1986 MK2 XR2 - RS1800 Engine - Classic Ford Feature Dec 2017
Old 04-04-2016, 11:48 AM
deanflowers
deanflowers's Avatar
Default 1986 MK2 XR2 - RS1800 Engine - Classic Ford Feature Dec 2017
I bought this as a painted rolling shell with no interior and an engine balanced in the bay but no interior back in 2013.
Car pretty much finished:
The interior i managed to find in Norwich was in fantastic condition and managed to get some new old stock floor mats:
Got it on the road last year and did a few shows
On-top Nottingham
Spring Action Day Castle coombe (got a top 20 place)
Queens Square bristol:
Just had it detailed and all the swirls removed:
Before:
After:
Also got accepted for the international ford day so happy with that. Car will be in the 40 years of the fiesta area.
Basic Spec:
RS1800 Engine with H/O inlet (130bhp)
XR2 stock box - would like an LSD one
Puma shortened gear linkage
Magnex stanless exhaust including 4 branch
Induction kit
New injection fuel tank
All the rest is standard and the majority of it new.
Things i'd like to do:
Change the headlining - i know where to buy but haven't
Change the box to LSD one
Wire in the stock stereo
Paint the floor red so all the new stuff stands out as its black at present.
Fit a polybush kit i have
Old 09-04-2016, 07:11 PM
Gadget
Spanner monkey
Gadget's Avatar
Stunning mate, I wouldn't change a thing
Old 09-04-2016, 07:40 PM
xr2mk2turbo
xr2mk2turbo's Avatar
Lovely, but I'm biased
Old 09-04-2016, 08:17 PM
oldschoolfordnut
oldschoolfordnut's Avatar
Very nice. I think I may have an 8 hole lsd at my mom's so if you want it and pay postage you can have it.youll have to get it fitted into a gearbox with 8 holes in the Crown wheel cuz early 5 speed had 6 holes, ill take a look tomorrow at my mom's place. I went a slightly different root lol
2 5 v6, mondeo box .should be fun
deanflowers (10-04-2016)
Old 09-04-2016, 08:38 PM
eagie
eagie's Avatar
Great wee cars, seeing this makes me want another!
Old 10-04-2016, 01:00 PM
deanflowers
That would be awesome. Bet that is a mental grunty beast
Let me know where you are as i do get about a bit
Old 10-04-2016, 01:39 PM
Mr S1
Don't ask - I don't know
Mr S1's Avatar
I love mk2 XR2's - had a mercury great one when I was about 19 and whilst not the quickest is THE most fun car I've ever owned.
I'd love another !
Old 12-06-2016, 10:36 AM
deanflowers
Lowered the car 35mm but need to drop the front 50 really and got my split pepperpots made and fitted
I still have the standard wheels so will swap between the two set depending on what the car is going to be used for at the time.
Im also getting another set done face mounted with hidden hardware (this is how i wanted these done but there wasnt enough time before a show i was attending)
Old 12-06-2016, 10:41 AM
What a nice looking car this is. I bet it goes well. Nice wheels too. Ive never seen a set like them.
deanflowers (12-06-2016)
Old 12-06-2016, 10:43 AM
deanflowers
Had them custom made from a set of original wheels using BBS RS dishes and barrels.
Old 12-06-2016, 10:48 AM
There cool as fook.
Old 12-06-2016, 06:18 PM
fatboy billy
fatboy billy's Avatar
Looked fantastic at players mate love the split pepperpots
deanflowers (14-06-2016)
Old 12-06-2016, 10:58 PM
cge
cge's Avatar
Took this after we fitted the springs Dean.
Also got one with mine as well.
Old 13-06-2016, 07:56 PM
deanflowers
It is still high on the front lol but managed to get some miles on it so happy
Old 14-06-2016, 08:56 AM
cge
cge's Avatar
Space the rear wheels out and put -50mm springs on the front and it will look spot on
Chris
Old 14-06-2016, 09:37 AM
oldschoolfordnut
Vectra gsi coil overs work a treat with sierra top strut bearings and it's a 50mm drop in the lower part of the ajustments so you can play with stiffness, bottom hub bolt hole lines up and top one needs opening up n washers welded on then use a camber bolt in the top,hey presto coil overs on the front for Ł120 all in
Old 14-06-2016, 09:39 AM
oldschoolfordnut
Crappy pic but you get the idea
Old 14-06-2016, 09:41 AM
deanflowers
Seems to work ok that. I will investigate. I know some people have used golf ones too
Old 14-06-2016, 09:43 AM
oldschoolfordnut
I think golf are about 50mm drop fully wound out so very stiff
Old 14-06-2016, 09:55 AM
JK12
JK12's Avatar
liked this at players! nice car
Old 14-06-2016, 11:19 AM
cge
cge's Avatar
Different top mounts on the mk2 so you get a lot more adjustment no matter which coilovers you use.
I would use a decent make coilover if you are going down that road tho.
Chris
Old 14-06-2016, 11:21 AM
oldschoolfordnut
Yeah true,I'm forgetting it's a mk2
Old 15-06-2016, 09:55 PM
lee2cossies
lee2cossies's Avatar
Who did the wheels for you dean and how much? is it possible to make the wheels bigger in diameter also?
