Big build getting back on track
Old 08-02-2016, 05:51 PM
  #201
Mark Shead
Mark Shead's Avatar
Originally Posted by Gav Diamond
Hi Mark
I used normal ATF dextron 3 I think it was, if that's wrong it could explain the oil leak from the input shaft seal
Clutch set up is a Reyland centre push with 0.7 master cylinder but have contemplated going to side push as I've never been happy with the centre push, spigot bearing again were supplied by Reyland but used 2 types as was originally on twin plate clutch but the flywheel had not been machined correctly so to save fuss went with helix paddle clutch and was supplied a different spigot to match it
The 3550 I had in mine and Rods have always been prefect at that rpm these had a unsprung 6 paddle disc and a ground down input shaft to suit spigot bearing, Mine had cable and rods had a side push and then on to center push with a tripple and the same oil as yours and never a problem,
I know of two other cars with the TKO600 with sprung disc and spigot bearing and center push like yours both have the same problem as yours.
Mark
Mark Shead is offline
Old 08-02-2016, 06:04 PM
  #202
nixon_2wd
nixon_2wd's Avatar
TKO600s should NOT be run with dexron 3 or any other ATF fluid for that matter. They should have GM syncromesh according to spec.
You will burn your syncros using ATF. It has got bronze syncrorings through out, not fiberbacked like the T5.
nixon_2wd is offline
Old 08-02-2016, 06:08 PM
  #203
Mark Shead
Mark Shead's Avatar
http://www.tremec.com/anexos/TKO_Ins...ps_117_117.pdf
Tech spec's recomend Dexron oil and I have tried other make oils and its worse,
I am currently looking in to Redline oil and what is recomended by them soon to see if theres helps as it has on other makes of boxs I have used.
Mark
Old 08-02-2016, 06:13 PM
  #204
nixon_2wd
nixon_2wd's Avatar
Hm thats new. Earlier it only stated the #12345349 GM syncromesh. Ive had my TKO since 2009 running that oil without issues, running AP centerpush slave.
Old 08-02-2016, 06:15 PM
  #205
Mark Shead
Mark Shead's Avatar
My own and Rods run the same oil and had no problems.
Mark
Old 08-02-2016, 06:21 PM
  #206
nixon_2wd
nixon_2wd's Avatar
I think I have an email from Tremec saying only run the GM syncromesh.
Unfortunately, its expensive as *** here in Norway at Ł50 / ltr, hence why I asked them lol.
Old 08-02-2016, 06:26 PM
  #207
Mark Shead
Mark Shead's Avatar
We need to look in to it more to sort these out, I will be calling redline tomorrow to see what they have.
Mark
nixon_2wd (08-02-2016)
Old 09-02-2016, 05:19 PM
  #208
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
The car was rescued from its tomb today & I began work on removing things under the bonnet. There is a lot to do on this car I realise that now. Many Many changes from the last Spec. Removed strut Brace Covers for Power Coating & had a chat with the sprayer to see what he required. Managed to complete half the engine bay in the 3 1/2 hours I allowed myself. Glad to say I can still clamber under the car (Its not on the ramps yet)when required although its way over 5 years since ive done that. Think Mark took some pictures as we dug the car out so will post as & when. Will be back on Friday for another 31/2 hours & hopefully the car will be ready for under bonnet paint. If not will go again on Monday so car is ready for spraying next week. As usual Mark wants changes to the wiring & wants to have more control of Fuel Pump Volts. We can have up to 21V max but only need that when at 3.5bar & on Methanol so not often. Not sure what hes up to yet but think the car will be able to tell when we put the different fuels in. Also trial fitted the dry sump system in the car. It still needs small mods but it should fit without changes to the steering rack but its tight.
We talked about Power again today & this will be limited by Turbo Speed. Mark thinks that pump will be limited to 800max then its how far do we push it. Boost will start at 3bar + on the ftw Purple & 950 is the likely outcome. If we achieve that Mark will take the GT4202 from the boot & strap that on & push it over 1000bhp. If we fall short & struggle to get past 900bhp the the GT4202 wont be used.
Enjoyed today
Cheers Rod
Rod-Tarry is offline
Old 09-02-2016, 05:54 PM
  #209
Mark Shead
Mark Shead's Avatar
Redline came back to me either D4AFT or MTL so I will be testing the MTL.
