSD .. also I'm fitting a shift light and EML in the dash nice and discreet .. new sump gasket , filter and oil , build it all back up and then it will be ready for MSD to push it a little harder .
Old 03-05-2020 | 06:11 PM
  #1946
Rsmat's Avatar
Rsmat
Also treated myself to a new stereo..
Old 05-05-2020 | 08:02 AM
  #1947
Johnny Knoxville's Avatar
Johnny Knoxville
I can remember Andrew@ALD saying he hated Newmans cams lifters because they come loose all the time
Rsmat (05-05-2020)
Old 05-05-2020 | 02:01 PM
  #1948
Rsmat's Avatar
Rsmat
I set these when i fitted the engine and after 5132 miles two had only opened ever so slightly so I'm happy , I service every 3.5k so I don't mind checking and adjusting them if need be tbh mate.
Old 06-05-2020 | 07:05 PM
  #1949
Patto's Avatar
Patto
hi matt, not sure if you've said already in the post but who supplied the pec rods and pistons ? I'm looking to get some pistons and rods for my cvh I've got apart.. also what bearings did you use ?
Old 06-05-2020 | 09:15 PM
  #1950
Rsmat's Avatar
Rsmat
Hi mate , Neil @ ND Tuning did me a mega deal on the rods and pistons , bearings are all ACL from Paul @ PJ motorsport.
Patto (06-05-2020)
Old 06-05-2020 | 09:19 PM
  #1951
Rsmat's Avatar
Rsmat
Gave the box a clean up today .
Old 10-05-2020 | 07:04 PM
  #1952
Rsmat's Avatar
Rsmat
Not much progress as I'm still waiting on my release bearing back from C.G motorsport and my TCAs Pins from MK motorsport then I can put the car back together. I decided to change the last of my super pro kit and fit the steering rack bushes and I even got some help from our kid who brought his R8 to see me.. ::
bluntys1rsturbo (11-05-2020)
Old 11-05-2020 | 05:31 AM
  #1953
bluntys1rsturbo
Boost addict
Nice updates mate little apprentice is loving it as well.
Such a shame them bits didn't arrive for the weekend pal hopefully they come this week.
Old 11-05-2020 | 07:31 AM
  #1954
Rsmat's Avatar
Rsmat
Aye mate he likes to get on it he does ..
And tea true , hopefully this week .
Old 11-05-2020 | 09:10 PM
  #1955
Rsmat's Avatar
Rsmat
Could possibly be putting it back together this weekend , spoke to mark earlier and says the pins will be sent this week back to me.
Then spoke to Mike At C.G motorsport and same on the bearing.
Fingers crossed .
Old 12-05-2020 | 12:35 PM
  #1956
Rsmat's Avatar
Rsmat
Just had a phone call from Mick at C.G motorsport to say my new designed version of the release bearing will be with me tomorrow.
Old 12-05-2020 | 02:02 PM
  #1957
Lee read's Avatar
Lee read
Rs turbo
Nice one mate looks really nice.
Old 13-05-2020 | 06:12 PM
  #1958
Rsmat's Avatar
Rsmat
Thanks Mate .
Old 13-05-2020 | 06:14 PM
  #1959
Rsmat's Avatar
Rsmat
New bearing as arrived from Mick @ C.G Motorsport , now had a nice billet inner sleeve ,
Old 13-05-2020 | 07:23 PM
  #1960
Rsmat's Avatar
Rsmat
Not much left to do now and it can go back together.
Pins back from MK motorsport so we powder coat the set up and refit.
oil Feed take off (Hex) drilled and tapped for 1/8NPT
1/8NPT boss welded into the sump, for oil temp switch .
Drive shafts powder coated.
New baffles in rocker cover .
Then a morning putting back together.
Quick Reply: Rosso red Rs turbo build and progress.