Old 16-06-2016, 08:00 PM
JC600
JC600's Avatar
Awesome, really want a mk2 xr2 and in red!
Old 20-06-2016, 08:58 AM
deanflowers
Hi
Had them done by voodoo motorsport and went from 13x6 to 15x6.5
If you need an introduction let me know
It is not possible to make a set like this without going up at least 1 size but probably more than likely 2 sizes.
I would like to see a set of stock 2wd Cosworth wheels done to 17" with hidden hardware
Old 20-06-2016, 02:28 PM
lee2cossies
Originally Posted by deanflowers
Hi
Cool, i have a set of 13" capri pepperpots that i would love to get converted to split rim and the same time 15" diameter and maybe 8" wide, do you think they would be able to do this?
Old 20-06-2016, 02:31 PM
deanflowers
No problem. I wouldn't go any wider than 5.5 barrels though as im really close to the struts on mine. Give me a bell and will have a chat.
Old 20-06-2016, 03:55 PM
lee2cossies
OK mate cool, il give u a call about them.
Old 06-10-2016, 04:49 PM
deanflowers
While im working away the car is in for full underside restoration with Torques performance and having braided fuel and brake lines fitted.
they work fast - this was day 1
Front arches stripped down:
Underside stripped down:
All the bolts have gone off for re-zinc plating and everything else is off to the powder coaters.
New polybush kit should be with them today and a set of Gaz coilovers.
Will be changing the brake servo etc. over at the same time.
The floor was covered in sealant which revealed a few small holes to tackle but on the whole was pretty good apparently.
Floor will go red with red bushes and everything bolted to it black.
Just got to get it back together for Ultimate Stance at the end of the month as its on the pink wheel whores carpet.
Old 06-10-2016, 06:04 PM
xr2john
Passionford Addict
xr2john's Avatar
Looks good will keep an eye on this. Love my mk2s and I'm loving the split rims aswell
deanflowers (06-10-2016)
Old 07-10-2016, 05:23 PM
VIPER
VIPER's Avatar
Likewise! First class XR2 you have there, mate and I totally doff my cap to you for having those split-rim pepperpots actually made. I've photoshopped them on my car a few times and that was as far as I got, so respect due, sir!
Should look great with the black running gear against the red floor. My concours XR2 is black, so I've kind of had to go with a black floor and of course most of the suspension parts are satin black, but I've introduced a little colour with the dampers in red, polybushes and stuff like the tie bars, ARB and panhard I've done in metallic gunmetal. I'll be posting a thread on my car when I've sorted the photos.
I think that second set of rims you mentioned with the hidden hardware will look even better than these. Can't wait to see how they turn out.
deanflowers (07-10-2016)
Old 07-10-2016, 05:26 PM
deanflowers
Many thanks for the kind words Viper. They caused the builder a few headaches and are not exactly what i wanted so may be having another set made next year. I didn't really want the hardware on show
VIPER (07-10-2016)
Old 07-10-2016, 06:10 PM
VIPER
VIPER's Avatar
Yeah, I totally understand where you're coming from there. It's just the desire for the 'pepperpot look' isn't it, but at the 15" size so at first glance it looks stock but a second one and you go: "Ah, that's really cool what he's done there!".
As I say, I've toyed with this myself for mine for ages and never thought anyone would A) Ever actually have a set done to see if it was possible and B) if any company would even undertake the challenge. Seems it's a yes on both counts
I've decided to go for the easy option with mine and go 7x15 Lenso BSX (or Dare DR RS) when I get around to the wheel swap.
Old 07-10-2016, 06:31 PM
deanflowers
CR customs in poland do lots of this custom work, they didnt build mine though.
Ive got a set of cookie cutter XR3 wheels to be done and always wanted a set of 2wd cosworth wheels made. Unfortunately i foolishy sold my saph a few years back
Old 12-10-2016, 08:06 PM
deanflowers
The floor is zinc primed and painted.
Most of the suspension parts have been etch primed and painted black ready for refitting
Old 13-10-2016, 10:45 AM
VIPER
VIPER's Avatar
They're doing a cracking job there by the looks of it . Best bit when you're putting the refurbed and new bits back on, isn't it?
Still on schedule for your deadline is it?
Old 13-10-2016, 12:28 PM
deanflowers
Yea they say we are all good. Should hopefully be approximately be a two week turn around from start to finish
Old 13-10-2016, 12:47 PM
It's Czech Mate
It's Czech Mate's Avatar
Wheels are excellent, first time I've seen something original for ages, fair play :thumbsup:
deanflowers (13-10-2016)
Old 17-10-2016, 09:03 PM
deanflowers
Its moving along pretty quick now this was end of last week:
tanks crackle black - the header was yellow and couldnt see through it anyways:
coilovers on:
headlight backs being done:
Old 18-10-2016, 08:15 PM
deanflowers
more pics:
Just brake line and fuel lines to go.
Tank has had a threaded fitted brazed on to make plumbing neater and changing to bosch 044 pump as that takes threaded fittings and if i want to go turbo route i should be safe.
Quick Reply: 1986 MK2 XR2 - RS1800 Engine - Classic Ford Feature Dec 2017