Mark
The following 3 users liked this post by Mark Shead:
Gav Diamond (16-02-2016), Hellraiser (21-02-2016), nixon_2wd (10-02-2016)
Old 16-02-2016, 04:27 PM
  #210
Gav Diamond
Gav Diamond's Avatar
Any pics or updates Rod?
Gav Diamond is offline
Old 19-02-2016, 01:59 PM
  #211
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Not much to report. Marks pictures didn't come out or at least ive not seen them. Have bought a hell of a lot of small items. Nuts, Bolts , Screws, Clamps, grommets, blanking Plugs etc. Not in picture but lots of heat shielding material as everything has been removed. The Strut Tops & Water Bottle are looking as new after Powder Coating. The next 10 days will see a big push or as big as I can cope with.
Mark is 50 minutes drive away so I cant cope with more than 2/3 days a week & a max of 3.5 hours a day.
I know that's Wimpy but the Missus is monitoring it as ive been ordered to take things easy. I also now have a page on Facebook to cover the build as it happens.
Old 19-02-2016, 04:21 PM
  #212
Jay,
Sponsor
Jay,'s Avatar
Rod its all looking good and you do what you can and it is your hobby no point making yourself ill or worrying Mrs Tarry
Jay, is offline
Old 19-02-2016, 09:09 PM
  #213
dojj
Resident Wrestling Legend
dojj's Avatar
your health is more important that the taxi rod, and even though you may think she's fussing over nothing or getting too worked up about something silly, as jay has said, no point in both of you getting all worked up about it
but on the other hand, them strut tops do look really nice
dojj is offline
Old 20-02-2016, 08:44 PM
  #214
1300gt
1300gt's Avatar
Great work rod. It's all dropping into place
1300gt is offline
Old 25-02-2016, 02:48 PM
  #215
toff
toff's Avatar
ave been away from the scene for a while and come back to this
so impressed your still going strong
toff is offline
Old 02-03-2016, 06:09 PM
  #216
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
This is the moment my car started its journey back from the grave. The car will be returned from paint tomorrow but the pic shows the underbonnet spruce-up is underway. Cant wait to get to work putting the bits back in & making the required changes to the wiring brought about by the new Spec. Will probably go over to Marks on Friday maybe to start that process if not will be Monday.
Old 02-03-2016, 06:18 PM
  #217
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Bet it was a shock seeing it move out off that ramp
ajamesc is offline
Old 02-03-2016, 06:37 PM
  #218
costina
Live long and prosper!!
costina's Avatar
That workshop needs a tidy.
Good to see progress Rod.
BUT take it steady
Paul
costina is offline
Old 02-03-2016, 07:40 PM
  #219
Caddyshack
Caddyshack's Avatar
BUT take it steady
Paul
It would do my head in working there and I can be messy when I work. I guess it is just the way we are wired up, if Mark was a neat freak he might not have the skills elsewhere. I visited Manthey racing at the Nurburgring and it looks like an operating theatre, as we walked off the workshop floor a geezer followed us with a floor polisher.
Caddyshack is offline
Old 02-03-2016, 08:01 PM
  #220
Adam-M
Adam-M's Avatar
Wish I had a papa like rod lol, I'd definately take things slowly at your age but hats off for still getting dirty.
That's not what I was picturing marks garage to be like, I was picturing shiny tiled floors and stainless worktops everywhere even though they never stay that way lol.
Adam-M is offline
Old 03-03-2016, 04:53 PM
  #221
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Well its back from paint so tomorrow I will start putting it back together.
Old 03-03-2016, 05:50 PM
  #222
Staffi
Staffi's Avatar
Can't wait to see this finished. Shell looks very clean Rod
Staffi is offline
Old 04-03-2016, 07:05 PM
  #223
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Did 4 hours today before Mark told me to stop felt fine but a bit tired after a long drive home. With the car on the ramps loads of little bits that need sorting came to life. Going to remove the rear suspension & sort out the surface rust & have the parts blasted. The rear arches under close inspection need a bit of work so its going back to paint to be sorted. Front half looks good. Started on the wiring its going to take a bit of time but I have loads of that. Its good for the brain taking out old Autronics wiring & trying to leave what I need behind. 2 wires had me beat, when I arrived home got the old Autronics CAD Drawings on the screen & sorted one of them. The other will be traced on Monday when I go back to Marks. The car goes back to paint 21st March so I have couple of weeks to sort all the wiring. Once all under bonnet wiring is sorted will put the 21V amplifier in the boot & wire in the fuel pump. This should be ample time if Mark/Missus will allow me to put the hours in.
ps. The gearbox has been removed so new heat shielding can be fitted must admit im amazed at the detail ive gone to in the past on this car not so sure I have that same sort of commitment now but I will try.
Old 05-03-2016, 11:08 PM
  #224
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
Nice work rod, it'll eventually get finished don't push too hard you have no deadlines. Slow and steady. Let's hope mark gets mine moved this week as I'm coming to get it shortly if it's done or not, times up now.
adamski frst is offline
Old 06-03-2016, 03:04 AM
  #225
visa_broke
visa_broke's Avatar
rod - do you have a link to the fb page? As others have said your health is the main thing, just don't over do it. Good luck getting progress on it now.
adamski frst - what was yours in for? anything interesting
visa_broke is offline
Old 06-03-2016, 07:30 AM
  #226
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
https://www.facebook.com/fastestcosworth/
Old 06-03-2016, 09:12 AM
  #227
adamski frst
Don't wanna hijack rods thread, Just head studs swap as mine was built few yrs back and the first running a efr and it's had head lift problems, so the new studs mark had made will fix it. Then it's off to the body shop for quite abit of work.
Old 06-03-2016, 04:27 PM
  #228
visa_broke
visa_broke's Avatar
thanks for the replies guys
Old 07-03-2016, 05:50 PM
  #229
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Im enjoying this working Lark. Another 4 hours on the car didn't get around to taking a pic but will try to remember that tomorrow. Closing in on finishing the Accuvolt, CDI & Nitrous wiring. Going to fit the Head lights tomorrow & sort out that wiring. Going well !!.
surrey_100e (07-03-2016)
Old 11-03-2016, 06:58 PM
  #230
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
These two parts will be fitted on Monday (maybe) its the 4 coil pack & the 22v Amplifier to drive the fuel pump. Taking longer than I thought but progress is being made.
Old 11-03-2016, 08:46 PM
  #231
Caddyshack
Caddyshack's Avatar
Get it on Rod, watching with interest.
Old 12-03-2016, 04:15 PM
  #232
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Ready to fit. The Breather & Coils were on this plate for the last engine. A dry-sump means no Breather required so its a great place for the 22V Amplifier for the Fuel Pump. Fits in the orginal battery tray with a bit of luck it will be wired in on Monday.
Old 15-03-2016, 04:18 PM
  #233
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Not good quality pics but better than nowt.
First two show 'Voltage' corner. The 12v terminal & to the left the 16v amplifier that supplies- CDI unit, EGT amplifier & Emtron ECU. the amp next to the coils is the 22v Amplifier that supplies the Fuel Pump. The CDI unit is mounted on the inner wing.
The 3rd Pic is the Nitous pulsoids & the purge valve. Lots still to tidy but getting there im now on the other inner ring with the heat shielding on the Turbo side my next task. Having 2 days off now but on Friday will remove rear bumper to allow some work on the rear arches to be carried out. The removal of the front & rear suspension will follow when it returns from paint going to have it blasted & painted. It looks like the front springs are shot so they will be replaced & the dampers removed & spruced up.
Old 15-03-2016, 08:42 PM
  #234
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Future updates will be posted here :- https://www.facebook.com/fastestcosworth/.
Old 15-03-2016, 09:57 PM
  #235
gjh
gjh's Avatar
Looking good Rod!
gjh is offline
Old 15-03-2016, 10:30 PM
  #236
tkracing
tkracing's Avatar
It's a hobby rod, remember there's other things more important, but keep plodding along matey, keeps the mind andbody working
Cracking job btw
tkracing is offline
Old 18-03-2016, 08:11 PM
  #237
surrey_100e
surrey_100e's Avatar
Was good to meet you today Rod, keep up the good work. Look forward to seeing it back up and running
surrey_100e is offline
Old 18-03-2016, 09:13 PM
  #238
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Good to see you liked your car.
JoeyBoyden
04-01-2024 02:36 PM
Sultzi
12
16-08-2015 01:08 PM
track.focus'd
12-08-2015 05:53 PM
Blown Hell
05-08-2015 07:22 AM
RIB1122
03-08-2015 09:20 AM
Quick Reply: Big build getting back on track
